To add or not to add! |
Yes it's better to add oil sump. |
40% |
[ 8 ] |
No longer needed. |
60% |
[ 12 ] |
Total Votes : 20 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Sat Oct 31, 2015 3:12 am Post subject: |
Benefits of a sump for a daily driver are to the manufacturers of oil and their profit margins.
VW designated an oil change interval so that the oil is changed before its lubricating properties are lost. If you add sump, you can extend that interval in proportion to the new oil capacity, but:
Cooling
Horsepower increases
Curing baldness
Longer engine life
None of these stand up to scrutiny of benchmark tests. I'll wager 99 percent of air cooled engines don't reach end of life cycle due to oil wear but some other reason. _________________ .ssS! |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Oct 31, 2015 7:06 am Post subject: |
I have 1 1/2 qt on my 70 bus with 2110cc full flow can be tricky with the
'stashbar' & headers
no they don't cool the oil! maybe 1 or 2 degrees :shock:The aux cooler with fan does that!
off-road two-tracking is a bit tricky but I do it all the time ,I've bent the edge of the sump plate on sexStones up here but never broke a sump _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Mon Nov 02, 2015 3:37 am Post subject: |
I installed the oil sump this weekend. It was fun in the process and I really noticed the sudden drop in the temperature and how clean the oil stays. But the looks of the oil sump exposed underneath is pretty scary especially on off road situations. I guess that would be a challenge post in the future in the event that our camping venue will require us to travel light off road driving. I am driving the bus to work now and I can feel that the engine is benefiting from that upgrade. I guess, it's worth it.I will post the pics soon!
thanks,
Dong _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Nov 02, 2015 4:26 am Post subject: |
madmike wrote: |
I've bent the edge of the sump plate on sexStones up here but never broke a sump |
Is this some kind of Freudian auto-correct?? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Mon Nov 02, 2015 4:31 am Post subject: |
Northern michigan slang for big "F*&King Rock" _________________ 'Black Ice'Drag Buggy 'Turbo'
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Nov 02, 2015 11:30 am Post subject: |
DONGKG wrote: |
I installed the oil sump this weekend. It was fun in the process and I really noticed the sudden drop in the temperature and how clean the oil stays. But the looks of the oil sump exposed underneath is pretty scary especially on off road situations. I guess that would be a challenged post in the future in the event that our camping venue will require us to travel light off road driving. I am driving the bus to work now and I can feel that the engine is benefiting from that upgrade. I guess, it's worth it.I will post the pics soon!
thanks,
Dong |
In my previous replies I've stated my opinion of a deep sump maintaining normal oil temperatures on long uphill climbs and the decreased road clearance hazard.
My comments and opinions on Dong's latest post:
As a driver I don't think you will notice a sudden drop in oil temperatures and the way to realistically measure the effect correctly would be with an oil temperature gauge or an IR thermometer. Oil that is too cool could be a problem on short drives in humid or cold weather.
The oil will appear to stay cleaner because of the increased capacity, but the the lubricating qualities of the oil depend on both the contaminants that it collects and the temperatures to which it has been heated.
The deep sump helps maintain normal operating temperatures on long uphill climbs and reduces the amount of horsepower lost due to overheating. The result is better uphill performance.
New equipment is fun to install and test, but the perceptions of change may be chimerical. Loss of ground clearance is real.
Manilla to Baguio with an oil temperature gauge might be a good test of oil temperatures with and without the sump and the results with data would be welcome here.
Aloha
tp |
Posted: Tue Nov 03, 2015 1:20 am Post subject: |
Tom Powell wrote: |
DONGKG wrote: |
thanks,
Dong |
Aloha
tp |
Yeah, thanks for that one. You are absolutely correct, buddy. The low oil temperature is quite apparent and so with the viscosity quality of the oil. And I can see that the additional volume of oil will be helpful on uphill road trip. So also long drive on the freeway. We'll be going to Baguio tomorrow, I was wondering if we will use the bay window or our so so so boring Toyota fortune......
Thanks. _________________ '67 KG Cabrio (Mickey) ;
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Tue Nov 03, 2015 1:16 pm Post subject: |
The other thing that is misleading on increasing oil volume is that it takes longer to settle on an operating temperature.
So a hill climb will not heat a larger volume of oil to such a high temperature but the heat is still there and it will run hotter on the down grade for longer to make up for it.
On my bus it does not reach peak oil temperature until it has been driven at 65-70mph for 10 miles. No deep sump as it was lowered by somebody a long time ago...only full flow and long hoses to the cooler adding another 1.5 quarts to the capacity. _________________ Ancient vehicles and vessels
Posted: Tue Nov 03, 2015 1:44 pm Post subject: |
Remember that slow warm up is a major reason for engine wear so adding a deep sump if you don't really need it may actually shorten engine life. For myself i will stick with running a high viscosity index synthetic oil (usually a 5w40) and let it do its thing. I have long run enough extra oil so that the stock oil sump is full to overflowing and feel this has a positive effect on engine life. |
Posted: Tue Nov 03, 2015 10:20 pm Post subject: |
This is the step by step I made in installing the oil sump.Although I have posted this already on my bay window thread, I hope this will not be considered as a re-post.
The vice grip came in handy in removing the original small stubs.
Checking on the removed oil strainer and other hardwares needed.
The silicon gasket maker was likewise essential during the installation and the surfaces of both the engine sump and that of the aftermarket oil sump
must be double checked for possible uneven surfaces; otherwise, the chances of the oil leaking is likely to happen.
Tightening each and every bolt required patience and the unnecessary force should not be applied.
The washers were replaced too considering that they were already flat like a sheet of paper.
The bolts of the oil strainer should be tightened equally and evenly and one at a time.
After installing the same, I drove test the bus and left it running of a few minutes.It turned out to be positive. The temperature was moderate and after a few days of driving, the oil stayed clean.
Thanks,
'72 Type 2 Homey
'67 Splitty Bus
Manfreds78bay Samba Member
Posted: Tue Nov 06, 2018 3:13 pm Post subject: Re: Adding oil sump. Pros and cons.. |
I'm thinking about adding the sump only to solve a stripped drain plug.
I've tried a time insert and it did not hold. The drain plug holds well enough, but it does leak. I'd like to avoid the drill and tap method because where does it end? And these cases are rare as it is. If this thing gets stripped, its and easy fix.
Before you get after me for stripping it out in the first place. I've never over torqued the drain plug. I'm sure it has been over tighten over the years which caused the issue in the first place.
I've driving this thing across the country and never had an issue with cooling or thinking I need more oil for any reason. I've done plenty of long climbs and so forth. _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue Nov 06, 2018 5:02 pm Post subject: Re: Adding oil sump. Pros and cons.. |
They make sumps for Type 4 engines?
Edit: that looks like a modified Type 1 sump. How does it attach? I took mine off a few months installing it because the oil took soooo long to warm up i got yogurt in my oil cap.
www.airschooled.com |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Nov 07, 2018 6:51 am Post subject: |
mikedjames wrote: |
So a hill climb will not heat a larger volume of oil to such a high temperature but the heat is still there and it will run hotter on the down grade for longer to make up for it. |
This is... accurate... ish... Your oil temps will just be slower to respond to abuse (long high speeds, long uphills, etc). They may not get quite as hot as without a deep sump (people noting 1-3 degrees), but you wont see the oil temps shoot up on a long uphill, they will raise and to your point lower more gradually. So yeah, the heat is still in there... but heat is just energy, and now that energy is dispersed over a larger quantity of oil. So the oil is working less. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Wed Nov 07, 2018 6:56 am Post subject: Re: Adding oil sump. Pros and cons.. |
asiab3 wrote: |
Robbie |
That's just another day for us northerners... Push it back in so that yogurt can warm up and become oil again. Because wasting yogurt when there are people starving is just wrong. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
SGKent Samba Member
Posted: Wed Nov 07, 2018 8:17 am Post subject: Re: Adding oil sump. Pros and cons.. |
lived in Los Angeles basin for years with a 1971 bus. Found that a low profile sump was the only way to control oil temps on hot days on long grades. That said, it had to come off every fall and back on every summer. Once outside temps drop below 80F the oil would never warm up if the sump was on. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Nov 07, 2018 8:20 am Post subject: Re: Adding oil sump. Pros and cons.. |
Sumps are for chumps. _________________ .ssS! |
