NCdad Samba Member
Joined: August 28, 2008 Posts: 1525 Location: South Carolina
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Wed Sep 30, 2015 8:34 am Post subject: |
Cool... congratulations!
Looks like Colin adjusted the side mirror for you.
Have fun with it ! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Sep 30, 2015 9:01 am Post subject: |
Dana Champion wrote: |
AHEM.... The Church of the Crooked Mirror resents that statement, as the OP's bus clearly has the mirror splayed in the "Check Out My Patina Not My Blind Spot" orientation.
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Wed Sep 30, 2015 9:27 am Post subject: |
asiab3 wrote: |
I don't know.... the mirror has since been adjusted from the picture on the dolly..... this mirror "club" is catching on !
Peace, my bruthas |
NCdad Samba Member
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed Sep 30, 2015 1:47 pm Post subject: |
asiab3 wrote: |
I tried it once and didn't like it. They have to be straight or I just feel weird inside! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Wed Sep 30, 2015 1:51 pm Post subject: |
NCdad wrote: |
Help on Engine number.
H 5039066
1500cc ? |
Sounds like a 1500 from a '67 bug. Of course, the piston spigots are the same size as a 1600, so it could be that. Or it could have been bored out larger. Not a lot of details there, so you might be better served looking for one or two oil pressure plunger plugs on the bottom left of the case. Regardless, it's a German case and if it holds oil pressure at operating temp, no need to worry about it.
NCdad Samba Member
Posted: Wed Sep 30, 2015 2:19 pm Post subject: |
asiab3 wrote: |
lol... Patina.
Thanks for the info on the engine...
tried to get some compression checked, put a battery in and nothing... starter looks to be shot.
got a used one from another bus, and will hopefully get moving forward on it tomorrow. _________________ ROBERT
My VWs & Projects - | - German Invasion VW Show - Sept 7, 2024 Shelby, NC |
NCdad Samba Member
Posted: Wed Sep 30, 2015 5:59 pm Post subject: |
What are your plans with your bus?....
More pictures would be cool.
I' m in the seventy club. Mine is same original color as yours, stock 1600 sp. Factory Eberspacher, Euro delivery. It spent late summer '70 traveling through Europe. Netherlands to Germany, Finland, Greece, before it was shipped to LA, Ca. Those are the service stamps in the book.
1970 is kinda an end of an era. It's the last year of 4 wheel drum brakes, and round VW hubcaps.
Peace |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Sep 30, 2015 7:40 pm Post subject: |
Peace |
1970 is the last year of the tough old boot VW buses.
Now that I have developed an understanding of non-power-assisted four wheel drum brakes hurtling down mountain passes with signs that say "8% grade, trucks shift down," I have to say that I appreciate the solid engineering of these brakes. Yes, they will fade. No, they do not grab the front wheels as readily as tippy toe power disk brakes, but they actually do have stopping power if you learn that they actually demand that you press that brake pedal like you mean it. 100 pounds of force at the pedal? heck yeah.
Mirror angles? Just to catch the road more fully . . .
_________________ www.itinerant-air-cooled.com |
NCdad Samba Member
NCdad Samba Member
Posted: Wed Sep 30, 2015 8:39 pm Post subject: |
Peace |
As of now, Running and stopping... Safety, fuel lines accelerator & Clutch cable replacement,
An opportunity presented itself as the seller had to many projects going on to work on this one... the offer came up and I took a chance.
I think so far I am pleased with what I have for the cost of it. _________________ ROBERT
Posted: Thu Oct 01, 2015 10:48 am Post subject: |
Good deals are hard to pass up. Looks like it's fairly complete, in need of some love. Here are a couple of shots of my 06/70.
My Buddies son Kyle, Sequoia 2003
work in progress in the engine compartment
Good to see your bus getting some new life |
NCdad Samba Member
Posted: Thu Oct 01, 2015 11:00 am Post subject: |
Found a starter in my parts box checked compression and ...
#1 - 70
#2 - 40
#3 - 0
#4 - 5
Guess motor will be coming out for refresh _________________ ROBERT
Tcash Samba Member
Posted: Thu Oct 01, 2015 12:08 pm Post subject: |
Make sure you adjust the valves first?
Good Luck
Tcash |
1967250s Samba Member
Posted: Thu Oct 01, 2015 7:53 pm Post subject: |
And check compression with carb open. _________________ '72 Elm Green Deluxe |
NCdad Samba Member
Posted: Thu Oct 01, 2015 9:43 pm Post subject: |
Tcash wrote: |
Good Luck
Tcash |
ya all were just a tad loose. none tight.
oh well, moving up to 1641cc _________________ ROBERT
NCdad Samba Member
Posted: Thu Oct 01, 2015 9:49 pm Post subject: |
Today I got the stuck passenger wheel drum off and can roll it around.
also since the compression was way low, time for a rebuild.
NCdad Samba Member
Posted: Mon Oct 05, 2015 10:36 am Post subject: |
Need some Help, or direction...
Am I able to move these wheels on my bug over to the bus with no problem?
Not sure what tires to go with, any suggestions, the wheels are 15's
current tires are cheap Nexxens,
thanks! _________________ ROBERT
