Bobnotch Samba Member
Posted: Sat Dec 03, 2022 1:07 pm Post subject: Re: 1964 1500S Notchback |
Yup, when I built my 65 Notch, I didn't think twice about going 12 volt. As it was, I basically had to replace all of the electrics anyway, so I just went thru my 12 volt parts collection, and used what I had.
Way back in the early-mid 80's I had a 66 Square that was 6 volt. I drove it about an hour at night, then the next day tried to start it only to have a dead battery. I then proceeded to convert it to 12 volt using parts from a 71 square that was being parted out. I never had a dead battery in that car again after I converted it. Sold it with the 12 volt conversion too, after I explained what I did to the new owner.
On my T-34, I converted it to 12 volt as well, and didn't think twice about it. When I sold that car, I included ALL of the 6 volt stuff I removed in case the new owner wanted to return it back to 6 volt.
If you use stock T-3 parts, it makes converting it easy, and returnable back to 6 volts IF you want to. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sun Jan 01, 2023 8:43 pm Post subject: Re: 1964 1500S Notchback |
After having the Gen & Reg checked - the Reg is dead. No bueno since its a custom job I had done.
I bought some nice 6 volt regulators from BusOK and am ready to move on. Install is coming up.
I did have some weird issue with belt on the generator. Belt is correct but is loose? All the shims are out too.
I took some time too and put the NOS Marshal Fogs on the Pedro bar. These look so cool and may still end up on the front of this car.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Apr 16, 2023 7:44 pm Post subject: Re: 1964 1500S Notchback |
Also on the list this last week was to re-seal the wood slats on the roof rack. They get Sun Farked here in SoCal quickly. If these flake again Im taking off the clear and using Teak Oil.
t3kg wrote: |
1964 1500 S
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Apr 17, 2023 7:23 am Post subject: Re: 1964 1500S Notchback |
notchboy wrote: |
Wrong belt? 6v pulley diameter is smaller - Gates 7390 fits well but Gates 7395 is too big, in my experience. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Apr 17, 2023 9:08 am Post subject: Re: 1964 1500S Notchback |
sjbartnik wrote: |
notchboy wrote: |
Wrong belt? 6v pulley diameter is smaller - Gates 7390 fits well but Gates 7395 is too big, in my experience. |
You would think. But the pully on the 12 is the same as the 6 (at least mine are). I started this whole ordeal with a belt for a 66 Fastback - 6v and in American spec books for parts. Its not that it wont fit. The belt is on and spins the gen just fine - at all in - no shims - tightest possible scenario. Its just super slack in my opinion. I want to spin the motor off the tension of the belt, not jab through the hole and bung up my tin. Like every T3 Ive ever owned. _________________
t3kg wrote: |
1964 1500 S
Posted: Mon Apr 17, 2023 11:41 am Post subject: Re: 1964 1500S Notchback |
notchboy wrote: |
sjbartnik wrote: |
notchboy wrote: |
You would think. But the pully on the 12 is the same as the 6 (at least mine are). I started this whole ordeal with a belt for a 66 Fastback - 6v and in American spec books for parts. Its not that it wont fit. The belt is on and spins the gen just fine - at all in - no shims - tightest possible scenario. Its just super slack in my opinion. I want to spin the motor off the tension of the belt, not jab through the hole and bung up my tin. Like every T3 Ive ever owned. |
Keep in mind that if you run the belt too tight that you chance damaging the generator bearings. It's not really meant to run with the belt tight as it's only running the generator, not a gen and fan like on a bug, bus, or Ghia. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 17, 2023 1:24 pm Post subject: Re: 1964 1500S Notchback |
Bobnotch wrote: |
notchboy wrote: |
sjbartnik wrote: |
notchboy wrote: |
Keep in mind that if you run the belt too tight that you chance damaging the generator bearings. It's not really meant to run with the belt tight as it's only running the generator, not a gen and fan like on a bug, bus, or Ghia. |
Way ahead of you brother. _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Apr 18, 2023 11:35 am Post subject: Re: 1964 1500S Notchback |
notchboy wrote: |
Bobnotch wrote: |
notchboy wrote: |
sjbartnik wrote: |
notchboy wrote: |
Way ahead of you brother. |
Just a friendly reminder is all. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Ossipon Samba Member
Posted: Fri Jun 30, 2023 5:15 am Post subject: Re: 1964 1500S Notchback |
notchboy wrote: |
Sold - moving onto the Ghia Project
Did you get what you wanted? I liked this thread so much to compare with my poor sibling 64 notch. _________________ Ossipon
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 |
Posted: Fri Jun 30, 2023 6:40 am Post subject: Re: 1964 1500S Notchback |
Ossipon wrote: |
notchboy wrote: |
Did you get what you wanted? I liked this thread so much to compare with my poor sibling 64 notch. |
Yeah it was fair. I didn't push it and wanted a quick sale. If anyone thinks selling a decent/nice car right now will be hindered by the economy, well it sure aint affecting nice notchback sales. _________________
t3kg wrote: |
1964 1500 S
jparee1 Samba Member
Joined: December 06, 2017 Posts: 1 Location: Saint Petersburg, FL
Posted: Thu Apr 18, 2024 7:29 pm Post subject: Re: 1964 1500S Notchback |
notchboy wrote: |
Ossipon wrote: |
notchboy wrote: |
Yeah it was fair. I didn't push it and wanted a quick sale. If anyone thinks selling a decent/nice car right now will be hindered by the economy, well it sure aint affecting nice notchback sales. |
Hey Notchboy, reaching out in the hopes you may be able to provide some insight into this particular Notchback. I’m actually now the proud owner of this vehicle. I live in Florida, so I had to have it transported which went really smooth. I just managed to complete the registration process and on the way home it died on me.. pretty sure it’s the battery. Also, it’s leaking quite a a bit of oil. I read through this thread in the hopes of getting a better understanding of what work was done to either restore and/or improve the vehicle but still looking for some additional feedback. Any help would be greatly appreciated. Thanks Joe |
Posted: Fri Apr 19, 2024 7:44 am Post subject: Re: 1964 1500S Notchback |
Battery drain has always been an issue. Even with the clock out. Whoever restored the car in Germany cut corners at the end like they ran out of time, money & patience. The main wire loom is cut where it enters the car by the fuse block. I suspect that to be the main culprit of power suckage. I tore the motor down to the short block and cleaned up a multitude of sins but never did a full rebuild which it needs. It has sat for 8 to 10 years not being driven much if not at all, so all the brake soft lines may be swelled. Double check that with the guy you bought from. He may have changed them.
I would put a new loom in and rebuild a nice single port 1600 for it. Otherwise it's a super solid car. The resto done in Germany was great on body, metal and rust. Pretty much shit for everything else. The fact that you have a nice original interior put you way ahead of many others. _________________
t3kg wrote: |
1964 1500 S
