sped372 Samba Member
Joined: March 30, 2006 Posts: 653 Location: Waunakee, WI
Posted: Tue Oct 27, 2015 4:34 am Post subject: Vanagon Coolant Leak |
Just a quick intro... I have owned (and worked extensively on) a 1970 Westy for about ten years now. We've done lots of traveling but with two kids now, we were interested in two real beds.
Found a nice, mostly original Vanagon a little over an hour away and bought it about a week ago. Made the trip home with no issues.
Yesterday... Coolant leak!
I guess I should have expected it. Drove the van about 15 minutes yesterday, first it's really moved since the hour-plus drive home, and now today while just sitting there is a drip drip coolant leak from the left-hand head (cold overnight and haven't started since yesterday). I'm watching kids today so don't have time to investigate further than just a quick peek yet.
It looks to be dripping out of the air deflector under the head. Big enough (12" diameter wicked out) puddle on the concrete so far now, was dry yesterday. I have to believe it's from the water jacket seal? Crazy. I can see a tiny 0.5" pill-shaped puddle of coolant near the seal topside. Heads were supposedly just replaced 1,000 miles ago by previous owner.
Anything else to look at/for besides the obvious? Should I start it up and see if the leak gets worse (under pressure)? I put a catch pan under there for now. I need to try to get a better look from unerneath... not sure if I have to pull that piece of tin or maybe can see using a mirror. Wiped off the bit on top to see if that comes back, which I feel would be strange while sitting. All new to me though.
_________________ 1971 Karmann Ghia - 1600 DP
1984 Westfalia - 1.9 WBX |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Tue Oct 27, 2015 4:47 am Post subject: |
Check all the hoses over top of the engine maybe the crossover pipe connection is leaking and running down the wires and dropping onto the head from above. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Tue Oct 27, 2015 4:56 am Post subject: |
Sadly, that photo does appear to be a head seal.......
Not unusual, but it shouldn't leak there either.
If it is the head, there's really no simple mechanical fix short of head removal. The head studs and nuts are mostly submerged in coolant and sealed to the case with sealant.
If You rotate them, to hopefully tighten and stop the leak, you tear the sealant, now you have coolant in your crankcase if they leak! ...... NOT good.
Some have removed one head nut at a time, resealed it and torqued it, a better way....... but you violate bolt tightening sequences....... What's the risk?
If you find a loose head nut you must ask why?
Not to be a Debbie downer but studs pulling out of the case isn't unheard of, nor are broken studs.
Others swear by the Subaru leak stop designed for their engines, others swear at it.
There aren't any easy answers here, you need to weigh each option and determine what level of risk you are willing to assume.
Wash the engine off to remove existing drips and such.
Pressure test the unit.
If you determine that it is a head leak, pop the valve cover and check for tightness of each nut without rotating it.
But it is sealed to the head! How do you not rotate it?!?
Conundrum.......
If you don't own a pressure tester........
Make one.
BTW this unit can also be used quite effectively to bleed the cooling system after repairs have been made to the engine or cooling system. I carry one when I travel.
Go to a big box store and buy a $12 yard chemical pump up sprayer.
Cut the nozzle off and remove the hose from the radiator cap to the fill tank.
Clamp on the sprayer hose. Fill sprayer with water, or antifreeze mix if you prefer, and pump it up.
Let it sit over night.
In the morning, pump it up again and examine for puddles under the entire length of the Van.
Coolant leaks typically reveal themselves best when the engine is Cold.
Ghia
Vanagon
Beetle
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Oct 27, 2015 6:18 am Post subject: |
Welcome to the world of Wasserboxers. For what it's worth, mine began with a small leak that would only occur after a cold night. I decided to press my luck and it let go abruptly & completely 5,000 miles later.
Any chance the prior owner had the head replaced by a pro who would stand behind his work? Might be worth asking.
Sorry to see this so soon in your ownership. |
Posted: Tue Oct 27, 2015 6:23 am Post subject: |
I spoke with his mechanic before the purchase and he seemed like a stand-up guy. Might be worth another call. _________________ 1971 Karmann Ghia - 1600 DP
Terry Kay Banned
Posted: Tue Oct 27, 2015 7:17 am Post subject: |
While it sure looks like the head seal is weeping in the picture's, do pressure test the system to get a concrete verification of where it's coming from first.
Maybe the mechanic you're going to be calling would do this for you--
Bummer--
Don't get rid of the 70 yet--the Vangaon might be down for a smidgen' if it turns out to be the seal.
Perhaps you can work out some kind of remuneration deal with the guy that sold it to you.
Another headache--
Good Luck, _________________ T.K. |
Posted: Tue Oct 27, 2015 7:58 am Post subject: |
Pulled the lower tin and it looks dry under (above?) there. Wiped the catch pan out and going to see if any drips appear so I can hopefully spot the origin instead of just seeing it coming out of the tin. Had maybe 2 tablespoons of coolant in the pan overnight.
Is it safe to drive without that tin on temporarily? I know all tin is vital on the aircooleds, but not sure if so with water. Guessing it's more just protection for the pushrod tubes than cooling.
So the pressure test... running it isn't effective? You need to leave pressure on it overnight? Any worries about overpressurizing? Thanks, guys. _________________ 1971 Karmann Ghia - 1600 DP
Terry Kay Banned
Posted: Tue Oct 27, 2015 8:14 am Post subject: |
No problems pressure testing the system.
You may see exactly where it might be faster that you think--
This would be the best way of pinpointing the source of the leak pronto--
Won't hurt anything --just as long as you keep the pressure down to 15-20 psi.
You can drive without the push rod cover --just don't go off roading. _________________ T.K. |
fraggle00 Samba Member
Joined: October 19, 2011 Posts: 356 Location: Bristow, VA
Posted: Tue Oct 27, 2015 10:00 am Post subject: |
Pushrod tubes have the look of a recent repair or some crazy good maintenance. I believe the tin is simply for protection, not for ducting like on the air cooled motors. _________________ '91 Vanagon Carat
'87 Porsche 928S4 DOWN
'12 Fiat 500 Abarth |
Posted: Tue Oct 27, 2015 11:20 am Post subject: |
I found a small hose over the top of the engine that was weeping slightly. I was able to track a small trail of coolant starting at the bottom of the engine and working upwards. The drips were coming from the outboard end of the head, nowhere near the block-to-head seal. The trail went straight upward from there, to the intake manifold, and then over to just under that little hose. Snugged up the hose clamp. Cross your fingers for us that it really was that easy!
Thankfully the areas I was looking at were clean from the recent head replacement... rest of the engine bay needs a detail! _________________ 1971 Karmann Ghia - 1600 DP
Posted: Tue Oct 27, 2015 11:39 am Post subject: |
Very possible... or karma from all the roadside repairs on the '70?
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Merian Samba Member
Posted: Tue Oct 27, 2015 11:47 am Post subject: |
True!
I only browsed this thread but hope you have not sold a bay in such beautiful shape - it will make a fabulous gift for your kids when they are grown, and will only be more of an interesting vehicle by then.
It is now time to think about your repair skills, tools, working space & time -- or to consider an engine swap. |
Posted: Tue Oct 27, 2015 11:51 am Post subject: |
I really don't think we'll be able to part with the bay... too many memories.
The Vanagon might just be a temporary solution for a few years. I like it, but it's definitely short on some charm compared to the Bus. But wowza it feels like a mansion inside! It was a difficult decision to even consider 'upgrading' but we'll see how it goes. _________________ 1971 Karmann Ghia - 1600 DP
