EasternNotch Samba Member
Joined: January 19, 2006 Posts: 634 Location: Boston Metro West
Posted: Sun Sep 20, 2015 3:19 pm Post subject: Re: nice |
Bobnotch wrote: |
EasternNotch wrote: |
I am planning to take it on a small road trip this weekend up to New Hampshire to visit family. Should be a nice little ride and I can get a feel for how she does under a little stress. I would like to get up to highway speeds because all I have done is putt around on secondaries so far. |
Make sure you grease the front beam before you go. |
Yup solid advice thanks Bob and Donnie-
upper torsion had no noticeable play but I adjusted it anyway and noticed the lock tab was about to snap off so I replaced that during the process. The beam took a lot of grease and the upper zerks looked like they had not been touched in a long time.
On the way up to NH I took some nice backroads and the car felt great- so on the return trip I took the highway and she cruised along smoothly. Really happy with the trip overall, except I seem to have consumed excessive fuel. Next project is to verify the carb jetting _________________ 1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Oct 19, 2015 10:50 am Post subject: |
Photo from this past weekend-
Added these General tires a couple weeks ago on some Mahle wheels I got over the Summer at a swap.
195/65 front
205/65 rear
Fill the wheel wells at stock height. No rubbing at all
Very nice, and just a hint of color change in the trees. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Oct 30, 2015 3:40 am Post subject: |
Possible ignition switch failure yesterday-
I was about a 1/2 mile from my home at a traffic light and the car just stalled. I cranked it over and it reluctantly started. I turned left through the light and the car was losing power, I heard what sounded like a belt slip then smelled a hint of burning plastic.
After fiddling around on the side of the road a bit checking basics, I realized the ignition switch itself was no longer turning - I had to have my wife sit in the car holding the key forward so the wheel would not lock while I pushed it off the road into a driveway.
The key will not rotate to the 'On' position
I know this is a one year only ignition but is the the lock or the switch itself? If it was only the lack of movement I would assume it was a worn key or tumblers something like that but the faint plastic melting smell at time of failure has me wondering.
Any advice is appreciated
Lucas _________________ 1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
Posted: Wed Nov 04, 2015 7:00 pm Post subject: |
I haven't had a chance to dismantle the column yet and get to the root of the issue(s). I learned these ignition/indicator parts are 1 year only but I was able to source the electrical part of the switch last Saturday for 10 bucks. The part is new in box, but it looks like someone cut the MPC connectors( unless it comes this way) regardless I think I can splice the ones from my bad switch onto this one. My car came with a spare turn signal indicator switch and the cancellation feature doesn't work to one side so I Will replace this while I have it apart.
I also bought a NOS Ignition switch (mechanical part) with 2 keys from an ad on here. Going to get the column out and dismantled this coming weekend I hope.
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
Chino_UK Samba Member
Joined: January 08, 2014 Posts: 159 Location: Manchester, UK
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Nov 05, 2015 8:02 am Post subject: |
I learned these ignition/indicator parts are 1 year only but I was able to source the electrical part of the switch last Saturday for 10 bucks. The part is new in box, but it looks like someone cut the MPC connectors( unless it comes this way) regardless I think I can splice the ones from my bad switch onto this one. |
Yes, the new ones came that way.
KTPhil did a writeup on changing the 71 ignition switch:
http://www.thesamba.com/vw/forum/viewtopic.php?t=616570 _________________ 71 Elm Green FI A/T Squareback |
Posted: Thu Nov 05, 2015 9:04 am Post subject: |
Donnie strickland wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=616570 |
oops now I feel kinda bad because I talked the guy down thinking the connectors had been cut Oh well, it's someone I see a lot and it'll all work out in the wash.
I found Phil's write up and its awesome- going to follow it except i'll be using the correct switch. _________________ 1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Sat Sep 02, 2017 7:39 am Post subject: Re: 1971 Squareback- Iberian Red |
Couldn't think of another person I'd want to own that car Stan. These 2nd design cars are still underappreciated by many. You got a nice one! I hope to get your old '65 DD WT panel back on the road in the very near future.
-Lucas _________________ 1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
VWTECHEDITOR Samba Member
Joined: March 02, 2004 Posts: 99 Location: Southern Maryland, USA
Posted: Mon Sep 18, 2017 8:18 pm Post subject: Re: 1971 Squareback- Iberian Red |
Hey Stan;
Nice Type 3. I suspect that you'll enjoy it a lot.
I wanted to add my 2¢ worth regarding "fuel injection problems".
As you may remember from our past conversations, these cars were new back when I was a young man working at the Dealer. At the time, I was the newest guy in the shop and got the work that the older guys did not want. So I got most of the electrical and fuel injection problems. It quickly became apparent that:
- Electrical problems were mostly ground related.
- Fuel injection problems were usually tight valves, generator/regulator problems, and/or the aforementioned ground problems.
And as you can attest to, there are some that really do defy fixing. I currently have a '69 Squareback that is awaiting my attention. I acquired it because it did not run. One of the reasons is due to mismatched fuel system components. Contrary to popular notion, the parts are not all the same. For example, a "B" ECU replaces an "A", but a "C" does not replace "A" or "B". A "D" replaces a "C", but only if it has a black label and so on ad nauseam.
Digging out my notes from VW Fuel Injection school back in 1973 & 1974, my memory has been given quite a jog. However, these ancient systems are actually fun to work on (kind of).
Sorry to ramble.
Best of luck,
Art |
1-4-3-2 Samba Member
Joined: May 01, 2006 Posts: 104 Location: Rhode Island
Posted: Wed Oct 24, 2018 6:48 pm Post subject: Re: 1971 Squareback- Iberian Red |
Some pix from 2018, out enjoying this squareback.
NJ AirRaid and cul-de-sac camping. April 2018.
CT, CVA pre-show campout and Sping Dust-Off. April 2018.
Marlboro, MA, Main St. car show. June 2018.
Hull, MA, Nantasket Beach car show, with another red squareback. June 2018.
Terryville, CT, Bug-a-Fair. June 2018.
Shrewsbury, MA, Volks-fair at the Hebert's Candy mansion. July 2018.
Acton, ME, Vacationland VW Assoc. annual show. Aug. 2018.
Flanders, NJ, All Air-Cooled gathering. Sept. 2018.
Brookliine, MA, Transporterfest VW day. Oct. 2018.
_________________ Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709 |
rocketeer928 Samba Member
Joined: September 09, 2018 Posts: 41 Location: Enfield, Connecticut
Posted: Wed Dec 05, 2018 8:10 am Post subject: Re: 1971 Squareback- Iberian Red |
I thoroughly enjoyed looking through this thread. Very nice looking Squareback!! _________________ 1970 VW Type 3 Squareback - Cobalt Blue (Birdie)
1973 VW Type 1 Super Beetle Convertible - Red (Rosie)
2003 VW Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray |
