junichi Samba Member
Joined: September 12, 2005 Posts: 749 Location: brentwood bay, bc
Posted: Wed May 01, 2019 9:52 am Post subject: Re: 1964 Light Grey Kombi |
Well after 3 days of work I finally have a functional door with acceptable gaps. The skin will require a little more adjustment. Had to hack and reweld the inner structure as well as put a 20 guage shim behind the lower hinge. Then used a jack to take a bit of sag out. I thought i might be shopping for a new door! It's not pretty but it is buried inside the door anyway...
_________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
Posted: Wed May 01, 2019 10:33 pm Post subject: 1964 kombi rear bumper brackets |
Hi folks, do the rear bumper brackets bolt to the bumper or are they welded? Mine have been hacked beyond recognition. It appears the brackets have slots for bolting, but my bumpers do not. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Thu May 02, 2019 7:24 am Post subject: Re: 1964 Light Grey Kombi |
Two bolts on each side. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Thu May 02, 2019 7:32 am Post subject: Re: 1964 Light Grey Kombi |
Thanks. Mine is welded on one and has one redrilled bolt on the other! _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu May 02, 2019 8:13 am Post subject: Re: 1964 kombi rear bumper brackets |
junichi wrote: |
Hi folks, do the rear bumper brackets bolt to the bumper or are they welded? Mine have been hacked beyond recognition. It appears the brackets have slots for bolting, but my bumpers do not. |
That and a lot more in the original VW dealer parts manuals.
http://www.oacdp.org/ _________________ In Stereo, Where Available! |
shortwing Samba Member
Joined: August 18, 2006 Posts: 54 Location: The Sunshine State
Posted: Thu May 02, 2019 9:14 am Post subject: Re: 1964 Light Grey Kombi |
The brackets are intended to be bolted to the bumper. Likely to allow for a bit of adjustment during installation. Can you show a picture? _________________ "When everything seems to be going against you, remember that the airplane takes off against the wind, not with it." Henry Ford. |
Posted: Fri May 03, 2019 10:52 pm Post subject: Re: 1964 Light Grey Kombi |
Here is my bumper bracket
Nasty! _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Sat May 04, 2019 8:51 am Post subject: Re: 1964 Light Grey Kombi |
Yup, it's a mess! Bumper is twisted up from an impact so someone just adjusted the mounts to make it work!
Made some progress yesterday... Not exactly the right way to fix a door but it worked.
Posted: Sat May 04, 2019 9:02 am Post subject: Re: 1964 Light Grey Kombi |
EverettB wrote: |
Gross.
If you take it all apart you can straighten that a bit by sticking a crow bar under it and prying it outward. I've done that a few times.
Of course the best way is to unweld it from the bumper and actually fix everything. |
The latter is going to be required to get rid of the puckers in the bumper at the plate welded to the blade areas. Plus missing the bolt spacers. Will need those in place to sort out how much to bend all back to where it belongs. Otherwise over rider uprights will not fit to the bumper blade. _________________ In Stereo, Where Available! |
Posted: Sat May 04, 2019 9:04 am Post subject: Re: 1964 Light Grey Kombi |
Good to know. Right now the overriders are all on but are a bit twisted up as well. This project may wait... _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Fri May 24, 2019 10:46 pm Post subject: Re: 1964 Light Grey Kombi |
Bent up a patch for my 42 ×42" roof hole using this rudimentary method. It woked pretty well considering..
And built frames to hold it all in place temporarily:
Next step is to screw it in place, mark and cut. I will do the final bending with a hammer and dolly..
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Sat May 25, 2019 10:24 am Post subject: Re: 1964 Light Grey Kombi |
Pretty radical. That will be one huge weld. I like the rafters. |
Posted: Sat May 25, 2019 1:29 pm Post subject: Re: 1964 Light Grey Kombi |
It was a tough decision. Sunroof was tempting but the reviews of the aftermarket sunroof kits are not great and they are expensive. I would rather put 1000 bucks towards safari windows and repair panels for that area. I tbought of a custom poptop or mega subhatch but both would be a lot of work and time. I want to drive this thing. In the end original is always a good choice and this was a hard top kombi, originally. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Sat May 25, 2019 3:55 pm Post subject: Re: 1964 Light Grey Kombi |
A little hammer and dolly and it's torch time!
Posted: Fri May 31, 2019 9:58 pm Post subject: 1964 Kombi roof repair |
Roof tacked in today.
Posted: Tue Jun 18, 2019 10:51 pm Post subject: Filler time! |
Posted: Sun Jun 30, 2019 6:06 pm Post subject: Re: 1964 Light Grey Kombi |
I got my fuel guage working, but it has constant power to it, which seems wrong. From the wiring diagram it appears it should be switced from the ignition, though it seems to go through the turn signal stalk first? _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Posted: Sun Jun 30, 2019 6:30 pm Post subject: Re: 1964 Light Grey Kombi |
No, thru the speedometer first. _________________ In Stereo, Where Available! |
Posted: Sun Jun 30, 2019 7:25 pm Post subject: Re: 1964 Light Grey Kombi |
Should it have constant power though? Or be switched off by the ignition key? _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
