slalombuggy Samba Member
Posted: Thu Oct 01, 2015 6:15 pm Post subject: Big beef linkage |
Looking for a better linkage for my 51 EPCs. They sit on CB Bigbeef (TALL) manifolds and I run an alternator and CB breather box on the stand. I ungraded the rod ends but the cross bar sucks. Anyone run a center pull linkage with this combo?
brad |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu Oct 01, 2015 6:32 pm Post subject: |
BERG
It's worked for 30 years, 4 engines and 3 different carbs.
IDAs
Dells
_________________ Glenn
Member #1009
#BlueSquare |
mark tucker Samba Member
Posted: Thu Oct 01, 2015 7:21 pm Post subject: |
my std hexx empi cross bar works fine with my 44's & big beef's |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Fri Oct 02, 2015 11:28 am Post subject: |
I dont not like the HEX bar linkage either. I think it looks crap along with the berg and any other that obstructs the view of the fan shroud.
I have scat center pull with 44's on big beefs, not 51's though.
It took a few shims to get the right-side bar under the alternator, but it works fine. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri Oct 02, 2015 11:58 am Post subject: |
Any one that thinks bolting the linkage to the fan shroud (sheet metal) is a good idea has drank way too much berg tea. How many coils have you seen break off the shroud? Now it is a good idea to bolt a piece of angle iron from some rednecks garage to the shroud? _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Fri Oct 02, 2015 12:58 pm Post subject: |
I bought the Gene Berg Fanshroud mount linkage :http://www.geneberg.com/product_info.php?cPath=8_230_2837&products_id=825,
And the CB PErformance Hexbar linkage:
http://www.cbperformance.com/ProductDetails.asp?ProductCode=6480
And the CSP Bellcrank linkage:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C31%2D129%2D941%2D110
I didn't like the Hexbar system at all. Seemed like a sloppy bearing system for the arm. Also the CB Performance air cleaners will NOT accept a genuine K&N air filter.
I wasn't that impressed with the Berg geometry either. Any vibration of the fan housing is going to vibrate the linkage rods.
The CSP bellcrank linkage seemed to be the lesser of the evils, so that's the one I used. It's main flaw is that the carbs may not be synced well when the engine is cold.
However, I did have quality issues as the ball ends were NOT properly staked onto the carb linkage arms. I returned them a couple of times before I finally had them ship me a pair of threaded ball ends that I bolted to the carb arms and clearanced the threaded ends that extended beyond the nuts.
I also needed to install the CB Performance "Weblink Conversion Kit": http://www.cbperformance.com/ProductDetails.asp?ProductCode=6455
That had to be modified to fit. Here are the modification that I made:
http://www.thesamba.com/vw/forum/viewtopic.php?t=295815&highlight=weblink
I do need to add one more photo showing some additional clearancing that I needed to make to the Weblink arm.
So far it seems to be performing well.
However, I'd really like to see someone with 3-D CAD software do an analysis to see how well the the carbs are synced throughout the range.
Scott Novak |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Oct 02, 2015 2:35 pm Post subject: |
Ater installing the CSP bellcrank linkage on an engine with IDF's and an engine with IDA's I will never use any of that hex bar crap again. The 2276 in my Ghia has the CSP linkage with IDA's on Bugpack manifolds without any clearance issues. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Fri Oct 02, 2015 3:45 pm Post subject: Linkage |
mcmscott wrote: |
Any one that thinks bolting the linkage to the fan shroud (sheet metal) is a good idea has drank way too much berg tea. How many coils have you seen break off the shroud? Now it is a good idea to bolt a piece of angle iron from some rednecks garage to the shroud? |
X2 on that one!! Perfectly said. Not saying Berg linkage doesn't work, I just prefer a solid foundation like CB Linkage bolted solidly to Carb bases and rolling on Bruces Ball bearing kit. Silky Smooth and solid.
Jeff _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Glenn Mr. 010
Posted: Fri Oct 02, 2015 4:17 pm Post subject: Re: Linkage |
jpaull wrote: |
mcmscott wrote: |
Jeff |
And the engine doesn't get wider when it gets hot.
Over 350,000 miles with the Berg and never a problem or need to adjust. Also never had a coil come off, but then I only use OEM shrouds. _________________ Glenn
Member #1009
#BlueSquare |
jpaull Samba Member
Posted: Fri Oct 02, 2015 8:14 pm Post subject: Re: Linkage |
Glenn wrote: |
jpaull wrote: |
mcmscott wrote: |
Jeff |
And the engine doesn't get wider when it gets hot |
Yes true, that's why its nice that the CB linkage even with Bruce's ball bearing setup allow for expansion/contraction _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Posted: Fri Oct 02, 2015 9:26 pm Post subject: |
mark tucker wrote: |
I have used their linkage on 4 other sets of IDFs, but they must be making their new crossbars out of recycled beer cans without cleaning them first. The bar is very flexible
Thanks for all the input guys appreciate it.
brad |
jpaull Samba Member
Posted: Fri Oct 02, 2015 9:57 pm Post subject: |
Did you have aluminum crossbar? Mine came with steel crossbar and ordered for big beef manifolds. That thing is really strong. I do remember the aluminum ones in the old kits through. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
