danfromsyr Samba Member
Posted: Mon Nov 07, 2016 12:53 pm Post subject: Re: Webasto Gas Heater Install |
Soo if you have to change your PS rear tire you have to crawl/reach under and undo the exhaust from the muffler? that seems like it would be mighty inconvenient in a roadside emergency in the rain or such..
you could just wire tie it beside the jack port.
owokie wrote: |
I have mine mounted in the same location and exhaust is a nonissue, even with the door open for a minute or two. You might try it this way before you go through the trouble. The intake also matches that small stock hole next to the frame rail for an interference fit and prevents entry of large debris. Not that it matters at this point, but there is plenty of air flow without extra holes under the rear seat. How else would the stock rear heater work?
Noise from the unit itself in that location isn't an issue, but I still haven't completely silenced that damn dosing pump. A minor nuisance, but you'd think for the price of these things they'd have come up with a better solution. Still love having it though...
Abscate wrote: |
owokie Samba Member
Posted: Mon Nov 07, 2016 1:38 pm Post subject: Re: Webasto Gas Heater Install |
Good catch. I don't have or use the stock jack and can still use that stock jack point from below. Also, this location is slightly more to the rear than where most people put it (wired just in front) thus nearly eliminating exhaust entry into the open sliding door. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Tue Nov 08, 2016 10:49 am Post subject: Re: Webasto Gas Heater Install |
This seems like a pretty ideal location for the controller. You have to trim just the smallest amount off the ashtray opening to fit the controller.
This is what I did with the fuel pump this time. I would like to find a full box cover for it
The exhaust routes nicely through the frame and out the back.
OK this foam enclosure was stupid. If you don't do something to block the noise at both ends of the heater, all the noise just goes out the open end. This does quiet the output end but the overall noise level isn't much lower until I do something on the intake side. I'll have to redo this whole thing. The foam seems to handle the heat o.k. but the hard plastic grill is deforming so it will probably get replaced by a metal grill.
Posted: Wed Oct 18, 2017 8:31 pm Post subject: Re: Webasto Gas Heater Install |
So, I put this Webasto 3900 gas heater in 2 years ago and tweaked several things to make it quieter. It has been good and hasn't caused any major issues, but this year I started getting low battery faults where the heater won't restart. If I start the engine, it fires right up.
I am going to upgrade the wiring and redoi the connections and maybe repace the battery. I think I originally used 10 guage wire which is supposed to handle 22 amps but maybe I am getting some voltage drop anyway. I ordered 6 guage wire and will make sure the connections are super solid.
I have watched when I get the fault. I have a voltmeter plugged into a socket near the battery and it reads about 11.4 volts when the heater stops and gives a low voltage fault. The heater fault is triggered when the voltage drops below 10.5 volts at the ECU for more than 20 seconds. So unless the heater is misreading the voltage, I am getting a pretty big voltage drop from the battery. The wiring runs from under the driver seat to the heater under the rear bench.
11.4 sounds like a really low battery but voltage drops significantly at the battery during the glow plug heating/startup process And the heater is so powerful that it shuts down and needs to restart a fair amount in fall weather. In hindsight, this is the wrong model for a vanagon. After the heater has been running for 8 hours the battery reads 11.4 but will come back up to 12.2 volts or so after it sits for a bit. So basically the heater currently shuts off at 12.2 volts which I think is kind of crappy. But keep in mind this is just using the house battery. I can connect them both together to get a longer run than 8 hours. But hopefully the rewiring helps a bunch. That is one complaint a lot of people have about these heaters with the glow plug.
Another thing that may be in play here. I am just using a group 41 battery for my aux battery. I don't know if it has been depleted too much too often and is not doing as well as it did 2 years ago when it was new. It still seems to charge up to 12.65 volts. I may get a group 65 AGM battery for the house battery now but then they won't be matched batteries so I would not run them combined. 2 AGM batteries might be a solution to that, but then we're talking 300-400 bucks.
I would be interested if anyone else has had similar issues, or has comments about the wiring or the battery(ies). |
jordauto Samba Member
Joined: August 12, 2011 Posts: 218 Location: Sorrento,BC
Posted: Wed Oct 18, 2017 9:56 pm Post subject: Re: Webasto Gas Heater Install |
You should easily be able to run 30+ amps through your 10ga wire to your heater. The glow phase at start up of my Espar B1LC is only about 20 amps for 15 seconds and I assume a Webasto is about the same. . If it were mine I would use a multi meter and check voltage drop on both your power feed and ground, from the heater to the battery terminals. Basically connect one lead of your multi meter to the positive post, and the other end to the connector at the heater. Check for voltage drop with the furnace starting up. I would hope to see no more than .1 voltage drop. Then repeat the process on the negative side of your circuit. It sounds like your battery has enough power but you’re losing some to high resistance somewhere in your circuit. Also some of those plug in battery meters are pretty inaccurate. Check your actual battery voltage at start up with a multi meter as well. I love my Espar, having it draw fuel from the tank means almost unlimited heat. My unit is smalller in btu than yours so it gets up to the target temperature and then slows right down to an idle. Which makes it very quiet and uses little power. |
Posted: Thu Oct 19, 2017 10:11 am Post subject: Re: Webasto Gas Heater Install |
That is a good suggestion before I just throw parts at it. I'll have to strip off some of the insulation at the wire near the heater so I can read the voltage closer to the ECU but I might as well do that before I rewire it with the heavier gauge. It should tell me something.
[edit] I'll have to spend some more time on this. The 6 gauge wire I ordered is way overkill, but I am seeing a voltage drop with the 10 gauge but it could be a connection rather than the wiring. I'll redo it and see how it goes. |
Posted: Sun Oct 22, 2017 10:12 am Post subject: Re: Webasto Gas Heater Install |
I am beginning to think that there is nothing wrong with the heater or the install except my expectations. I did rewire it adding 8 gauge wire (and kept the existing 10 gauge) and I made sure the connections were good. There is now no detectable voltage drop now from the battery to the heater but it still shuts down with a low voltage fault using my partially flattened house to test with. It is just a Autocraft grp 41 starting battery that I am using as the house battery, which I had hoped would be sufficient but may not be.
I watched the voltage at the battery drop from 12.3 to 10 volts before the heater faulted. So I think the battery is just not as strong as it was when new. Fully charged it will run the heater for 8 hours but when it was new it seemed to do better. Bringing it down to 50% each time I use the heater may have damaged it. Even though I haven't really used the heater that much.
These heaters just uses a lot of power at start up and trip the low voltage fault. I don't think there is any internal crude causing resistance because the heater is still pretty new with low hours. And many posts online complain that these heaters just need a very good battery supply. Webasto changed the low voltage shutoff from 10.5 to 9.5 volts on the new model, so they must have recognized the heaters are temperamental.
I am doing some more testing with a spare battery, but I will probably have to buy an AGM Battery and Yandina Combiner so that I can run it down wiithout damaging it. |
owokie Samba Member
Posted: Sun Oct 22, 2017 11:44 am Post subject: Re: Webasto Gas Heater Install |
davevickery wrote: |
OR bite the bullet and go with LifePO like I'll probably do when this 41 craps out. FWIW, I got about a year out of the last one running an Espar and TF49 ie. used heavily. For $80, for me, that's a win. But something like this: https://www.bioennopower.com/collections/12v-serie...-sealed-ws or this: https://starkpower.com/product/12-volt-50ah-battery is appealing. 50AH, almost all of that usable at ~15# in the stock space? Yes please. |
Posted: Sun Oct 22, 2017 5:50 pm Post subject: Re: Webasto Gas Heater Install |
owokie wrote: |
OR bite the bullet and go with LifePO |
The low voltage cutout would trip long before the battery got close to 100% depleted so an AGM battery probably makes more sense.
I'm looking at this one. It is $155 on sale with free in store pickup so not a lot more than a regular battery. I would tip it on it's side under the driver seat and the terminals will be facing forward (I don't have a swivel on the driver side so I think it will fit). It is around 70 Amp hours and has great ratings.
http://www.sears.com/diehard-advanced-gold-agm-battery-group-size-65/p-02850765000P
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
Posted: Mon Oct 23, 2017 6:52 am Post subject: Re: Webasto Gas Heater Install |
The low voltage cutout would trip long before the battery got close to 100% depleted so an AGM battery probably makes more sense. |
I think the Low Voltage cutoff on the fridge is at 11.2v... with that being said it looks like the Stark batteries can maintain 12.0v til about 80% discharge and hits 11.2v somewhere in the 90% range. Wow. Pretty impressive.
I did not know about these batteries. I currently have three 44ah batteries (29lbs each compared to 17lbs) which are about 4 years old. They're definitely going to be replaced with these Lithium-ion batteries! Thanks for the heads up!
Discharge chart taken from Stark Batteries website.
_________________ Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now |
Posted: Mon Oct 23, 2017 7:02 am Post subject: Re: Webasto Gas Heater Install |
I'm looking at this one. It is $155 on sale with free in store pickup so not a lot more than a regular battery. It is around 70 Amp hours and has great ratings. |
AGM's should not be discharged more that 50% so that means you have about 35ah usable capacity in a 46lb battery. I think these starter batteries are great for high amp discharge like turning a vehicle over etc but I usually don't recommend them as an aux battery solution....
Just my opinion... I usually prefer SLA batteries... _________________ Abel Longoria
