jb144 Samba Member
Joined: February 25, 2016 Posts: 63 Location: San Francisco
Posted: Sat Oct 29, 2022 1:09 pm Post subject: How do I safely (temporarily) remove my AC compressor? |
My AC compressor is blocking access to some grounds I need to trace and replace. It was not connected when I bought the van many years ago and I'm unsure if I unscrew the lines if it'll blast me with refrigerant. I see the Shrader valves, which dont release anything when I pressed them down. Anything I need to know to take it off and reinstall afterward? Hoping one day to upgrade and get AC back.
Thanks.
'85 1.9L |
Abscate Samba Member
Posted: Sat Oct 29, 2022 1:18 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
Put a gauge on them to confirm absence of refrigerant _________________ .ssS! |
jb144 Samba Member
Posted: Sat Oct 29, 2022 1:20 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
Like a tire gauge on the Shrader valve? If it's empty, then I just unbolt remove and replace after I'm done? Is it that simple? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sat Oct 29, 2022 2:16 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
jb144 wrote: |
Yes. But a tire gauge won’t fit the valve. Sounds like you depressed it and nothing came out. So that indicates it’s empty of refrigerant. _________________ ☮️ |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat Oct 29, 2022 9:56 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
Just leave them there and make new wiring to a better location that is easily accessible.
If you must pull the pump, you can just take the bolts out and leave it connected. That is what shops do when they pull an engine.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Sat Oct 29, 2022 11:06 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
There's very little chance that there is any refrigerant in the lines after all these years of it not working.
You can give the shrader valve a little press with a small screw driver to see if there is anything in it but I doubt it. |
jb144 Samba Member
Posted: Sun Oct 30, 2022 9:23 am Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
Thanks everyone. Pulled it yesterday without issues, no refrigerant in the lines.
I have two ground bolts below the condenser with 7 brown grounds coming out. Really hard to trace where they all go, I imagine these aren't all stock. |
Posted: Sun Oct 30, 2022 1:04 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
That count sounds about correct for the 2.1 _________________ ☮️ |
jb144 Samba Member
Posted: Sun Oct 30, 2022 5:30 pm Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
It's a 1.9. Looks like I'll need to cut the looms and trace each one. |
jlrftype7 Samba Member
Posted: Mon Oct 31, 2022 6:15 am Post subject: Re: How do I safely (temporarily) remove my AC compressor? |
jb144 wrote: |
Why do you need to trace them? Just wondering? We too have the 1.9, here's our Grounds. There is a Spray Type Anti Corrosion on the eyelets that I added after cleaning them.
Anyway, if the wiring isn't corroded more than a very short distance from the end of the existing ground eyelet on each wire, it will be pretty easy to open up the harness sleeve enough to splice into your grounds for some fresh repaired connections.
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
