rmh60bug Volksrod Build
rmh60bug
rmh60bug is offline
PostPosted: Fri Oct 02, 2015 9:03 pm    Post subject: rmh60bug Volksrod Build Reply with quote
Been lurking for awhile on here. Found this on Craiglist for 1500, thought what the heck ! Boys and I need a project and this is it. PO had most of the hard work done. 2 40hp engines, split case trans, long spline long axle tran and a ton of parts came with it ! Uploading more pics. So far a drop spindle disc conversion, 12v flywheel machined to fit 40hp, using 68 transaxle, went thru engine ( fired right up ), lot more welding, wiring & everything else !!
rmh60bug
rmh60bug is offline
PostPosted: Fri Oct 02, 2015 9:26 pm    Post subject: Reply with quote
More Pics..... My teenage boys are workhorses on this ! Almost like they want to drive it. Hmmm could be problems in the future. Lol !
HALS
HALS is offline
PostPosted: Sat Oct 03, 2015 11:18 am    Post subject: Reply with quote
Looks like your off to a great start ...... did ya get kicked off volksrod.com ? HaHa. Rolling Eyes
"Leave it to girls to take all the fun out of sex discrimination."
rmh60bug
rmh60bug is offline
PostPosted: Wed Oct 07, 2015 5:10 am    Post subject: Reply with quote
Trans raise is enough the exhaust wouldn't fit. Had to cut & reweld. Hoping the header wrap will help with heat
rgdedge
rgdedge is offline
PostPosted: Wed Oct 07, 2015 3:26 pm    Post subject: Reply with quote
Good start and a nice job on the chop.
Tim
()o\|/o()
rmh60bug
rmh60bug is offline
PostPosted: Tue Oct 13, 2015 5:45 am    Post subject: Reply with quote
Thanks Tim !
Got the front end painted and brakes lines & master cylinder done. Now the pedal cluster and cables.
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Wed Oct 14, 2015 4:30 am    Post subject: Reply with quote
Good looking project and welcome to the Samba.
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
rmh60bug
rmh60bug is offline
PostPosted: Thu Oct 15, 2015 3:40 pm    Post subject: Reply with quote
Thanks Dan. I have been a lurker for awhile here. Just found the right project car to snag from Craigslist.
Will be busy awhile in the car welding up relief cuts. Haven't ran Mig on sheetmetal in a long time. Give me 1/8" or bigger any day ! Won't be perfect, but the boys and I are having fun.
rmh60bug
rmh60bug is offline
PostPosted: Fri Oct 16, 2015 1:44 pm    Post subject: Reply with quote
A little old school trick, thanks to a old hot rodder who stopped by. Instant rolled edge on clearance cut for steering box. 1/4 " brake line split with a die grinder. Take your time bending, rubber mallet & patience to get the fit right. Came out great !
rmh60bug
rmh60bug is offline
PostPosted: Sun Oct 18, 2015 3:44 pm    Post subject: Reply with quote
Rear deck lid chopped to fit and "rolled edge" tacked on. Just enough left to fill the gap between motor and body. Really cleans up the backend
1960 Volksrod in progress
40 Hp with 12v flywheel
6"chop, 5" drop, 10" ext
Slow & Steady is the key
sixfootdan
Samba Smartass
PostPosted: Mon Oct 19, 2015 7:10 am    Post subject: Reply with quote
Never thought of the brake line trick before, Thanks for sharing.
I could do the cutout in my hood. Cool
GO SEAHAWKS!!!
rmh60bug
rmh60bug is offline
PostPosted: Mon Oct 19, 2015 5:26 pm    Post subject: Reply with quote
No problem ! It's time consuming cutting and fitting, but worth it I think. Makes it just look smoother, not factory, but dang cool. Checked out your build pics. Nice Man ! Love the kegger tank with sight glass !!
rmh60bug
rmh60bug is offline
PostPosted: Wed Oct 28, 2015 6:37 pm    Post subject: Reply with quote
Worked on filling gaps from chop. Had to cut strips to fill in, then weld and grind them down. Came out better than I thought. Removed all headliner tabs, going to run just a top headliner & paint.
Looks better with no tabs.
rmh60bug
rmh60bug is offline
PostPosted: Fri Nov 06, 2015 10:30 am    Post subject: rmh60bug Volksrod Build Reply with quote
Bowden tube issues. The trans raise made the tube short, trip to the local hardware store solved it. Steel spacers welded together and a tight fit on tube. All good ! Used 2 washers to get the bend, not sure if it's too much or not enough. Any input is welcome.
rmh60bug
rmh60bug is offline
PostPosted: Fri Nov 13, 2015 5:27 pm    Post subject: Re: rmh60bug Volksrod Build Reply with quote
Lots to do in here. Bodywork on welds, rework back seat to fit trans raise, wire wheel pan, shifter linkage, soundproofing. The list goes on !
rmh60bug
rmh60bug is offline
PostPosted: Wed Nov 18, 2015 10:01 pm    Post subject: Re: rmh60bug Volksrod Build Reply with quote
50+ trim holes to fill. What to do, hide them or make them stand out. Stainless button head bolts & washers. The pics don't do it justice. Will use these bolts in other places to tie it together.
sixfootdan
Samba Smartass
PostPosted: Thu Nov 19, 2015 6:50 am    Post subject: Re: rmh60bug Volksrod Build Reply with quote
I did 1/4-20 stainless bolts with acorn nuts.
GO SEAHAWKS!!!
rmh60bug
rmh60bug is offline
PostPosted: Mon Mar 28, 2016 6:43 pm    Post subject: Re: rmh60bug Volksrod Build Reply with quote
Back at it ! Finally warmed up here in Northeast PA ! Deck lid mounted, clutch and throttle cables hooked up. Pedal cluster all done. Next up bleed the brakes, and wiring harness. Getting closer ! Slow & Steady
rmh60bug
rmh60bug is offline
PostPosted: Wed Mar 30, 2016 4:05 pm    Post subject: Re: rmh60bug Volksrod Build Reply with quote
Used brake line and heavy pex tubing for throttle tube from tunnel to shroud. The trans raise throws off the angle from tunnel tube. Got the pex on tunnel tube about 2", gap between them is only 1/4". Then used a hose clamp at shroud to hold it all from moving.
rmh60bug
rmh60bug is offline
PostPosted: Tue Apr 05, 2016 7:42 pm    Post subject: Re: rmh60bug Volksrod Build Reply with quote
Looking for a hand crank nut for the volksrod. If it will even work on a 40 HP. The boys saw a vid of hand cranking a VW and thought it would be "cool" for ours. Will it work ? Anyone have one ?
Also I have gone over the samba, volksrod, and the web many times. Would like first hand knowledge of what air shocks work on a link pin bug. I have it narrowed done to Monroe MA824 or 803 for front, MA785 or 768 for rear. Not looking to "slam" it, just level and adjust for ride. Will be running independent lines to all four corners, no roll in the corners ! Thanks
Page 1 of 7
