Fuse & Relay Panel - more hacks by a PO
Merian
Merian is offline
PostPosted: Fri Nov 06, 2015 5:01 pm    Post subject: Fuse & Relay Panel - more hacks by a PO Reply with quote
I found these empty crimp on taps on red/gray and black/gray wires. Any ideas on what this PO could have been up to?
Like using a sharp probe, these things pierce the insulation, but are worse, as they can cut into the wire itself. OTOH, I usually figure it is worse to remove them than to just leave them there.
thoughts?
djkeev
djkeev is offline
PostPosted: Fri Nov 06, 2015 5:09 pm    Post subject: Reply with quote
This is the back side if an 86 fuse panel. Which plug group has those wires with the taps on them?
If you zoom in, each group has a letter.
That letter will tell you exactly where to search the wiring diagram for your answer.
Dave
Ghia
Vanagon
Beetle
Merian
Merian is offline
PostPosted: Fri Nov 06, 2015 5:58 pm    Post subject: Reply with quote
all I know is that when I took the pic, I made a note that this is of the "lower LH corner"
no idea if that is from the front or the back
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Nov 06, 2015 6:00 pm    Post subject: Reply with quote
The color of each of the plastic connector blocks is unique and spelled out in the Bentley. That color along with the wire colors should make it simple to figure out what those wiring taps connected to.
Mark
shadetreetim
shadetreetim is offline
PostPosted: Fri Nov 06, 2015 6:13 pm    Post subject: Reply with quote
Looking closely, I don't see any 3rd wire sticking out of those "fire hazard" crimps. At this point, if they're not being used to splice or t-tap the wire, removing them or not will have no real effect. If they are being used to splice or t-tap, I would suggest replacing them. Personally, I always solder and shrink wrap connections, others may suggest a good quality crimp fitting. YMMV
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'10 Wrangler 3.8 6SP Manual
'12 Ford E350
'12 Tiguan 2.0T 6SP Tiptronic - Lady Shadetree's
crazyvwvanman
PostPosted: Fri Nov 06, 2015 7:03 pm    Post subject: Reply with quote
The grey/red and grey/black with the added taps are the wires to the front parking lights, right and left.
It looks like another one of those taps is hiding there too.
Since nothing it hooked to them I would just leave them alone.
Mark
Merian
Merian is offline
PostPosted: Fri Nov 06, 2015 7:06 pm    Post subject: Reply with quote
Thx.
seems odd, what would somebody power off the front parking lights?
thatvwbusguy
thatvwbusguy is offline
PostPosted: Fri Nov 06, 2015 7:43 pm    Post subject: Reply with quote
Those are 3M T-Taps. Removing them will do more damage than good.
I have seen people power fog lights from those wires. Bad idea, but not that out of the ordinary...
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
VANAGON HEADLIGHT RELAYS & HARD START RELAYS
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
Merian
Merian is offline
PostPosted: Fri Nov 06, 2015 8:16 pm    Post subject: Reply with quote
hmmm... it has added driving lights, so maybe that was an initial attempt by a PO, and later changed
not sure where they originate but they are on a relay now
david2676
david2676 is offline
PostPosted: Sat Nov 07, 2015 9:35 am    Post subject: leave them Reply with quote
those are likely from the PO installing some type of electronics ..radio gauges whatever .. take a meter and see if they are hot .. Key one or off ect .. or trace down the wire and see what wire they tapped into. it might give you place to add some gadget in the future. It will not hurt at all to leave them. removing it will leave a small pin hole. Not much to worry about. if it were me i would wrap its with tape.
this is really common on used cars likely they had a stereo installed and this is what is left.
64 bug
91 Vanagon/ Subaru swap Westfalia
