Kdavid Samba Member
Joined: October 12, 2014 Posts: 318 Location: Belgium
Posted: Fri Aug 27, 2021 8:49 am Post subject: Re: 64 Microbus Body Restoration |
Wipers are successfully installed and emblem is on 😄
Need to drill a hole for the rubber safari thingy for the wipers … scared 😱
Starting to look like a functional bus
It is a 64 bus
Wiper motor is a single speed one.. ? Only 2 connection on it ground
And power, original was a 6v and i converted the motor to 12v
When i power them on I’m thinking they going to fast
Switch was a simple on/off
When i disassembled the whole thing i found those 2 components
Under the dash it seem they are resistors
Could it be they where in between the wiper motor to slow it down ?
Or do they have another purpose ? Usa made ? Not original parts I guess ?
Gone make my own wiring, old one was to far gone
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 23748 Location: Southeast USA
Posted: Fri Aug 27, 2021 11:37 am Post subject: Re: 64 microbus body restoration |
Kdavid wrote: |
Do not know if I should paint the arms also in seagull grey like the bus ?? |
The silver looks correct. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Kdavid Samba Member
Posted: Fri Sep 10, 2021 10:00 am Post subject: Re: 64 Microbus Body Restoration |
Before 🤭
Looks way better 😄 and safer 🔥
Front of the bus is fully wired and operational
Fuse box is not an original model… did go for an more modern,
and reliable one in my opinion.
After double checking… let's hope i didn't forget anything 😬
Added a voltage regulator and now wiper speed is adjustable 👌🏻
New fuel tank is in 🎉 what a pain to install without damaging the paint
Busstom Samba Member
Joined: November 23, 2014 Posts: 3789 Location: San Jose, CA
Posted: Fri Sep 10, 2021 10:09 am Post subject: Re: 64 Microbus Body Restoration |
Stunning. Absolutely stunning. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Fri Sep 10, 2021 3:33 pm Post subject: Re: 64 Microbus Body Restoration |
Kdavid wrote: |
i don't fault you for using more modern fuses. really no reason to go much more modern. of course a modern programmable PDU would eliminate all fuses and relays..... much more expensive, though. _________________ regards
Uli
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Fri Sep 10, 2021 5:23 pm Post subject: Re: 64 Microbus Body Restoration |
EverettB wrote: |
Looks clean here.
What's the black ring at the top of the heater tube? Extra seal?
The safari latches go the other way, if you want to match the factory
it also makes it where you can actually hit the little button and turn it at the same time. pretty tricky when they are mounted the other way. _________________ regards
Uli
Kdavid Samba Member
Posted: Sat Sep 18, 2021 9:48 am Post subject: Re: 64 Microbus Body Restoration |
A programmable PDU would be nice indeed. Would be a waste of money and of its potential. not even one relay installed in the bus only a flasher unit, way to basic electrical system. also more used with touch display would be a shame to delete the original buttons
The black strap on the heater tube is a cable tie 😁
Did not know about the safari latches 🤔
They came like this on the aftermarket windows
Now figuring out the brake lines 🤔
easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
Posted: Sat Sep 18, 2021 11:39 am Post subject: Re: 64 Microbus Body Restoration |
Kdavid wrote: |
Your bus is looking really nice!
If you have any spare paint for the upper body color... it's a nice finishing touch to have the emblem with the correct paint split, between the "V" and the "W."
Here's an original paint emblem:
VW brochure:
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Kdavid Samba Member
Posted: Sat Sep 18, 2021 12:36 pm Post subject: Re: 64 Microbus Body Restoration |
If you have any spare paint for the upper body color... it's a nice finishing touch to have the emblem with the correct paint split, between the "V" and the "W." |
thanks for the tip !
did not know this
will do |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Sat Sep 18, 2021 1:15 pm Post subject: Re: 64 Microbus Body Restoration |
Kdavid wrote: |
did not know this
will do |
Evan beat me to it! Such a small detail, but you will see how that little line of paint makes the whole thing pop.
It all looks great, as in exceptionally well done! Keep at it! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Two Glove Boxes Samba Member
Kdavid Samba Member
Posted: Sun Sep 19, 2021 10:31 am Post subject: Re: 64 Microbus Body Restoration |
Throttle fixed 👍🏻 Thanks
Works better
A bit of guessing for the brake lines ... not fully satisfied with the result
Missing a hole for the brake line to the back of the bus ? 🤔😅
Drums are on, brakes regulated, speedometer cable installed
Making progress 🎉
easy e Samba Member
Posted: Sun Sep 19, 2021 12:54 pm Post subject: Re: 64 Microbus Body Restoration |
Kdavid wrote: |
Yes, the brake line should be located between the clutch cable conduit and the flange of the intermediate brace.
Click on picture to enlarge: _________________ aka: Evan
Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 760 Location: Brussels - Belgium
Posted: Sun Sep 19, 2021 11:42 pm Post subject: Re: 64 Microbus Body Restoration |
Great progress sofar!!
Did not know about these seals (those bigger ones where they pass the panel) for the clutch and e-brake cables??
Where did you get these and have the reference by any chance? Could not find them back immediately? _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1212 Location: So. Cal
Kdavid Samba Member
Posted: Fri Sep 24, 2021 11:30 am Post subject: Re: 64 Microbus Body Restoration |
Hole is drilled, brake lines are in 👍🏻
Lowered the rear spring plate 1 tooth
Now the front, i do like the ride height like this 🤩
Rear end bit higher, when engine installed gone be okey ? 😄 i hope 🤞🏻
Now wheels need to come off again 😄
And install the rear brakes, and bleeding the system
Was curious to se the ride height first 😎 need to pas inspection
aa390392 Samba Member
Posted: Fri Sep 24, 2021 1:04 pm Post subject: Re: 64 Microbus Body Restoration |
Very clean
Nice work. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
