Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
Posted: Thu Apr 01, 2021 5:26 pm Post subject: Re: Superior turtleback lugs |
flightofphx,
I think your referring to member Anniehum and his post was about vintage EMPI locking lug bolts. Not the ones you posted.
I'll try to clarify.
Original Formula Vee Mag Wheels Lug Bolt Hole Diameter is 5/8" a Mag Lug Nut Hole Diameter is 11/16" ( see photo).
*MUST FIT IN HOLES SNUG. Due to proper mounting and centering.
TKT.CITY_vw Samba Member
Joined: May 05, 2016 Posts: 3 Location: Tecate B.C. México
Posted: Thu Oct 14, 2021 1:31 pm Post subject: Re: Superior turtleback lugs |
looking for 1 original turtle back wheel bolt
I have my set of 4 wheels that have been in storage for to long, so i think it is time to buy an original set but there isn´t any one on the market .
I have the machines & equipment to reproduce the bolt, If someone could load me 1 bolt or send me the precise measurements (with a vernier caliper please).
i will appreciate.
thanks for reading. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Fri Oct 15, 2021 11:52 am Post subject: Re: Superior turtleback lugs |
I have the solution and just installed them
Summit racing 21133etxl lugs
GOR-79915 adapter washers
12m 1.5 to 14M 1.5 adapter studs
Ground the lugs about 1/8" so they didnt bottom out.
The key to this is the diameter of the shank (.062") and having a flat surface to mate to the wheel.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
talljordan Samba Member
Joined: January 10, 2012 Posts: 968 Location: San Francisco, CA
Posted: Tue Jan 30, 2024 3:12 pm Post subject: Re: Superior turtleback lugs |
TKT.CITY_vw wrote: |
i will appreciate.
Update and reviving this dead thread.
I have produced engineering drawings that match the original bolts. Looking to get them fabricated, but the custom bolt maker in IL wants $35 PER BOLT with a min order of 100. However this does mean I can produce these if needed.
If anyone has suggestions for a cheaper/better way to get these made, I love to hear it. I think it should be doable on nearly any lathe? _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Sat Feb 10, 2024 12:02 pm Post subject: Re: Superior turtleback lugs |
Did you not see my post just above? It works. Yeah - the set up time for machining anything like what you are proposing is where the cost is. You can try shopping around to another machine shop that may do a smaller batch. You are looking for a smaller specialty shop instead of a job shop. Like, I have a local guy that has a full CNC set up in his home shop that will make me some things, but it would still be expensive. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sat Feb 10, 2024 2:14 pm Post subject: Re: Superior turtleback lugs |
I saw your post. Those washers are too large diameter and the nuts no longer exist. I found some alternatives on summit racing that I just placed an order for.
https://www.summitracing.com/parts/gor-41137et
https://www.summitracing.com/parts/gor-79916
However I still have a strong preference for originality, and I would like to get these manufactured if I can _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Thu Feb 15, 2024 6:59 am Post subject: Re: Superior turtleback lugs |
Fortunately I don't have any more turtle backs coming in for work. Let me know how what you got works for you. Thanks. And yeah, IF you are able to get new ones made, that would be of interest. There are folks that love those and you may have a small market if you can get a few dozen sets made. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu Feb 15, 2024 2:22 pm Post subject: Re: Superior turtleback lugs |
They just came in, some issues:
The shank diameter is 0.620 instead of 0.625. This may cause centering issues.
Also the shank protruding past the washer is 0.18 or so, and I think its supposed to be closer to 0.25-0.3.
I may still give these a shot but dont have high hopes. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Wed Mar 20, 2024 9:11 am Post subject: Re: Superior turtleback lugs |
talljordan wrote: |
I may still give these a shot but dont have high hopes. |
Quote: |
I Have seen those products from summit racing but not quite the good juice the wheels need, Im planing in geting some mag lug nuts with .68 shank and getting it machinned to .62, i thing it is the best way to go, have just acompliched 4 years withs my wheels maybe time to install this wheels in my 1971 squareback. all ready sandblasted just need a little polish. |
_________________ Franscico Rocha
when the sciens ends, the art begin! |
Posted: Sat Apr 20, 2024 4:45 pm Post subject: Re: Superior turtleback lugs |
Francisco and I have been working on getting these made as original. I received the sample and have tested it as adequate and a perfect reproduction.
In the photos, the rusty one is stock, and next to it is our repro, and the aftermarket nut option.
This bolt is an exact replica of the stock bolts, and the washer included is slightly thicker to prevent pitting or bending like I saw with my stock bolts.
You can see at a glance how much superior these are to the aftermarket option. Not only is the shank the correct length so theyll center better and be firmer. The diameter is correct, so they fit snug in the wheels. You can see that the aftermarket has barely any shank protruding, and because they use lug studs, there is risk of them not gripping great.
I think we will be having a bunch of these made, and then will offer them for sale, with pricing TBD.
If you have interest, please reach out so I know how many to have made.
Scott H Samba Luddite
Joined: August 15, 2003 Posts: 3026 Location: NorthCarolina,USA
Posted: Sun Apr 21, 2024 4:32 pm Post subject: Re: Superior turtleback lugs |
I would be interested in a set, pending final pricing.
What material are they being made from? _________________ Scott
oc92 wrote: |
I like the soul of an old car to be visible... |
Posted: Yesterday 12:18 pm Post subject: Re: Superior turtleback lugs |
@talljordan and I have discussed the price still working on it the material is M8 treated, strong as the specification.
This bolts are management by a mechanic engineer an test fitment in different formula vee wheels, in Jordan's wheels and my wheels.
Prices will be sell by bolt and for a 16 set, also can work on a locking bolt. _________________ Franscico Rocha
Posted: Yesterday 9:22 pm Post subject: Re: Superior turtleback lugs |
I double checked with the manufacturer by email.
The material is 4140 steel and is NOT heat treated after all. Heat treating adds so much cost that the cost for a set would exceed the value of a set of wheels.
4140 steel is rated at about 95000 PSI tensile strength which is roughly in line with grade 5 steel, and about 2/3 the strength of grade 8
That being said, I have tested the sample bolt to 125 ft-lbs with no damage. I wouldn't recommend rattle gunning the ever living shit out of them, but they should be more than adequate for our purposes. I would suggest only mounting using a torque wrench set to the correct torque setting for a VW. I didn't want to torque any harder for fear of damaging the rim itself. But my math is showing a theoretical maximum torque of over 600 ft-lbs before the threads fail, assuming a perfect bolt. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
