cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Fri Oct 02, 2015 7:20 am Post subject: Broken digital clock LCD |
When we bought our rig, it came with a broken digital clock LCD. At no extra charge! I want to fix it.
Are the LCD or complete clock available? Would a VW dealer still carry them? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
cmayna Samba Member
Posted: Fri Oct 02, 2015 7:43 am Post subject: |
Yes it has power. You can read a partial of the segments but the rest of the screen (lcd) is blackened, which is a sign of the LCD being broken. _________________ '90 Westy / automatic.
Craig |
Zeitgeist 13 Samba Member
Posted: Fri Oct 02, 2015 8:06 am Post subject: |
Mk2 Golf/Jetta clocks are a direct bolt in, but the illumination has a slight greenish tinge to it _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
cmayna Samba Member
Posted: Fri Oct 02, 2015 8:12 am Post subject: |
Greenish tint is fine with me. Might give the Westy some character. What year golf or Jetta are we talking? _________________ '90 Westy / automatic.
Craig |
zak99B5 Samba Member
Joined: December 21, 2014 Posts: 471 Location: Albany, NY
Posted: Fri Oct 02, 2015 8:27 am Post subject: |
cmayna wrote: |
Greenish tint is fine with me. Might give the Westy some character. What year golf or Jetta are we talking? |
MkII G/J are 85-92. _________________ 1991 Tintop GL Manual tranny, EJ22 |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Fri Oct 02, 2015 10:32 am Post subject: |
I have one I’ll send you. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
bluebus86 Banned
Posted: Fri Oct 02, 2015 11:23 am Post subject: |
question:; I have yet to pull apart the clock (digital, 1986 van), but mine works except I cant set the time, the hour can be set but not the minutes, the switch to set minutes no longer works, it doe not respond to pressing.
if I were to open up the clock, are the little time set switches accessible for cleaning of the contacts?
has anyone repaired the time set switches before and has a procedure???
thanks
in advance
_________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Oct 02, 2015 11:28 am Post subject: |
The buttons used to set the time often get misaligned, which then leads to the symptoms you described. Pay close attention to how well the buttons move in and out. If they're cocked at all, they may not be making contact _________________ Casey--
y u rune klassik? |
cmayna Samba Member
Posted: Fri Oct 02, 2015 12:12 pm Post subject: |
Gnarlodious wrote: |
I have one I’ll send you. |
Think I found one locally, thanks _________________ '90 Westy / automatic.
Craig |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Fri Oct 02, 2015 12:23 pm Post subject: |
PM'd ya, Gnarlodious! _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
snwbrdr435 Samba Member
Joined: August 10, 2013 Posts: 337 Location: North Of Boston
Posted: Fri Oct 02, 2015 1:28 pm Post subject: |
I also have an extra as well if the other two ^ don't work out. |
msinabottle Samba Member
Posted: Fri Oct 02, 2015 9:28 pm Post subject: Minor Problem with Winston's Clock |
Winston's clock used to be the most accurate vehicular clock I'd ever encountered, is that no longer. Last year it started losing two minutes, then four minutes, then six minutes... It's up to eight, now, and it seems to go BACK to eight very quickly when I reset it.
Nothing has changed in Winston's electronic status, the clock hasn't been bumped or damaged--I suppose it just could have worn out. Any ideas? If 'replace the clock' is the answer, I'm open about where to get a new one.
I like that clock. I HAVE looked for a small modern clock that I could just stick over the display.
Posted: Fri Oct 02, 2015 9:37 pm Post subject: |
Most likely a capacitor is failing. Usually the first thing to fail on an electronic circuit. For older devices, routinely replace all the capacitors.
I have a radio controlled digital clock from the late 1990s that has worked well all these years. Never needs adjusting or setting for daylight savings. Unfortunately it is no longer made, and there is no such thing as a compact radio controlled clock for automotive. You would think there would be a huge market for such a device, but nobody makes one. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
PawelP Samba Member
Joined: October 25, 2015 Posts: 3 Location: Vancouver
Posted: Sun Oct 25, 2015 2:25 pm Post subject: Vanagon clock |
Does anyone still have Quartz clock for 1991 vanagon? Mine has black spots on the screen and display is out. I need to replace it. Thanks Pawel |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
PawelP Samba Member
Posted: Sun Oct 25, 2015 5:03 pm Post subject: |
95$ bucks is a little steep for my liking considering it is a 25 year old technology that may brake anytime. I was thinking more of a 10$ plus shipping unless there is something magic about those clocks that I am not aware of. |
BillWYellowstone Samba Member
Joined: July 16, 2011 Posts: 767 Location: Yellowstone NP
Posted: Sun Oct 25, 2015 6:20 pm Post subject: |
Too bad the kid from TX is moving to another country, I am sure he could whip something up.
What is special, the rareness of them I suppose. Watch eBay, never know what could turn up. _________________ Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round. |
cmayna Samba Member
Posted: Sun Oct 25, 2015 7:21 pm Post subject: |
PawelP wrote: |
$10???? LOL
I have an extra for $40 which includes first class postage. Let me know if interested. _________________ '90 Westy / automatic.
Craig |
