ghiafreek Samba Member
Joined: December 19, 2002 Posts: 937 Location: San Antonio, Tx
Posted: Thu Sep 17, 2015 6:10 am Post subject: Do I need to take off pan? |
I'm in the process of tearing down my '58
It's very straight and dry. I don't need to replace rockers and no other major welding is required. I am indecisive because I would really like to get 100% paint coverage. With the beam and tranny in, is it going to be almost impossible? |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Thu Sep 17, 2015 8:33 am Post subject: |
You are looking to paint the entire chassis and undercarriage?
If you remove the fuel tank you will find pretty good access up front for painting. Out back remove the engine and transmission. _________________ Ghia Owner Emeritus |
Posted: Thu Sep 17, 2015 11:09 am Post subject: |
Yes, I want to paint all. Problem I will have is that if its has to be a roller so spayer can handle it in and out of booth. |
malley56 Samba Member
Joined: January 29, 2006 Posts: 255 Location: Martinsville, VA
Posted: Thu Sep 17, 2015 12:07 pm Post subject: |
If doing a nut and bolt type restoration you might not be entirely happy with it unless you do take it off the pan... But I ended up not taking my vert off the pan because of worrying about body twist. They say it's fine as long as you do the correct bracing. Wasn't worth it in my case though. |
c21darrel Samba Member
Posted: Thu Sep 17, 2015 2:11 pm Post subject: |
c21darrel wrote: |
Quote: |
Problem I will have is that if its has to be a roller so spayer can handle it in and out of booth |
Never seen a shop that didnt have dollys to move projects around. Shouldnt be a problem. You can also search several threads on dollys that members have built for that reason.
That car looks nice! Looks good in black.
Color change? |
Thanks. No color change. Original Black Ghia.
I want to be able to have the beam off and tranny/motor out. Guess I could build some sort of dolly and have it mounted to tranny horns and front other for front beam mounts. Yep..thats gonna be the plan. |
VeloMikey Samba Member
1960bus Samba Member
Posted: Thu Sep 17, 2015 4:10 pm Post subject: |
On a vert you would need to brace the door apertures if you do take the body off the pan. If you have no rust to access then why mess with the original join? Its not hard to do it but on a dry Ghia I've never understood the benefit. _________________ Dan
1958 Ghia Vert
1960 RHD Deluxe Microbus
1966 RHD Devon Kombi |
Posted: Thu Sep 17, 2015 7:31 pm Post subject: |
CerveloMikey wrote: |
What size are your rear wheels and tires? Is that a deep six with a 205/65-15? |
close…205/60/15 |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Fri Sep 18, 2015 8:07 am Post subject: |
Here's a trans frame horn dolly on a bus. I've seen others a simple as a piece of angle iron with a single caster (centered). Can do similar up front at beam mounting location... even with just two wheels.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Fri Sep 18, 2015 1:31 pm Post subject: |
easy e wrote: |
SWEET!
That's what I was looking for.
Gonna draw it up and do that.
Thanks |
