junichi Samba Member
Joined: September 12, 2005 Posts: 749 Location: brentwood bay, bc
Posted: Sat Sep 09, 2017 7:12 pm Post subject: Re: 1964 Light Grey Kombi |
Thanks, Dubskii. I wish mine was a 57 too!
Your paint stripping inspired me to do a bit more today. It sure what the bright yellow is but it's on there pretty good!
I am surprised how beige the "light grey" is. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
Posted: Mon Sep 11, 2017 9:16 pm Post subject: Re: 1964 Light Grey Kombi |
Here is a better look and unfortunately there is not much light grey in here. The main light beigy colour is bondo. I should have known this was there as I can actually see the dent from inside
The rear cargo door is bad too. For now I think I will put this on hold and get back to welding. This will have to get fixed eventually. I may try a few test patches on the other side, which looks more promising.
Posted: Mon Sep 11, 2017 11:57 pm Post subject: Re: 1964 Light Grey Kombi |
I should be sleeping but I couldn't resist a little more investigation. It looks promising as I get past the damaged area...
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
Posted: Tue Sep 12, 2017 7:16 am Post subject: Re: 1964 Light Grey Kombi |
Just read the whole thread and thanks for all the detail. I'll be doing a lot of the same stuff so I appreciate your help! Great bus!
byron _________________ 1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
Posted: Tue Sep 12, 2017 7:57 am Post subject: Re: 1964 Light Grey Kombi |
Thanks and good luck with your project! _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Sun Sep 24, 2017 8:36 pm Post subject: Re: 1964 Light Grey Kombi |
Out and about today. Still running a bit off and wants to stall intermittently, but I don't want to mess with it as it's running the best it's been.
Posted: Wed Nov 15, 2017 6:09 pm Post subject: Summer is over |
So we had a great and long summer here and I got to drive and enjoy the bus a bit with my family. Just a few shirt trips since I am still working out the mechanical bugs and much of the metal work is still incomplete.
Insurance expired in October but I have not been very motivated. Did a little on my boat resto project but not much, and nothing with the bus. Now the rain is here...
Got a little motivation and started welding up my floor patches.
I have to seam weld the length of the cargo floor 4 times! I tell you, next time I wouldn't bother with patching in to save $$. This is going to take me 10x longer than if I bought the floor half sections... _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Fri Dec 01, 2017 11:23 pm Post subject: Re: 1964 Light Grey Kombi |
Getting there on the floor seam welds. One more to go and then some finish grinding.
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sat Dec 02, 2017 6:37 am Post subject: Re: Summer is over |
junichi wrote: |
I have to seam weld the length of the cargo floor 4 times! I tell you, next time I wouldn't bother with patching in to save $$. This is going to take me 10x longer than if I bought the floor half sections... |
Yup best advice ever. I made the exact same mistake trying to save a few dollars and ended up doing double the amount of welding. . I shoulda bought the full cargo floor and welded one seam down the middle. Now I have two full length welded seams and misc patched areas. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Sun Dec 03, 2017 8:45 am Post subject: Re: 1964 Light Grey Kombi |
Same with the front floor, even if you took a brand new complete floor, cut it down the center at the heater tube (so you don't have to pull the heater tube) then butt welded the two halves together and plugged the rest it would still be hours (days?) less work and mess than the outer patch panels. |
Posted: Sat Jan 06, 2018 1:53 am Post subject: Re: 1964 Light Grey Kombi |
I'm sure you're right about the front floor...but I already made that mistake too!
Not much progress despite the holidays..family time, replacing floors at home, not time wasted.
Saw the "mig light" and had to have one. Made it out of leftover cargo floor. Works great- highly recommended. No matter how it where I set up my lights, I always seem to cast a shadow on the gun tip...this fixes it.
Posted: Sat Jan 06, 2018 6:26 pm Post subject: Re: 1964 Light Grey Kombi |
Nose is coming along... Weld, grind, repeat:
And the floor is no longer full of gaps and holes, though still a lot of grinding to do:
Posted: Fri Jan 12, 2018 10:26 pm Post subject: Re: 1964 Light Grey Kombi |
I had a day off today. I did a bit of welding and grinding on the front floor.
And started the driver's side:
Posted: Fri Jan 12, 2018 10:30 pm Post subject: Re: 1964 Light Grey Kombi |
The gauges will stay, but the wiring dangling through the front floor had to go. I will find a new way to mount them.
Nowhere near done, but I got it roughed in..
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sat Jan 13, 2018 7:30 am Post subject: Re: 1964 Light Grey Kombi |
Nice work _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sun Jan 21, 2018 8:28 pm Post subject: Re: 1964 Light Grey Kombi |
It took most of today to do the final prep, fitting, and welding. Still have to seam weld and grind the side of the new panel. Wolfsburg West front floor panel was a great fit. It only needed some trimming/resending at the a-pillar and a bit near the seat stand, and I had to carve out the hole a bit where the headlight wires pass through. Highly recommend this part.
Posted: Sun Jan 28, 2018 8:36 pm Post subject: Re: 1964 Light Grey Kombi |
Had to add a little extra piece in the front floor..a bit rustier than I thought...
Posted: Sun Jan 28, 2018 8:39 pm Post subject: Re: 1964 Light Grey Kombi |
Also this weekend I made a little guage pod. I will probably paint it later, though it is stainless. Took most of the day to redo the wiring...it was a mess.
Edit: see "before" pic above... _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Sun Jan 28, 2018 8:49 pm Post subject: Re: 1964 Light Grey Kombi |
And I played with paint stripping a bit. What colour is L345? I found a post here saying krylon river rock was similar. But it's what I would call beige... Much lighter than the paint I found on the lower half. It was under the green, then bright yellow primer, then beige, then a grey, which I think is primer?
On the top half under the white is beige, but not the same as the lower. It maybe was repainted to "match" the bottom? Then yellow primer, beige again, and grey. Shown here is the outer, non original beige on the upper body:
What colour is L345??? Is it beige? Different gallery pics of it look very different.. They call it light grey but is it really? _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 28, 2018 8:54 pm Post subject: Re: 1964 Light Grey Kombi |
L345 a grey with very light green tones in it. _________________ In Stereo, Where Available! |
