jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Sep 21, 2015 11:45 pm Post subject: |
I had a machinist friend tap, thread and make a stem for my end mill. Gotta be delicate when drilling with the press and it's usually just a skim off the surface flat. Ran into too many cases with pounded relief valve seats.
_________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
mark tucker Samba Member
Posted: Mon Sep 21, 2015 7:42 pm Post subject: |
mine is a modified shortened sharpened ,reamer with a sleve for a guide and protection. the sand paper method may work, just be sure to keep it clean. |
Mad Manx Samba Member
Joined: September 30, 2004 Posts: 304 Location: Redondo Beach California
Posted: Mon Sep 21, 2015 6:54 pm Post subject: |
gprudenciop wrote: |
i went ala vw owner cheap!!
gorilla glue sand paper cloth to the bottom of an old plunger inserted tap on the other side and bam!! add to drill and enjoy... |
I went the same way unless it is really efed up this works great.
[img][/img] |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Mon Sep 21, 2015 6:33 pm Post subject: |
gorilla glue sand paper cloth to the bottom of an old plunger inserted tap on the other side and bam!! add to drill and enjoy... _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
Thing_Man73 Samba Member
Joined: October 11, 2014 Posts: 70 Location: San Diego
Posted: Mon Sep 21, 2015 6:30 pm Post subject: |
nsracing wrote: |
I ground several before and they are all gone/sold. Im not sure when I can make them again.
It is not that hard to make them if you have a cylindrical grinder.
Don't use an endmill as it will cut the inside walls and that will really screw up the case. The tool should only allow an end-cut....not a sidewall cut. |
I didn't want to get to technical, mine has a guide that screws into the plug hole and the flutes have been relieved from about .03 from the eop of the end-mill so that no side cutting can happen. I also believe mine is a .625 diameter. I should go out and measure it and take a picture. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Mon Sep 21, 2015 6:29 pm Post subject: |
it might be 16, I don't recall. Just measure a plunger! |
python12456 Samba Member
Joined: October 15, 2014 Posts: 34 Location: United States
Posted: Mon Sep 21, 2015 6:20 pm Post subject: Spot facing tool |
I thought they needed to be 16mm or is it 18mm.
I found a 16mm 4 flute end mill |
modok Samba Member
Posted: Mon Sep 21, 2015 5:09 pm Post subject: |
End mill will work but it does not take much to cut mag. I made mine from a french moped crank. Just have to find a something 18mm and sharpen it! |
nsracing Samba Member
Posted: Mon Sep 21, 2015 4:19 pm Post subject: |
Posted: Sun Sep 20, 2015 6:49 pm Post subject: |
mine has a guide on it so it doesnt effup the bore.
Ive seen the later hyd cases that have the oil gally offset about 2~3 mm and they were chattered all to hell when they were serfaced from the factory.probably due to the offset oil gally hole |
Posted: Sun Sep 20, 2015 5:30 pm Post subject: |
You can us a standard short flute, flat bottom, no corner radii 16mm Endmill.
You can buy one from McMaster-Carr |
Posted: Sun Sep 20, 2015 5:10 pm Post subject: oil relief |
ive contacted aircooled.net they don't have anymore for sale or rent thanks anyway |
74 Thing Samba Member
Posted: Sun Sep 20, 2015 1:49 am Post subject: |
John @ aircooled.net used to rent them out. You may want to contact him. |
Art Thraen Samba Member
Posted: Sun Sep 20, 2015 1:46 am Post subject: |
[img]
[/img] |
Posted: Fri Sep 18, 2015 5:46 am Post subject: Oil Relief spot face tool |
I am looking to buy or borrow a Oil Relief spot face tool to clean up my case. It looks like someone tried before and didn't do to good. Thanks |
