Combinations Samba Member
Joined: March 19, 2010 Posts: 286 Location: Massachussets
Posted: Fri Nov 06, 2015 2:58 pm Post subject: bay 76 rear seat belt anchoring system |
Hi guys, I am putting the seat belts that were originally installed then removed before I got my 1976 bus.
There are there belt set right?
The sides ones get attached on the side with bolts that also maintain the vertical part of the seat too correct?
Are these sides bolt the same as the middle ones?
Thanks
Aurel |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Nov 06, 2015 3:42 pm Post subject: |
If you mean the outer seat belt attach points on the fenderwells also secure the seat then yes, the seat hinge goes on first and the belt holds it down. All the bolts are the same thread, not sure if the ones that hold the seat are slightly longer. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Nov 06, 2015 3:55 pm Post subject: |
busdaddy wrote: |
If you mean the outer seat belt attach points on the fenderwells also secure the seat then yes, the seat hinge goes on first and the belt holds it down. All the bolts are the same thread, not sure if the ones that hold the seat are slightly longer. |
Ok get it, thanks
Good point on the length , I guess they might be. The one I found seems too small. I will double check that tomorrow. |
Posted: Fri Nov 06, 2015 4:51 pm Post subject: |
Seatbelt bolt thread is universal for all cars, 7/16" NF if I'm not mistaken, the autowrecker will have some if Ace hardware doesn't. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
