Turksandcaicos Samba Member
Joined: October 23, 2012 Posts: 27 Location: Colorado
curtis4085 Samba Member
Posted: Tue Oct 13, 2015 6:20 am Post subject: |
It's as close as it gets to OG. One of the guys on here has a wonderful thread on redoing his cabinets with it. I think his thread is in the FAQ _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Tue Oct 13, 2015 6:24 am Post subject: |
I didn't see it in FAQ. His user name is eche if I recall. He will be along soon I'm sure. _________________ Special Thanks to:
Tcash Samba Member
eche_bus Samba Member
Posted: Wed Oct 14, 2015 9:35 pm Post subject: |
The laminate panels I bought from NLA VW were the ones that are backed by birch plywood that mount on the walls. For refinishing my cabinets, I used original old laminate graciously donated by a fellow Samba member.
A review from when I first bought the panels:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7274474#7274474
A link inside my build thread showing the panels. Skim forward to see installation.
http://www.thesamba.com/vw/forum/viewtopic.php?p=7274484#7274484
NLA VW sells the raw laminate too - same as the wall panels, just without the plywood backing, for use on the cabinets. If you're going to replace all the laminate on all your cabinets, it'll work great as it has exactly the same grain and knots as OG, and the color tone is fairly close, too. If you're going to just replace a panel here and there, you'll likely see the shade will not quite match your other panels. That said, it is without a doubt the best option out there, as any other currently available laminate will neither match OG in color or in grain.
They have an ad in the classifieds here for the wall panels (hey, that's my toe!). http://www.thesamba.com/vw/classifieds/detail.php?id=1691744
Would recommend. |
jtchristopher Samba Member
Joined: July 07, 2011 Posts: 55 Location: Ortonville, MI
Posted: Mon Nov 30, 2015 4:02 pm Post subject: Re: UK NLA Laminiate |
Laminate Construction
Despite the fact that plastic laminate manufacturers frequently introduce new products, I seriously doubt we will ever find a contemporary match for the plastic laminate found in a Westy interior. For the more exacting – you are faced with complete delamination and replacement with similar materials. For the less demanding – you are faced with selective delamination of your damaged panel and replacement of the laminate.
Recently, December 2015, I purchased a top cabinet typical of a ’77 – ’79 interior for introduction into our ’75 Westy. Although structurally sound, the rear piece of laminate was brittle and fractured in an attempt to repair its loose fit; similarly, the bottom piece of laminate was missing in its entirety.
I lean toward the exacting type of decision maker; however, my mindset in this instance was to secure the best match for an isolated piece of laminate where I felt a very close match would be hardly noticed. Remember, too, the upper cabinet lies adjacent the closet. The top piece repair represents the only side-by-side comparison to existing – yet the comparison is on predominantly different planes making it relatively easy for the eye to “understand” a slightly different color. The bottom panel is framed in black, plastic t-molding making that comparison, also in a different plan, extremely difficult to discriminate. These factors, coupled with a flawless front panel, contributed to the decision to replace isolated pieces.
Obviously laminate color / graining was the basis for selection. Below, ranked in descending order, are subjective best match to original laminate construction recommendations:
Manufacturer Product Name / Number
Pionite Afternoon Showers / HP 360 (Suede)
Nevamar Vantage Point Walnut / WW0013N
Arborite Spiced Walnut / W-417-FP
Arborite Pecan Tekka / W-430-VL
BTW, all of these lack the faux knots. The Pionite and Nevamar are clear choices – the Pionite is a virtual duplicate in terms of color match for my application.
Perimeter Panel Construction
For this narrative, perimeter panel construction is meant to include the approximate 3/16-thick plywood and presumably vinyl faux wood grained pieces found behind the driver’s side cabinetry and adjacent the rear seat; on central body of the sliding door; adjacent the rear seat on the passenger side; and, the central body of the rear lift gate.
In my opinion, replacement of these pieces in like kind and quality was insane in light of the fact that we use our bus for its intended purpose. In use, replacement panels of wood veneer, plywood or plastic laminate would soon mimic the existing materials – rendered visually distressed by virtue of the numerous scratches and holes from many years of use.
InPro Corporation manufactures a highly maintenance resistant alternative to the interior panels. IPC rigid sheet provides significant protection for vertical, high-traffic, areas; it is durable, long lasting and easy to clean. As an example of a typical use – you’ll often notice this type of material in hospital or loading dock hallways where impact with equipment is likely and frequent and long lasting appearance is important.
If you migrate to IPC’s website locate the Woodland Faux – Wood Patterns. I selected Amber Cherry for use in fabrication of the interior panels. The decision to use this color / pattern was based on the observation that our original, wood perimeter panels were far from an exact match in comparison to the adjacent plastic laminate construction of the cabinetry.
Of particular importance to our application as bus owners is the fact the plastic material is colored through the entire thickness of the panel. You can score this material with a razor blade and hardly notice the cut – its intended use is a perfect application for our high use, close-quartered buses where impact and scrapping is an expected consequence of use. You’ll find the material richer in color than the original and the Amber Cherry works well with the existing laminates in terms of color and graining. IPC offers free samples and these can be order through migration on its website.
My decisions in “restoring” our bus are based upon improvement on the concept --- using contemporary technology and materials is a logical extension of that premise. The introduction of IPC panel just makes great sense for continued use….
I hope this helps all of you in your efforts to rejuvenate the interior of your buses. _________________ 1975 Campmobile; Brilliant Orange (Celeste)
1986 Vanagon Camper; (Clark)
1995 Eurovan Camper; White (Edgar) |
trevorbrady Samba Member
Posted: Mon Nov 30, 2015 4:44 pm Post subject: Re: UK NLA Laminiate |
reprowesty.com in The Netherlands also sell laminate and panels.
I haven't checked them against NLA but the prices may be better? I haven't bought from either NLA or reprowesty so I can't vouch for quality of either, just suggesting another source |
Posted: Mon Nov 30, 2015 7:57 pm Post subject: Re: UK NLA Laminiate |
Never heard of the supplier in the Netherlands before. Thanks for the information. _________________ 1975 Campmobile; Brilliant Orange (Celeste)
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Bleyseng Samba Member
Posted: Tue Dec 01, 2015 8:30 am Post subject: Re: UK NLA Laminiate |
I will try to visit reprowesty this trip and check em out. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Mon Oct 22, 2018 3:34 pm Post subject: Re: UK NLA Laminiate |
My NLA interior kit has been fantastic till I changed climates. I guess the humid, wet PNW kept these panels happy. After moving to San Diego, within the month my sliding door panel potato chipped. I would fix it but it also cracked. It flexed so bad that I couldnt open the slider. These pics are after I soaked it in the pool for half the day and had weight on it for the other half to flatten.
I know there were others with this issue? I only remember conversation not pics.
So Ill be dropping another $150 on Bus depots which Im sure is the same vendor source as NLA.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Magion Samba Member
Joined: February 15, 2016 Posts: 236 Location: Vancouver, BC
Posted: Mon Oct 22, 2018 3:46 pm Post subject: Re: UK NLA Laminiate |
Unfortunately I have to second that. Bought Rear hatch panel from NLA VW - great fit and you would not know the difference but as soon as the humidity changes the panel flexes too _________________ 1975 Westfalia in Brilliant Orange
1995 Westfalia in Caribbean Green |
tommu Samba Member
Posted: Mon Oct 22, 2018 10:54 pm Post subject: Re: UK NLA Laminiate |
I'm glad you both posted this. I had several replacement panels sent to me from NLA and we couldn't figure out why they were warping so much. It's good to know that they do stay straight in a climate similar to the UK. _________________ |
Hoody Samba Member
Posted: Tue Oct 23, 2018 5:54 am Post subject: Re: UK NLA Laminiate |
I have not seen these panels in person. I am wondering if they are sealed on the back side like the originals were. My guess is that they are not. Westfalia used a vinyl covering. If you don’t seal them with several coats of sealer this is what will happen. There is also the misconception that contact cement should be used to adhere the laminate to the wood. I am not sure who came up with this concept but it’s incorrect. Contact cement does not hold up to moisture, heat or ozone. And it creates a nightmare to fix. You should be using a waterproof heavy duty wood glue like Titebond 3 ultimate. Westfalia used contact cement to adhere the vinyl and rubber in Westys. Not the laminate. |
tommu Samba Member
Posted: Tue Oct 23, 2018 12:31 pm Post subject: Re: UK NLA Laminiate |
Hoody wrote: |
Sealed but not with vinyl. Looks like some kind of varnish to me. My sliding door panel is warped so much it's almost a tube. _________________ |
Posted: Tue Oct 23, 2018 3:00 pm Post subject: Re: UK NLA Laminiate |
tommu wrote: |
Hoody wrote: |
Sealed but not with vinyl. Looks like some kind of varnish to me. My sliding door panel is warped so much it's almost a tube. |
Yep thats what this one looked like. Serious tubage. Then I threw it in the pool. _________________
t3kg wrote: |
1964 1500 S
RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Posted: Wed Oct 24, 2018 11:45 am Post subject: Re: UK NLA Laminiate |
I had that issue with my sliding door panel too. We had a text conversation about it. I was able to get Bus Depot to replace it - they worked with NLA VW - and the new one was better, but does show some signs of warping after installation.
My advice to remedy it? Thoroughly wet the plywood backing until it won't soak up any more water, then lay it out to dry with some weight on it. Repeat as necessary to get it laying flat, THEN seal it. This will allow the wood fibers to relax in a flat position and the sealing will minimize the change in moisture content of the panel. _________________ Andrew
Oscar: 1976 Westfalia Deluxe Camper, 2.0L FI, Manual Transaxle |
1970fun Samba Member
Posted: Wed Oct 24, 2018 12:31 pm Post subject: Re: UK NLA Laminiate |
The only remedy for not warping these panels is to glue some laminate from the same thickness at the back of the panel!
There has to be a uneven number of layers to prevent warping that’s why plywood always have a uneven number of layers no matter the thickness. |
Posted: Wed Oct 24, 2018 2:16 pm Post subject: Re: UK NLA Laminiate |
Well Im assed out and have to buy a new one anyway with the crack. I bought this like 4 years ago when NLA was the only vendor. _________________
t3kg wrote: |
1964 1500 S
