WW Stroker Crank Question
Lidpainter
Samba Anti-Hero
Lidpainter is offline
PostPosted: Tue Sep 22, 2015 8:44 pm    Post subject: WW Stroker Crank Question Reply with quote
I did a search but I could not find this info. Please don't flame me if I missed something obvious. I was wondering what pistons and rods are supposed to be used with the Wolfsburg West 36 hp stroker crank. Any info would be great. Thanks.
Thanks, time to bulk up on meat!
Jonnyla
Jonnyla is offline
PostPosted: Tue Sep 22, 2015 9:30 pm    Post subject: Reply with quote
I believe stock pistons and cylinders along with some shims between the cylinders and block. I may be way off but I think I read that somewhere... So basically someone with more knowledge needs to pipe in still. Laughing
'55 3 fold sedan, stock with lower stance (project)
'57 sedan, future old speed outlaw style (project)
Robert Chambers
Robert Chambers is offline
PostPosted: Wed Sep 23, 2015 4:31 am    Post subject: Reply with quote
The WW Okrasa Kit was covered a couple of times in the Dune Buggy and Hot VWs magazine. July 2010 first, then again in July and August , 2015. Not sure if it will answer all your questions, but they are a good reference for me. I have been following these threads and articles for a similar build. I recently bought an early Porsche crankshaft for my 36 dual carb build. Good luck with yours!
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'53 Standard Zwitter
'63 117
tobiasax
tobiasax is offline
PostPosted: Wed Sep 23, 2015 11:21 am    Post subject: Re: WW Stroker Crank Question Reply with quote
Hello, the stock rods need a light grinding and stock Pistons need to be modified. See my drawing at: http://lowlightkaizen.blogspot.se/2014/04/piston-clearance-for-695-mm-ww-crank.html?m=1
__________________________________________
RareAir
RareAir is offline
PostPosted: Wed Sep 23, 2015 1:48 pm    Post subject: Re: WW Stroker Crank Question Reply with quote
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1961 356B
1966 Typ 151
1966 Typ 241
volksartist
volksartist is offline
PostPosted: Wed Sep 23, 2015 3:48 pm    Post subject: Reply with quote
Pushrod spacers as well.
tobiasax
tobiasax is offline
PostPosted: Wed Sep 23, 2015 8:51 pm    Post subject: Reply with quote
It depends on the rest of the engine. My heads was machined down somewhat so I achieved good valve train geometry without spacers.
Lessoned learned: don't do anything to the pushrods until the engine is assembled.
Daniel hunt
Daniel hunt is offline
PostPosted: Tue Jan 03, 2017 2:54 am    Post subject: Re: WW Stroker Crank Question Reply with quote
I'm also going with the 69.5mm stroker counterweight crank in my 1959 bug. also going with a 80mm by 64mm big bore kit by AA performance requires machine work but will be worth it.
struggling on conrods though I read somewhere that staying with the stock length conrod will cause extra stress and so on. And so should use 5.394 length conrod instead. anyone got any experience with this or just knows if this is correct.
Also what needed/how much machining was required to the heads to allow a 69.5mm stroker?
Only info I find is to add shims but how much exactly and what I'm unsure.
btw I'm very new to the VW scene.
tobiasax
tobiasax is offline
PostPosted: Tue Jan 03, 2017 10:29 am    Post subject: Re: WW Stroker Crank Question Reply with quote
Stock con rods work just fine.
You need a spacer that builds approx. half the increased stroke (69,5-64)/2=2,75 mm
The extra stroke will increase the compression with a given set of heads. If you want to increase more you need to machine the heads, otherwise not.
EVfun
EVfun is offline
PostPosted: Wed Jan 04, 2017 9:36 am    Post subject: Re: WW Stroker Crank Question Reply with quote
With the talk about spacers are all the stroked 36 horse motors running dual carb setups? I don't see how a stock intake manifold would fit.
Wildthings wrote:
sled
sled is offline
PostPosted: Wed Jan 04, 2017 10:14 am    Post subject: Re: WW Stroker Crank Question Reply with quote
It's extremely easy to cut and lengthen the intake tubing. Exhaust pipes generally have to be modified as well.
drive your split.
EVfun
EVfun is offline
PostPosted: Wed Jan 04, 2017 4:28 pm    Post subject: Re: WW Stroker Crank Question Reply with quote
I don't think I've ever seen a welded intake manifold. I would be concerned that good weld penetration would end up creating a weld bump inside and airflow disruption.
Wildthings wrote:
snowbug
snowbug is offline
PostPosted: Thu Jan 05, 2017 8:48 am    Post subject: Re: WW Stroker Crank Question Reply with quote
have a look at my build, I am not using any spacers. http://www.thesamba.com/vw/forum/viewtopic.php?t=589193 Jim
Old enough to remember THRILLS, the gum that tastes like soap.
