Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Mon Oct 05, 2015 4:18 pm Post subject: A word of caution on paper air cleaner elements. |
Many of the cheaper air cleaners come with paper elements, not K&N style cloth elements. Your engines could see a shorter lifespan due to this. My experience is a little different then most, but it can also affect your engines as well. In my configuration, I have a very short intake tract. That coupled with the cam overlap is giving me times of intake stand off under certain conditions. The car is definitely drivable, but I will be working to remedy this condition in the next few days.
However, I took the car on a 300 mile road trip last weekend. When I pulled off the air cleaners to do some jetting, there was major damage to the air cleaner elements. I found multiple holes in the elements that were the diameter of a pencil's lead. This means that you can be sucking in all kinds of dirt and other items into the engine. What I believe has happened, is that the standoff makes the element wet. Then the intake suction is actually pulling loose pieces of the element.
Most of you will not have this situation, but if your engine is coughing back through the carbs, it will probably end up with the same damage as I have found, just take a little longer. So if you have the paper elements, keep an eye on them. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Mon Oct 05, 2015 4:46 pm Post subject: |
I had zero trouble with paper filters, save for they don't like water. 7 1/4 spectre brand cheapos. The aircleaner bases I made for them had 2" velocity stacks UNDER the level of the filter so standoff was not a problem. I do not know what kind of junk you have bought, I've never seen any paper filters sold in a bubblepack so...... what did you do???LOL |
LivinInnaVWBus Samba Member
Posted: Mon Oct 05, 2015 5:29 pm Post subject: |
Paper elements are typically much more restrictive, but also much more effective than the K&N style oil filters.
The company I work for is a K&N dealer, I can get the stuff at cost but choose not to. K&N isn't all it's cracked up to be but I field calls all day long from people brainwashed by the ads.
Your oil will get dirty much quicker, you'll likely lose fuel economy(rather than gain, as they claim), the oil can contaminate 02/MAF sensors AND they can cause you to rebuild your carb sooner... all for a power gain most never notice. |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Oct 05, 2015 7:24 pm Post subject: |
In '73 VW went to paper filters which had been the norm for most other manufactures for at least 10 years prior.
VW used the same size filter on Beetles, Rabbits, Dashers, and what ever else they where making from 73 till the mid 80's
If K & N was that great, then you'd see it on a vehicles from the factory.
I put a K&N on my '99 New Beetle, no more than 3 months later the MAFS died, VW replaced free, the second time the MAS died, again VW replaced for free, and I got rid of the K&N.
Never had another MAFS fail again.
It's better to just run the OG VW filter system you have. _________________ Good Luck
Al |
Posted: Mon Oct 05, 2015 7:42 pm Post subject: |
modok wrote: |
Lets just say that the name brand began with an E. I know, I know, but they were cheap and they had the style of housing that I wanted. They were just something to get me on the road quick, with the understanding that I would be changing out the elements as soon as I got my intake configuration right. For me clearances are extremely tight (Type 4 in Squareback), and until, I knew what was needed, I wasn't going to drop serious coin on what might not work. _________________ 69 road Bug 2110
My builds
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon Oct 05, 2015 10:12 pm Post subject: |
If any of you guys are using one of those 6 3/8" - 6 1/2" cheap chrome filters on you stock Solex's I found this filter fit my housing perfect, and its taller then the one that came stock.
http://www.speedwaymotors.com/Replacement-Washable...34084.html
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
mark tucker Samba Member
Posted: Tue Oct 06, 2015 9:50 am Post subject: |
LivinInnaVWBus wrote: |
WRONG, most paper elements flow very well when there new,and throught thier usable life span, but dont last and cant be washed out. the k&n flow very good and are washable, but they flow after washed is reduced quite a bit. and your talking about oil filters and the post is about air filters.
everything has a life span, it's up to you to figure out what yours is....or not.
Ive seen somany air filters with holes wore into them from something rubbing the filter . the idf stuff is real bad about it as the stacks eat away at the filter at each end. I reshape my stacks for clearance running and when removing the filters. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Tue Oct 06, 2015 11:39 am Post subject: |
I have done a dyno test comparing no filter/Genuine K&N/stock type paper filter.
Actually, there was no measureable difference in power between the three.
I know from my own experience that the K&N lets fine sand through.
Papers do not.
Test was done on a 300+ hp turbo engine.
I will not let K&N near an engine I care about. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Oct 06, 2015 12:27 pm Post subject: |
I use the VW of mexico style air cleaner (or late 73'-75' carb plastic air cleaner)
Works fine.
As you can see Amsoil paper air filters are the best, (but expensive) So I use Napa Gold air filters.
You can see the "high flow" K&N is really high flow, however it does let a ton more particles in.
Very interesting article to read.
http://www.gmtruckcentral.com/articles/air-filter-study.html
_________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
nextgen Samba Member
Joined: August 19, 2004 Posts: 6027 Location: CONGERS, N.Y.
As Mulit69 pointed out this is performance NG. Yes Paper flows great stock. But for some of our engines you will need a very big filter to flow the air our engines need. Again it is a balance big paper filters and change them in a timely manner. If you are not a sand buggy, clean and oil your K&N filters regularly you will not have a problem.
Something I never told anyone. I have the same K&N filters on my bug since 1990 and moved them from car to car. The bug I have now has them on it for over 120k the engine is T-4 914. The only problem I have is the rubber on the top and bottom of each filther, is no longer soft. I is like steel, I have to use foam gaskets top and bottom of each one.
_________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Tue Oct 06, 2015 2:51 pm Post subject: |
I'm pretty sure the stock 1600 paperfilter flows enough for 300 hp.
Not the plastic housing though. Those are almost always a restriction on every car I modified.
The only reason to use a K&N air filter would be that they look cool. And cool won't bring you home. Much like chrome. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
Posted: Tue Oct 06, 2015 4:48 pm Post subject: |
I have the china k&n..kang&nong?? that came with my empi hpmx crabs, Ive always ran the prefilters on them so they stay clean, back in the old days when I ran duell 4 bbls on tunnel ram sticking out of the hood I used paper elements, they were about $4 each and got changed every 2 months.
for my bug the kang&nong work as fine as frogs hair. Ive had a new set of k&n's for about 4 years on the shelf,but...not untill I need them, I also have the king kong filters for someday....Im still awaiting for the calander that has someday on it. |
jsturtlebuggy Samba Member
Posted: Tue Oct 06, 2015 9:30 pm Post subject: |
R2C filters are working for me. I have one on my Subaru Manxter and on my VW powered buggy. Pacific Customs sell a larger variety of sizes and shapes. Also Speedway Motors carries the 14in round ones.
I no longer have silt on my throttle plate the K&N was allowing to get through. They do discolor with age. I also cover them with Outwears. They can be blown out with low psi compressed air.
_________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Wed Oct 07, 2015 3:40 am Post subject: |
Everything I have ever read says that paper filters are more effective.
K&N where built with high flow in mind first and filtering ability second as an improvement for street racers who where going with no filters at all previously.
I think they are little more than a gimmick for normal driving.
Yes, you can wash them but for the price of one K&N you can buy dozens of paper filters, enough to last you many years, and give your engine better protection to boot.
Every new car on the market comes with paper filters, I refuse to believe that that new cars costing tens of thousands of dollars are designed around paper filters in order to save a $100 bucks.
It sounds to me like the OP doesn't have a paper filter problem,he has an intake design problem.
It also makes no sense that a 'wet' filter would weaken as paper filters are not made from water or gasoline soluble paper. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Oct 07, 2015 1:00 pm Post subject: |
Aerindel wrote: |
It also makes no sense that a 'wet' filter would weaken as paper filters are not made from water or gasoline soluble paper. |
For a stock set up? yes. But getting paper filters isn't as easy when it comes to after market set ups. |
Posted: Wed Oct 07, 2015 1:47 pm Post subject: |
Aerindel wrote: |
As I admitted, I do have an intake problem that I am sorting out. Having fuel stand off or inversion is never a desirable condition. The majority of engines do not have this problem due to the length of the intake runners. However, when the carbs are only about 2" above the heads, and you factor in valve overlap, that creates issues that fall out of the norm.
As far as paper loosing its integrity when wet: find ANY paper you like, then apply ANY type of wetting agent, and the papers integrity goes out the window. Put a socket in the middle of a paper towel and lift it, then dip the center of the towel in gas. Will it still lift the socket, nope. A large engine is like a vacuum cleaner, at any reasonable RPM it is sucking in a very large CFM of air. If the integrity of the filter medium (especially paper) is compromised, and is in close proximity to the vacuum source, you will start to pull it apart. _________________ 69 road Bug 2110
My builds
I Ride Sand Samba Member
Posted: Wed Oct 07, 2015 4:16 pm Post subject: |
Multi69s wrote: |
Aerindel wrote: |
As far as paper loosing its integrity when wet: find ANY paper you like, then apply ANY type of wetting agent, and the papers integrity goes out the window. Put a socket in the middle of a paper towel and lift it, then dip the center of the towel in gas. Will it still lift the socket, nope. A large engine is like a vacuum cleaner, at any reasonable RPM it is sucking in a very large CFM of air. If the integrity of the filter medium (especially paper) is compromised, and is in close proximity to the vacuum source, you will start to pull it apart. |
go get a piece of printer paper, soak it in acetone and compare it to a dry one. the glue is not affected by some solvents while others will degrade it. paper filaments are the same. the only thing that happens when they get wet is the get restrictive. i the filaments are known to be exposed to some water (mist off of tires gets to almost any filter) and fuel is also likely, so they design the filament accordingly. |
modok Samba Member
Posted: Wed Oct 07, 2015 4:27 pm Post subject: |
Good possibility it is an exhaust tuning problem. Collector ID bigger than 2"??
yeah, wet paper does not flow!! Paper swells and absorbs water but synthetic materials do not, and so why aren't we using synthetics???
I have the r2c filters on now, seeing how they hold up to the fuel fog, so far, good! |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Wed Oct 07, 2015 5:43 pm Post subject: |
The first time I read about fuel fog standoff was in Bill Fisher's How to Hotrod VW motors. At that time I owned 2 VWs - one bone stock 68 deluxe bug and a 64 deluxe bug. The 64 was my 'test bed' for modifying both cars. What worked on the 64 was transfered over to the 68 - the wife's dd. I had a stock 1500 single port in the 64 and decided to use an after market air cleaner since they look better than the oil bath cleaner. And the oil bath was a PITA to clean and refill - I'm a lazy man! I noticed almost immediately the paper filter wasn't holding up - it began to get holes in the filter. I went back to the stock filter. Maybe a year later I bought Fisher's book - after reading that section where he outlined the fuel fog problem I understood why that paper filter was falling apart. It did smell like gas.
Fisher mentions that all the VW air cleaner designs have a built in fuel fog containment to them. With those fancy little air cleaners all a guy needs to do to contain the fog and prevent possible lean condition is to add a 2-3" piece of pipe - metal or plastic (fuel friendly) to raise the paper filter up and away from the fog.
Even long manifold IDF/HPMX setups such as I have are not immune to fuel fog standoff. EMPI has several videos on youtube showcasing their carb's performance. A couple of those clearly show the fuel fog hanging over the tops of the carbs when the motors are pulling hard on the dyno - even with the velocity stacks - which I always run with.
I've mentioned this to guys that have paper filters on their motors where there is no area for fuel fog containment - I usually get <crickets> in response. Oh well - live and learn.
Anyone know where I can get paper filters for 44 HPMX/IDF carbs? _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
