Kdavid Samba Member
Joined: October 12, 2014 Posts: 318 Location: Belgium
Posted: Mon Dec 18, 2017 8:10 am Post subject: Re: 64 microbus body restoration |
Okey
The seller of the kit says..
Why buy them when i can make one
Vw shim and 2mm
And installed my new clutch
Rustyscrew Samba Member
Posted: Tue Dec 19, 2017 11:30 pm Post subject: Re: 64 microbus body restoration |
Such an amazing build. I love seeing the progress and attention. A true inspiration to me. |
Kdavid Samba Member
Posted: Thu Dec 28, 2017 12:22 pm Post subject: Re: 64 microbus body restoration |
Restoring my original 64 gearbox
This one has lots of miles on it compared to my straight axle box
i can see more wear on the gears and differential and lots of wear especially on the 3rd gear.. all the other ones and syncros seem fine to reinstall
so i tried to macgyver my 3rd gear ... results ??
will i succeed and will the box shift in 3rd with or without teeth grinding ??
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Thu Dec 28, 2017 1:07 pm Post subject: Re: 64 microbus body restoration |
Simply stunning, amazing craftsmanship Sir! What an amazing build you are doing! I can't wait to see it in person someday! Jesus! You even built your own heater log yourself! POW!!! Mind blown!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Kdavid Samba Member
Posted: Mon Jan 01, 2018 3:54 am Post subject: Re: 64 microbus body restoration |
more problems here with my input drive shaft seal, the lip in the front (dust seal) is not sealing the input shaft... the seal fitted my straight axle box without a problem tho... so did a little modification to make it work with the seal that i have.
so no metal shavings from the ring gear and starter, or other dirt can enter my seal and destroy it
BarryL Samba Member
Joined: November 01, 2004 Posts: 14216 Location: Casa de Oro, California
Posted: Tue Jan 02, 2018 12:40 pm Post subject: Re: 64 microbus body restoration |
Kdavid wrote: |
will i succeed and will the box shift in 3rd with or without teeth grinding ?? |
How are the mating teeth on the slider part?
I've seen that a lot. It's like there's an inner seal held with the compression ring spring and an outer dust seal. Some shafts have a longer flat surface.
Interesting fix you made. |
Kdavid Samba Member
Posted: Tue Jan 02, 2018 1:40 pm Post subject: Re: 64 microbus body restoration |
@BarryL
Teeth on the slider were in reasonable condition
compared to the ones on the 3rd gear
material on the slider must be a bit harder or better quality
than the gear part.. |
Kdavid Samba Member
Posted: Sun Jan 07, 2018 3:21 am Post subject: Re: 64 microbus body restoration |
RWK Samba Member
Posted: Sun Jan 07, 2018 12:08 pm Post subject: Re: 64 microbus body restoration |
Love your build. Starting to work on my 63 SC, where did you get your roll over frame plans for flipping bus on side? or could you possibly post or pm me your rough dims, I can make mounting plates
just looking for other leg lengths and height from floor ect, how easy is it to flip?
Thanks _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Sun Jan 07, 2018 2:36 pm Post subject: Re: 64 microbus body restoration |
Great detailed project!
Really good work, I like it a lot! |
Kdavid Samba Member
Posted: Wed Jan 17, 2018 11:21 am Post subject: Re: 64 microbus body restoration |
Before
looks much better now
Skim Rants Master
Joined: April 15, 2001 Posts: 17081 Location: GFK 31 Year Vet
Posted: Wed Jan 17, 2018 3:49 pm Post subject: Re: 64 microbus body restoration |
That's a beautiful transmission right there. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Wed Jan 17, 2018 5:20 pm Post subject: Re: 64 microbus body restoration |
That was a ton of work, but it will all be worth it when you're cruising with a quiet gear box...well aside from the Reduction Whine! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Wed Jan 17, 2018 5:22 pm Post subject: Re: 64 microbus body restoration |
motofly196 wrote: |
straight cut gears come with their own reward _________________ regards
Uli
Kdavid Samba Member
Posted: Sun Jan 28, 2018 9:06 am Post subject: Re: 64 microbus body restoration |
Both painted
Next the steering column
Kdavid Samba Member
Posted: Sun Feb 11, 2018 12:30 am Post subject: Re: 64 microbus body restoration |
Kdavid Samba Member
Posted: Thu Mar 22, 2018 9:39 am Post subject: Re: 64 microbus body restoration |
little safety modification on the fuel tank
shut off valve to connect on the ignition switch
LostnaWesty Samba Member
Posted: Tue Mar 27, 2018 6:11 am Post subject: Re: 64 microbus body restoration |
what a great build. looks just like the bus I acquired. |
Kdavid Samba Member
Posted: Sun Apr 15, 2018 10:22 am Post subject: Re: 64 microbus body restoration |
Heater tube welded in
And some cleaning and painting..
Getting slowly closer to bodywork and sanding the damn thing
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Mon Apr 16, 2018 9:08 am Post subject: Re: 64 microbus body restoration |
Did you sandblast the underside, or just sand, and wire brush it to clean it up? It looks awesome. |
