Vito85 Samba Member
Posted: Mon Jun 05, 2017 7:56 am Post subject: Re: VDO temp and oil pressure |
yes, the VDO oil it is ok, working fine
the issue that I have now, is to cleat the web of wires under my dashboard,
here are some pics
I understand they are relays, can you recognize them ?
if so, can you tell me the connections description ?
I found that
49 its is positive...... is that constant ? or power by the key??
49a its turn signal...... is that for the lights or to the steering wheel ??
Also I do know why there is these 2 cylinders??
any clue ??
God bless and thank you |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jun 05, 2017 9:44 am Post subject: Re: VDO temp and oil pressure |
Some information here may be of help... IT defines what numbers defines electrical function of relays and switches and whatever...
http://www.e38.org/understanding%20euro%20wiring%20diagrams.pdf
And there is this...
http://www.bosch-classic.com/media/en/bosch_classi...nungen.pdf
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Mon Jun 05, 2017 11:31 am Post subject: Re: VDO temp and oil pressure |
That looks alot like the Flasher Relay in my buggy.
Vito85 wrote: |
... I found that
49 its is positive...... is that constant ? or power by the key?? |
Neither. Constant power is usually number'd 30, and Key switch'd power is 15.
Vito85 wrote: |
... 49a its turn signal...... is that for the lights or to the steering wheel ?? |
To steering wheel, actually to center terminal of Turn Signal Lever, AND also to a tab on Hazard Switch. Here is the wiring diagram I drew up decades ago when building my buggy:
Posted: Mon Jun 05, 2017 3:47 pm Post subject: Re: VDO temp and oil pressure |
This would be the headlight relay (similar to the one Dale M identified on your post a week or two earlier in this thread). One of the 3 heavy gauge wires at bottom comes into the relay from headlight pull switch; the other 2 go out to the headlight fillaments, one for brights, other for dims. Touching the small brown wire (top right) to ground (with headlights on) actuates toggle between brights/dims. |
Posted: Mon Jun 05, 2017 7:15 pm Post subject: Re: VDO temp and oil pressure |
Think this wiring is same as your relay...
'Nother pic but basically same thing...
Vito85 Samba Member
Posted: Tue Jun 06, 2017 5:46 am Post subject: Re: VDO temp and oil pressure |
thank you very very much now I can see
I still need to find out those cylinders function..... I will get more pics later
thank you to everyone for your help
God bless |
Posted: Tue Jun 06, 2017 6:32 am Post subject: Re: VDO temp and oil pressure |
Best guess is one is for turn signal flasher and one is kludged in some how for emergency flashers... Pull one wire off unit and test systems to see what does not work...
Vito85 Samba Member
Posted: Thu Jun 22, 2017 7:51 am Post subject: Re: VDO temp and oil pressure |
very slow progress .... I need to get a new emergency switch.....
used are same or higher price than new.... do you know why ?
so far I find it on cp1 site..... any experience with this one ? why it has resistance ?
thank you and God bless
Posted: Thu Jun 22, 2017 9:05 am Post subject: Re: VDO temp and oil pressure |
My spare doesn't even have the tab with resistor. Also, in the circuit drawing I posted earlier in this thread, that tab (number'd 54, but with no resistor) is left UN-used. So it seems you may be able to just ignore that issue.
wythac Samba Member
Posted: Thu Jun 22, 2017 9:41 am Post subject: Re: VDO temp and oil pressure |
It will be interesting to see how you apply an emergency flasher switch in your oil temp and pressure circuits...... |
Vito85 Samba Member
Posted: Thu Jun 22, 2017 1:22 pm Post subject: Re: VDO temp and oil pressure |
wythac wrote: |
lol... I'm using the same thread, but different issue.... I'm wiring the car
Thank you MrGoodtunes, you right.... should not be an issue |
Vito85 Samba Member
Posted: Fri Jun 23, 2017 7:57 am Post subject: Re: VDO temp and oil pressure |
I just place my order |
