87 Westy Syncro TDI conversion and restoration~lots of pics
Page: 1, 2, 3 ... 16, 17, 18  Next
Syncrodelic
Syncrodelic is offline
PostPosted: Sun Oct 30, 2022 6:50 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Still loving this mounting idea. I'm going ahead with a conversion this winter but I'm doing a 50 degree install. How would the stock pendulum mount setup work at 50 degrees?
Thinking I would try moving/extending the mounting pin over to the new centre line of the engine/trans, but if it's not well balanced there it would likely put strain on the bellhousing and transaxle mounts. Could probably find the balance point and alter the moustache bar/crossbeam mounting point to match, although keeping everything on centre would be easier for sure.
I'd welcome any thoughts or ideas on this to help figure it out....
Syncrodelic
PostPosted: Wed Oct 13, 2021 8:58 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Congrats on this amazing build Kevin. So well done, and so well documented. Like many others, I really appreciate the efforts to share your knowledge and progress.
I really like the system you designed to mount the TDI and I had decided to copy it for my own TDI install. However something struck me when I woke up recently thinking about it. Your engine/transaxle package is mounted at 3 points I believe--at the two trans mounts at one end, and at the other end on a single mount at the far end of the engine. What is making me hesitate is that generally the engine end is mounted with two arms coming from the sides of the motor somewhere in the middle of the block. Having the single mount at the end moves the support farther out from the center mass of the block. Does having the engine/trans mounted at each far end put a lot of stress on the bellhousing? With the bellhousing right in the middle, it seems like there would be a lot of strain on those bolts and the housing itself. I know that this is how the ALH is setup on the MK4, however the motor/trans is a much longer package on the Syncro. I see that it obviously works for you, but I'm concerned about rough offroading, which I do like to do in my Syncro. Do you have any concerns there?
tilstad
tilstad is offline
PostPosted: Tue Jan 19, 2021 11:24 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Any news on how the ac worked? Id love a similar setup myself. We get roasted here in Texas.
tilstad
tilstad is offline
PostPosted: Sun Jul 26, 2020 5:05 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Could you post some results of the AC system? Is it working satisfactory? Pro's/Cons?
Was it a 120V motor?
jrcstudios
jrcstudios is offline
PostPosted: Wed Apr 22, 2020 7:39 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
I knew I couldn't be the only one that wanted to use the factory AC as a "plug in"! I would love more details on this, I'm about to try the same thing on a '91 tin-top with the tunnel AC (which works great on the engine) Are the compressors simply parallel in plumbing? or do you have change over valves?
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Jan 23, 2020 8:38 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
87vanwes wrote:
ALIKA T3 wrote:
Wow Kevin! This a great job as usual, looks well designed as usual Cool Cool
Thanks ALIKA
Hope all is well with you. Is the address you gave me years ago still good?
Oh I just see this now as I am looking at your mods again!
Yes it is Smile
I just got the plates you sent me welded for the Syncro conversion a few months ago, been doing some short test drives the last couple weeks to sort out everything!
fleet_maintenance
fleet_maintenance is offline
PostPosted: Sat Dec 07, 2019 2:27 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
This thread just turned 4 years old!?! Time flies, how is the van working out for you? (and happy holidays!)
87vanwes
87vanwes is offline
PostPosted: Wed Jul 31, 2019 5:03 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
puchfinnland wrote:
Great work as usual, so 2 belt driven compressors on one system.
So far so good. The only thing that worries me is oil starvation with two compressors. The oil could pool at the non running one. They are at the same elivation so maybe not.
Kevin
1987 westy syncro tdi conversion and restoration.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
87vanwes
87vanwes is offline
PostPosted: Wed Jul 31, 2019 4:59 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
?Waldo? wrote:
Fantastic!
Thanks Andrew.
I need to pick you genius diesel mind sometime.
How are your projects coming along?
Kevin
87vanwes
87vanwes is offline
PostPosted: Wed Jul 31, 2019 4:57 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Thanks ALIKA
Kevin
puchfinnland
puchfinnland is offline
PostPosted: Sun Jul 07, 2019 5:50 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
?Waldo?
?Waldo? is offline
PostPosted: Mon Jun 24, 2019 2:34 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Fantastic!
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Jun 24, 2019 12:44 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Sun Jun 23, 2019 12:57 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Thank you for the pics Kevin.
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD
87vanwes
87vanwes is offline
PostPosted: Sat Jun 22, 2019 4:54 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Ok... the plugin AC puzzle.
Google was no help on tying two compressors into one system. Lots of hybrid car stuff but no luck on my quest. The idea was to use the existing ac equipment already in the van with a 120v compressor piggybacked with the engine driven one.
I decided if I were going to pull this off was to use belt driven automotive compressor. The question was how much horsepower would it take. Google was all over the place, five horsepower, ten horsepower... this was not doable. I decided to go out on a limb with 3/4 horsepower. If I canít stay well under 20 amps Iím out of business for plugging in.
So I bought a sanden compressor.
Used the specs and cut out a bracket to link a standard motor to the compressor.
I also picked up a waterproof 3/4 horsepower motor and this was the test.
This is with an onboard battery charger that keeps up with all the fans.
A few more pics of the setup working well.
The battery charger is under the rear cabinet this one is separate from the house charger. It is easily removed if a charger is needed.
Another cool one is cruise control Cool
Itís the go Westy with a factory stalk I scored on eBay
After a little adjusting it works quite well
I hope every one is well and thanks as always for the thoughts and kind words.
Kevin
87vanwes
87vanwes is offline
PostPosted: Sat Jun 22, 2019 4:10 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
[email protected] wrote:
yes more please!!!!
I guess this is the latest.
On the last page I shared the plugin ac idea using a household compressor tied into the onboard ac system. It was a learning experience and almost worked. The compressor simply could not produce the volume of refrigerant for an expansion valve system.
Another problem was the vw radiator fan was loud and was a power hog. The mod I did for this was to use a fan and motor out of a mark 3 tdi car.
I cut an adaptor to fit the fan and motor into the Vanagon shroud. It is very quiet and uses very little energy.
A few words of caution the ALH TDI has a very low heat signature meaning itís very easy to cool and puts very little strain on the cooling system. Iím not sure this fan mod would keep up with the factory engine or other repowers.
14 years apart and the wire colors are the same go figure.
I will try to get the AC part up soon.
Kevin
87vanwes
87vanwes is offline
PostPosted: Sat Jun 22, 2019 3:41 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
big swifty wrote:
Resurrecting this beautiful build thread. Working on my exhaust for my van. Would you kindly post some pics of your exhaust system?
Hey swifty
When I did my exhaust I was hoping there was a kit available but no luck finding one. Earlier in the thread I showed an exhaust using the factory tdi resonator. It did not last very long before it spit itís guts out and never was as quiet as I would have liked.
In the end I wound up using the stainless Moroso muffler. Itís fairly quiet and small. You may have noticed I relocated the turbo actuator to keep the exhaust tucked in tight to the engine. The exhaust is completely attached to the engine. Iíve thought of adding an additional brace to the bell housing, but so far so good.
Here are some pics for you.
I hope this helps.
Kevin
[email protected]
ahmed.aboudan@gmail.com is offline
PostPosted: Fri Jun 21, 2019 4:01 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
yes more please!!!!
big swifty
PostPosted: Thu Jun 20, 2019 4:34 pm    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Evan
87vanwes
87vanwes is offline
PostPosted: Thu Sep 13, 2018 5:40 am    Post subject: Re: 87 Westy Syncro TDI conversion and restoration~lots of pics Reply with quote
Thanks guys
We're in good shape here. I'm thinking we will get a prolonged blow from the east going to the southeast. My best guess would be winds in the 50 mph range with a good amount of rain. We're not prone any kind of flooding due to rain. Wind driven flooding is another story but east winds won't do it.
I will do an update soon and keep you posted on any storm problems.
Once again thanks for the thoughts and well wishes you guys are great
Kevin
Page 1 of 18
