36 hp oil cooler
Jrb572
Jrb572 is offline
PostPosted: Fri Oct 30, 2015 3:10 pm    Post subject: 36 hp oil cooler Reply with quote
I am just about done rebuilding my 36hp. I was thinking about the oil cooler. Should I have it boiled out? I put fresh oil in it. Then turned it upside down again. It appears to have not huge but some type of chunk that comes out with the oil. Any ideas? I was looking to possibly move up to a 356A oil cooler. But they look super expensive.
Kjell Roar
Kjell Roar is offline
PostPosted: Sun Nov 01, 2015 2:36 pm    Post subject: Reply with quote
I would flush the oil cooler with diesel or parafin.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
morymob
morymob is offline
PostPosted: Mon Nov 02, 2015 6:29 am    Post subject: Reply with quote
Being otta sight, i used a later better one in my 57.
PostPosted: Mon Nov 02, 2015 8:57 am    Post subject: Reply with quote
What was changed?
VWCOOL
VWCOOL is offline
PostPosted: Mon Nov 02, 2015 2:52 pm    Post subject: Re: 36 hp oil cooler Reply with quote
Was it the oil cooler on YOUR motor? Was the motor running, or did it blow up and fill the cooler with metal?
Jrb572
Jrb572 is offline
PostPosted: Mon Nov 02, 2015 8:09 pm    Post subject: Reply with quote
There was a wrist pin knocking. But the motor had been sitting for sometime before I put about a 100 or so miles on it. I went ahead and ordered on from someone on here that had one that was cleaned and pressure tested. It was $36. Figured it would be best to not reuse it.
morymob
morymob is offline
PostPosted: Tue Nov 03, 2015 5:42 am    Post subject: Reply with quote
Spelled out: OIL COOLER!
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Tue Nov 03, 2015 6:47 am    Post subject: Reply with quote
So what is the difference in the OIL COOLERs Wink
is the question ask.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
PostPosted: Tue Nov 03, 2015 9:16 am    Post subject: Reply with quote
What was changed?
Yes, if this was not clear - what is different about the "later better" oil cooler?
Snort
Snort is offline
PostPosted: Fri Nov 06, 2015 4:13 pm    Post subject: Reply with quote
The oil cooler was shortened, the number of tubes reduced from 36 t0 32, they were brazed instead of soldered, painted black instead of silver. I don't know if any of the changes resulted in better performance. Perhaps if anything slightly better airflow to the cylinders and heads and fewer leaks but I'm just guessing.
Edit: Also the early ones win the oil cooler beauty contest hands down.
tobiasax
tobiasax is offline
PostPosted: Sun Nov 08, 2015 2:01 pm    Post subject: Reply with quote
My thinking is that the changes were made to improve durability. Pre-early-1957 coolers had problems with cracks and leaks. The new design proved to be so good it was used by VW until 1970 when the engines did have 1500 cc and lots more hp. My belief is that the 57-70 oil cooler is good enough for a street driven hopped-up 30/36 hp engine.
__________________________________________
PostPosted: Tue Nov 10, 2015 9:04 am    Post subject: Reply with quote
To clarify for myself:
Are we talking about the change from the "dome" oil coolers to the later style or ?
Snort
Snort is offline
PostPosted: Tue Nov 10, 2015 3:34 pm    Post subject: Reply with quote
I made that assumption, so seeing no other comments to the contrary I would say yes.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Mon Nov 23, 2015 10:17 pm    Post subject: Re: 36 hp oil cooler Reply with quote
Buy a new one. I saw a picture where someone sawed off the top of the cooler after having it professionally cleaned. There was enough &^%* in the cooler to ruin 10 engines.
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
PostPosted: Mon Nov 23, 2015 11:07 pm    Post subject: Re: 36 hp oil cooler Reply with quote
Is there a source for new 36hp oil coolers?
gimmesomeshelter
PostPosted: Mon Nov 23, 2015 11:41 pm    Post subject: Re: 36 hp oil cooler Reply with quote
This will fit:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111117021E
If you have the money, you can install one of those aluminum oil coolers the Porsche guys use.
http://www.nlaparts.com/store/aluminum-cooler-p-691.html
Cheers,
Paul
Richard Feynman
txoval
txoval is offline
PostPosted: Tue Nov 24, 2015 11:59 am    Post subject: Re: 36 hp oil cooler Reply with quote
I used the one from the link to Wolfsburg West.
The only key item being, you must use the "Green" oil cooler seals. They are designed to use this cooler on the early engines. 8mm ports to 10mm ports.
If you use the early seals (black cylinders) they will leak immediately and you will have a heck of a mess...don't ask how I know this
My57Oval
My57Oval is offline
PostPosted: Sun Feb 14, 2016 7:36 pm    Post subject: Re: 36 hp oil cooler Reply with quote
Is this cooler the same basic dimensions as stock for say ,a '57 36HP motor?
Because if not, and it is taller or will block air flow to #3, than you may have cooler oil but higher head temperature right?
Rob
My57Oval
My57Oval is offline
PostPosted: Sun Jun 12, 2016 7:46 pm    Post subject: Re: 36 hp oil cooler Reply with quote
Hi. Has anyone used this cooler?
Lingwendil
Lingwendil is offline
PostPosted: Sun Jun 12, 2016 11:13 pm    Post subject: Re: 36 hp oil cooler Reply with quote
Supposedly this is the same cooler as the one from Wolfsburg west, but I haven't handled one myself...
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-117-021-EAL
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
