andersjohanssen Samba Member
Posted: Thu May 24, 2018 12:15 pm Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat K |
thatvwbusguy wrote: |
Sure. A normally open relay is just a switch that is triggered by an input voltage instead of you pushing it from off to on. Using a relay on the ground side is a "fail safe" solution since it takes no signal to do the job you want it to do. |
Thank you all for this thread. I have been overwhelmed! Does my schematic below make sense?
-Anders
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3795 Location: VA/TN
Posted: Thu May 24, 2018 12:25 pm Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat Kit |
You can get blue seas fuse blocks with the ground blocks built in. But yeah looks good to me. You would be able to condition both battery separately by the use of the relay. Also if you plan to add solar it will not combine the batteries when solar charging. _________________ Brandon
Instagram @joannthevan |
Timwhy Samba Member
Posted: Thu May 24, 2018 1:17 pm Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat K |
andersjohanssen wrote: |
-Anders
Why the 30 amp relay? If you have the ACR you don't need it. You could still use one for powering a Dometic fridge while driving. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Thu May 24, 2018 1:44 pm Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat Kit |
I'm pretty sure he has that so his prosport will not combine the batteries when engine is off. _________________ Brandon
Cbkg Samba Member
Posted: Sun Jun 03, 2018 9:48 pm Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat K |
-Anders
How's the install going? Really like this set-up! I'm going to try and duplicate this (:
Where did you get and what brand is the 30 Amp AC Relay?
Will you be connecting the Aux battery to the starter?
Thanks,
Ken |
Posted: Mon Jun 11, 2018 11:29 am Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat K |
Thanks,
Ken |
The install is going well. I just laid everything out and hooked it all up to the relay. For some reason when I went to test it, the relay wasn't clicking from the alternator when the engine was on or off. I tested the relay and it works so I am confused. Is it because I need to rev the engine to get the alternator wheel moving? Is it because the ACR needs two minutes before it does it's thing? Any ideas? Will post pictures soon!
- Anders |
Posted: Mon Jun 11, 2018 11:37 am Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat Kit |
I believe that data is in the technical data sheet but if I recall correctly the voltage of aux battery needs to be higher than like 10 volts.
Then, once the SI_ACR is on (grounded) and it detects a higher voltage above 13.3 (ish) for 30 seconds, then it combines the battery.
Yes you might need to rev the engine to excite the alternator wire to kick on the relay. _________________ Brandon
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Mon Jun 11, 2018 11:53 am Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat K |
You have 2 relays in your diagram so you should clarify which one you are referring to.
The small relay should click on whenever the charging led on the dash turns off, with engine running. Does it?
Mark
- Anders |
Posted: Mon Jun 11, 2018 11:58 am Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat Kit |
This weekend I ran the wire for my relay to control the ground on my SI_ACR. I found an alternator wire connected to a relay below the drivers seat.
Does anyone know the amperage needed for the relay to control the ground for the SI_ACR? I see some people are using like 30 amps - However I think the SI_ACR uses less than an amp tops when operating. _________________ Brandon
Posted: Mon Jun 11, 2018 12:17 pm Post subject: Re: Using Blue Sea SI-ACR Charging Relay w/GoWesty Aux Bat K |
I stupidly didn't drive or rev and so the battery light didn't go off. I will try again. Thanks.
crazyvwvanman wrote: |
Mark
- Anders |
