captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Sat Oct 03, 2015 6:10 pm Post subject: |
If I lived in Florida I wouldn't want a trailer. The number of toll roads that have sprung up there in the last couple of years is crazy. When I drove across last I didn't notice if they charged you extra for a trailer; most do. Last time I drove to RI with a trailer I think I dropped like $40 in tolls. Probable shouldn't have gone through Boston. _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
Posted: Sat Oct 03, 2015 8:58 pm Post subject: |
captincanuck wrote: |
If I lived in Florida I wouldn't want a trailer. The number of toll roads that have sprung up there in the last couple of years is crazy. When I drove across last I didn't notice if they charged you extra for a trailer; most do. Last time I drove to RI with a trailer I think I dropped like $40 in tolls. Probable shouldn't have gone through Boston. |
Us'en Mericans hate dem unfar gasoline taxes, what cost us 2 cents per mile. Dem tolls hast to be better as we'uns only hast to pay em to use certain roads. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri Oct 30, 2015 9:50 pm Post subject: |
I have a solution to get all that weight completely off the bus and yet still in the exact same place. It's called a swivel wheel and you have it under the load and have the frame attach at two points to the frame of the bus so it can move up and down. It's the same as towing a single wheel trailer except you would be pushing it. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
inhabor Samba Member
Joined: September 09, 2012 Posts: 194 Location: florida
Posted: Wed Nov 04, 2015 4:44 pm Post subject: |
Working on it.
babysnakes Samba Member
Posted: Wed Nov 04, 2015 4:53 pm Post subject: |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Wed Nov 04, 2015 5:26 pm Post subject: |
Thanks. I'm also re-doing the cage. I'm amazed about how much lift I got after moving the spare tire and the fire extinguishers. |
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Wed Nov 04, 2015 9:06 pm Post subject: |
don't you want to run a bead down the vertical sides of those adjustersl, not just the top and bottom?? I have never installed that style of adjuster before but it seems like you don't want to leave to load to be handled only by one weld in tension and the other in compression, when you can distribute the total load to the sides in shear as well. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Posted: Thu Nov 05, 2015 4:08 am Post subject: |
I did. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3792 Location: San Jose, CA
Posted: Thu Nov 05, 2015 9:35 am Post subject: |
Busstom wrote: |
I only have two ideas: Install beam adjusters, or... |
I was wondering where you went. |
Posted: Thu Nov 05, 2015 10:04 am Post subject: |
I live in West Palm Beach and my brothers shop is up in Tampa Bay so is a very slow process. |
Posted: Thu Nov 05, 2015 10:48 am Post subject: |
I would be careful to monitor the springs to see if they are going to sag and break some day. If you lift them off the bump stops, they will have room to come down even more because of the weight on the nose. Right now they can't bend because the bump stops are holding them. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Thu Nov 05, 2015 7:03 pm Post subject: |
inhabor wrote: |
Chalk up another win for SCIENCE! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Greg in GA Samba Member
Posted: Thu Nov 12, 2015 11:46 am Post subject: |
jtauxe wrote: |
Chalk up another win for SCIENCE! |
Science had nothing to do with it, he simply moved the ballast closer to the fulcrum _________________ 1969 Beetle
1974 Westy 1800cc FI conversion, L62H
Need a really good mechanic for your VW bus? Consider making an appointment with Colin (Amskeptic) next time he passes thru your area. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12689 Location: on a bike ride somewhere
Posted: Thu Nov 12, 2015 12:03 pm Post subject: |
Greg in GA wrote: |
jtauxe wrote: |
Science had nothing to do with it, he simply moved the ballast closer to the fulcrum |
Mm, physics is one of the sciences, so I think we're all winners. Plus, the people who are driving around that bus will benefit too, in an emergency maneuver! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Thu Nov 12, 2015 12:28 pm Post subject: Re: Heavy bus |
sorry, it's difficult to convey sarcasm using a keyboard. _________________ 1969 Beetle
Tcash Samba Member
Posted: Thu Nov 12, 2015 12:28 pm Post subject: |
asiab3 wrote: |
emergency maneuver! |
Posted: Sat Nov 28, 2015 8:43 pm Post subject: Re: Heavy bus |
Generator moved to the back of the bus
Tcash Samba Member
Posted: Sat Nov 28, 2015 9:33 pm Post subject: Re: Heavy bus |
That is a nice generator holder.
Nice
Tcash |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Sat Nov 28, 2015 11:59 pm Post subject: Re: Heavy bus |
Nice job. You have some serious welding/fabrication skills! _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
