solar question
flattire
flattire is offline
PostPosted: Thu Oct 29, 2015 3:11 pm    Post subject: solar question Reply with quote
Yes I have read everything about solar and I couldn't find the answer to my question. When I add accessories ( like fan etc) I know I put the positive into my fuse bar, but what happens to the negative wire? I run the + & - wire from the solar panels to my controller, then + & - to the battery.. I run wire from battery to fuse bar. I have mppt controller - 6 place fuse bar - 5 20w panels. Hope I am coming thru to you guys! ALL ANSWERS APPRECIATED. flattire
newfisher
newfisher is offline
PostPosted: Thu Oct 29, 2015 3:24 pm    Post subject: Reply with quote
There should be a ground stud on your stand alone fuse panel. Once it is grounded, you can now use that side of the fuse bar to ground your accessories.
which panel do you have
flattire
flattire is offline
PostPosted: Thu Oct 29, 2015 6:28 pm    Post subject: solar Reply with quote
Thanks Newfisher for the reply. I still not sure how to handle it. I have a 6 place fuse bar which is just used for positive connections . Most accessories come with 2 leads=== red & black. I connect the red to my fuse bar and where does the negative go? Do I need another bar for the grounds? I have 5-20 w panels from Solar Ink. Thanks
thatvwbusguy
thatvwbusguy is offline
PostPosted: Thu Oct 29, 2015 7:38 pm    Post subject: Reply with quote
The body of the van is a ground. Use a ring connector and a self tapping screw (or a factory bolt and a toothed washer) and you have a good ground.
If you want to return wires to a common location, something like this should do the trick nicely: http://www.amazon.com/Blue-Sea-Systems-Power-Connector/dp/B000XBEPFC . Since it is a ground, you don't need the red rubber boot. Use a short piece of heavy wire to connect the large post to the chassis of the van and then connect the ground wires from your accessories to the smaller screws around the perimeter.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
kamzcab86
kamzcab86 is offline
PostPosted: Thu Oct 29, 2015 7:40 pm    Post subject: Re: solar Reply with quote
The simplest method, IMHO, is to use a Blue Seas-type of fuse panel, which has both + and - buses:
If you don't want to go that route, the next simplest method is to, yes, get a ground bus if you have multiple ground connections. Otherwise, you'll attach the - wires to any convenient ground on/in the van (I, personally, prefer them all in one place so I don't have go fishing around should a problem arise... and I don't like piling them all up on one bolt).
~Kamz Anxious
2016 Golf GTI S
thatvwbusguy
PostPosted: Thu Oct 29, 2015 8:07 pm    Post subject: Reply with quote
To be honest, I ground most things locally to the chassis with a ring terminal and a toothed washer. This approach takes way less wire, reduces the spaghetti of wires near the fuse block and doesn't depend on a single ground connection to support all the others like a common bus ultimately does.
I have zero reservations about drilling holes in my van to hook things up though. Many people don't seem to share this point of view Wink
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
HoustonPhotog
HoustonPhotog is offline
PostPosted: Fri Oct 30, 2015 5:44 am    Post subject: Reply with quote
I agree with Kamz... I love the Blue Sea blocks with their own Ground bus.
Blue Sea Systems 5025:
http://www.amazon.com/gp/product/B000THQ0CQ/ref=as...4NMNFHWHZN
I had a major electrical issue when I bought the van and it took forever to figure it out. It all came down to a ground post that had too many grounds stacked on top of each other which made one ground not connect right.
Since then I switched over to Blue Sea blocks so each ground had its own terminal.
To combat wires everywhere I have 3 of these Fuse blocks in my van. One under the drivers seat. One in the middle westy cabinet and a third inside of a custom cabinet I built that sits behind my passenger seat. I supply power via 8awg wire to these blocks.
My install here:
http://texasvanagons.com/rear-power-distribution-block/
Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now
