Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Kdavid Samba Member
Joined: October 12, 2014 Posts: 318 Location: Belgium
Posted: Sun Feb 27, 2022 8:16 am Post subject: Re: 64 Microbus Body Restoration |
To many choices… 🥺
Kdavid Samba Member
Posted: Tue Mar 08, 2022 10:06 am Post subject: Re: 64 Microbus Body Restoration |
First attempt 😄
Need a better sewing machine
And some modifications to the working and assembly process
So we don’t have the line in the semi leather
And not convinced off collor combo …
Otherwise not to bad for a couple off amateurs 😄👍🏻
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Tue Mar 08, 2022 6:50 pm Post subject: Re: 64 Microbus Body Restoration |
Will you be adding the anodized aluminum strips over the sew line? I think that would accentuate the line at the semi leather intentionally. |
Kdavid Samba Member
Posted: Wed Mar 09, 2022 4:17 am Post subject: Re: 64 Microbus Body Restoration |
I cant seem to find those chrome moldings.. or they are way overpriced 🥵
Want the panels to be like the picture below
Need to fold the fabric on the back the other way I suppose, or cut the
excess fabric way shorter
Posted: Wed Mar 09, 2022 5:43 am Post subject: Re: 64 Microbus Body Restoration |
BBT or CSP can supply those trims (WW) ... just bought them as well for my doors:-) Have not received them yet, so still need to fit.
I just glued the fabric to the board with a 4-5mm overlap. That overlap should be covered with the trim.
Or indeed cut the excess fabric shorter so it is not showing that much? _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Kdavid Samba Member
Posted: Sun Mar 13, 2022 10:04 am Post subject: Re: 64 Microbus Body Restoration |
On the picture it looks grey, actually outside
or in real life its the color beige
Kdavid Samba Member
Posted: Sat Apr 30, 2022 8:45 am Post subject: Re: 64 Microbus Body Restoration |
Update on upholstery 😅
After a whole lotta testing, and waiting for the fabric to arrive.
This box section im not totally satisfied, after some research on the
thing, a bit to small and needs to be flat on the underside
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
Posted: Sat Apr 30, 2022 9:51 am Post subject: Re: 64 Microbus Body Restoration |
Your attention to detail is truly outstanding |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Sat Apr 30, 2022 8:00 pm Post subject: Re: 64 Microbus Body Restoration |
This is one of the nicest custom interiors I've ever seen. |
Kdavid Samba Member
Posted: Sun May 22, 2022 10:59 am Post subject: Re: 64 Microbus Body Restoration |
Update on interior
Made the decision to install a Rusty Lee Rockn Roll bed in the back
Of the bus 😄
hellie91 Samba Member
Posted: Sat May 28, 2022 1:17 pm Post subject: Re: 64 Microbus Body Restoration |
Knap werk.
Goe bezig.
Groeten Thomas |
Kdavid Samba Member
Posted: Sun May 29, 2022 11:21 am Post subject: Re: 64 Microbus Body Restoration |
Door cards okey… made allot of tests and mistakes
It worked out 🥵
Seat upholstery… making a cover from scratch… no previous experience
Not even the old cover to use as template
Not the original springbox… OMG 🤯
Test cover made and we are both satisfied 😄
Now we make the real deal 🤞🏻
bigkevo Samba Member
Joined: July 05, 2006 Posts: 10 Location: perth, West Australia
Posted: Sun May 29, 2022 6:08 pm Post subject: Re: 64 Microbus Body Restoration |
Awesome work, great to see others giving the interior panels a shot, they look excellent! |
Kdavid Samba Member
Posted: Thu Jun 23, 2022 10:40 pm Post subject: Re: 64 Microbus Body Restoration |
Ivan's junkyard car cemetery, Bastnäs 🇸🇪
Beautiful place to visit if your a car guy 😁
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
BarryL Samba Member
Posted: Fri Jun 24, 2022 6:31 pm Post subject: Re: 64 Microbus Body Restoration |
That is just outright incredible how they made that in miniature. |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Sat Jun 25, 2022 11:42 am Post subject: Re: 64 Microbus Body Restoration |
Or a car gal
Kdavid wrote: |
Beautiful place to visit if your a car guy 😁 |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Kdavid Samba Member
Posted: Sun Jul 10, 2022 9:00 am Post subject: Re: 64 Microbus Body Restoration |
It has bin a while since the bus had a complete front end
The bumper needed a lot of love and attention
Like every other part on this thing 😝
Kdavid Samba Member
Posted: Fri Jul 22, 2022 7:15 am Post subject: Re: 64 Microbus Body Restoration |
It turns out i have an oil leak (or multiple) on my engine
There was oil on the left and right side
And push rod tubes where in oil
I did stretch the old ones and reuse them, so i assumed it was my stupid mistake.
So ordered a csp set with installation tool, easy fix i thought don't need to take out the engine or take off the heads…
Today i took off the tins underneath the engine so i could have a better look.
Turns out the oil comes from higher 😩
On the right side the thermostat was also soaked in oil
Time for a test
Cleaned everything with brake cleaner
Started up the engine, immediately i had oil on the left side push rod tube
The engine run for almost an hour, right side still dry ??
And left side one or two drops on the floor
Most came out when i started the engine ?
Push rod tubes don’t leak …
Oil cooler ? Why oil on the right side ?
Upper side of the engine bone dry.
Now i let him sit for a couple of days
Any suggestions? |
