crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Oct 26, 2015 11:17 am Post subject: Fresh Air Duct Rivet |
Yes I searched. Anyone know what size that rivet is that holds the seal to the dust flap in the overhead airbox?
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211817757 _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2535 Location: Ocean Beach in Beautiful BLUE California
Posted: Mon Oct 26, 2015 12:07 pm Post subject: |
I just used standard aluminum 1/8"(?) pop rivets. I don't remember the length but just tried a few until I found the right one. One good thing about aluminum rivets is that they are easy to drill out if they are the wrong size. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
DadaCheese Samba Member
Joined: April 15, 2008 Posts: 835 Location: Richmond, CA
Posted: Mon Oct 26, 2015 1:24 pm Post subject: Re: Fresh Air Duct Rivet |
crofty wrote: |
Yes I searched. Anyone know what size that rivet is that holds the seal to the dust flap in the overhead airbox? |
Crofty, I believe you to be very exacting with your work and choices, and you are likely going for stock...
However, like some other folks, I ended up using some nuts and bolts for this job in case I want to remove it/them another time.
In fact, I believe the picture below is from before I realized that I should have done them the other way around.
_________________ ----------------------------------------------------------
Dada as in dadaism.
Cheese as in the stuff I love to eat. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
Posted: Tue Oct 27, 2015 7:14 am Post subject: |
I'm pretty sure its a 1/8 x 1/8. I bought a box of 3/16 and it was too big. _________________ Your Vanagon sucks, Stop waving at me.
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 824 Location: North Carolina
jslmc1 Samba Member
Joined: December 14, 2005 Posts: 12 Location: juneau, AK
Posted: Sat Apr 24, 2021 1:55 pm Post subject: Re: Fresh Air Duct Rivet |
I was working on mine today and couldn’t find rivets to fit at the hardware store so I ended up using m4x6 button cap screws and nuts. Also took a few pictures of the original seal and soft rubber skim coat that was used. I ended up using the later bus seal from WW and it pushes on the button heads a bit but it is not bad. It looks like you could cut a front door seal to match the original seal profile.
jslmc1 Samba Member
Posted: Sat Apr 24, 2021 4:38 pm Post subject: Re: Fresh Air Duct Rivet |
If ordering from Hansen rivet I believe(no guarantees) D1-7/32-AL should work. You want about a 9/64” diameter and 7/32” length overall. Someday I will order some at 7/32 and 8/32 and try them. If you are really picky you want one with a flat head. |
mdege Samba Member
Joined: January 16, 2018 Posts: 938 Location: Niederkruechten, Germany
