wcfvw69 Samba Purist
Posted: Sat Sep 25, 2021 4:43 pm Post subject: Re: 64 Microbus Body Restoration |
Beautiful! Looks showroom fresh! _________________ Contact me at [email protected]
The Samba member since 2004.
69aircooled Samba Member
Joined: August 04, 2004 Posts: 240 Location: North Carolina
Posted: Sat Sep 25, 2021 6:08 pm Post subject: Re: 64 Microbus Body Restoration |
Your bus is incredibly nice! You’ve done a fabulous job restoring it. I have followed along since the beginning of this thread and this is one of if not the best restores on this site. Congrats! |
easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
Posted: Sun Sep 26, 2021 12:43 pm Post subject: Re: 64 Microbus Body Restoration |
You are making great progress!
I can see you are not completely finished installing the axle boots… so good place for a suggestion:
Best to orient the axle boot seam (horizontal) to either point towards the front or rear of the bus. Any other orientation makes excess stress / can cause premature failure.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Kdavid Samba Member
Joined: October 12, 2014 Posts: 318 Location: Belgium
Posted: Wed Sep 29, 2021 11:21 am Post subject: Re: 64 Microbus Body Restoration |
Brakes are in and regulated, brakes are bled. No leaks 🤞🏻
shock absorbers installed, axle boots fixed in place (Didn't put them completely horizontally. to avoid oil leaks). Oil in the axle 👍🏻
fuel shut off solenoid installed
Now the starter and finishing the wiring in the back
Finally time for the ENGINE 😎😆 first drive 🚌 🎉 |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3412 Location: San Diego
Posted: Wed Sep 29, 2021 5:11 pm Post subject: Re: 64 Microbus Body Restoration |
You definatly get an A+ for detail and cleanliness. Very nice indeed |
Kdavid Samba Member
Posted: Fri Oct 01, 2021 10:54 am Post subject: Re: 64 Microbus Body Restoration |
Engine is in 🤩
Hotwired the engine to see if everything cleared
And if clutch working properly 👍🏻😅
Video 😄
https://youtu.be/kBBo-5n9pNI
Posted: Fri Oct 01, 2021 3:03 pm Post subject: Re: 64 Microbus Body Restoration |
Very nice! |
Kdavid Samba Member
Posted: Sat Oct 09, 2021 12:45 pm Post subject: Re: 64 Microbus Body Restoration |
Found some inox adapters for the heater tubes, Command wires installed,
not sure where the return springs are connected.
After some tries it works as it should be 👍🏻
battery and disconnect switch installed
They send me the carpet all rolled up... can't get it nice and flat again 🥲
Kdavid Samba Member
Posted: Sat Oct 09, 2021 12:53 pm Post subject: Re: 64 Microbus Body Restoration |
First time since restored outside, and driving 🤩
CanStan Samba Member
Joined: October 16, 2005 Posts: 1036 Location: Calgary, AB
Posted: Sat Oct 09, 2021 5:37 pm Post subject: Re: 64 Microbus Body Restoration |
This is such a great build!
But has this changed?:
easy e wrote: |
Best to orient the axle boot seam (horizontal) to either point towards the front or rear of the bus. Any other orientation makes excess stress / can cause premature failure. |
I thought the collective wisdom was to point the seams to 10 or 2 for this exact same reason? I've never had issues with good boots pointed the 'old' way, but if people are seeing them stress worse like that, I'll try the 'new' way next time. |
easy e Samba Member
Posted: Sat Oct 09, 2021 6:21 pm Post subject: Re: 64 Microbus Body Restoration |
CanStan wrote: |
easy e wrote: |
He did it your way: "... axle boots fixed in place (Didn't put them completely horizontally. to avoid oil leaks)." _________________ aka: Evan
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Sat Oct 09, 2021 9:05 pm Post subject: Re: 64 Microbus Body Restoration |
Kdavid wrote: |
I've never seen springs like that on the flap arms... when were those used? _________________ How to Post Photos
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 191 Location: Porto - Portugal
Posted: Sun Oct 10, 2021 5:57 am Post subject: Re: 64 Microbus Body Restoration |
Kdavid wrote: |
... bummer.
But this is my suggestion: Do not use it by now.
Since the warm summer time is all gone by now, keep it stored facedown with some flat weight on top of it until better sunny days. Or if you have heated floors, just do it during the winter season and check back by spring or early summer? |
Kdavid Samba Member
Posted: Sat Oct 16, 2021 8:19 am Post subject: Re: 64 Microbus Body Restoration |
Seems like i’m missing 2 door seals 🤭
Almost there, the end is nearby 😎
Apart from the interior … 😫 |
Braukuche Samba Member
Posted: Sat Oct 16, 2021 8:21 am Post subject: Re: 64 Microbus Body Restoration |
Looks fantastic. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
ddutch Samba Member
Posted: Sat Oct 16, 2021 8:55 am Post subject: Re: 64 Microbus Body Restoration |
Incredible build of an awesome, like new bus in my favorite color. That engine runs very nice and smooth too.
Dutch mode on;
Gefeliciteerd met dit fantastische mooie resultaat! Woont u in Vlaanderen? Groet uit Utrecht.
Dutch mode off. |
Mid West Dubber Samba Member
Joined: July 11, 2011 Posts: 302 Location: Natimuk, VICTORIA, AUSTRALIA
Posted: Sat Oct 16, 2021 6:59 pm Post subject: Re: 64 Microbus Body Restoration |
I’m not sure you have any seals missing. I believe it is only meant to have a top and bottom seal on the body and the doors all the way around. Happy to be corrected |
mdege Samba Member
Joined: January 16, 2018 Posts: 936 Location: Niederkruechten, Germany
Kdavid Samba Member
Posted: Fri Oct 29, 2021 9:15 am Post subject: Re: 64 Microbus Body Restoration |
Next challenge has arrived…
Never done this… not much information to be found on the internet
I’m gone try it, wish me luck 🍀 |
