fooblahblah Samba Member
Joined: June 06, 2004 Posts: 19 Location: Boulder, CO
Posted: Sat Nov 07, 2015 11:59 am Post subject: Rear outer wheel bearing depth? |
One of my outer rear bearings completely self destructed. I'm working on them and was not sure how far to press the outer bearing? Since there is no hard stop in the sleeve other than the spacer between the inner and outer. Anyone have any tips?
Thanks
_________________ 87 Syncro Adventurewagen |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Sat Nov 07, 2015 2:58 pm Post subject: |
Check your Bently. I'm sure it tells you. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Sat Nov 07, 2015 5:59 pm Post subject: |
On the outer, there is not a bearing stop. Press it in until it is flush with the seal ledge. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Sat Nov 07, 2015 6:59 pm Post subject: |
Thanks. That's what I was curious about. _________________ 87 Syncro Adventurewagen |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Sun Nov 08, 2015 2:47 am Post subject: |
when I did my first set of rear outer bearings, this was my first concern. I noticed the wear pattern of my old bearings and they were in the center. I would like a proper press tool that would stop at the right spot. That bearing is a little delicate also since the rollers are caged there. The inner bearing is so much easier than that outer one in my opinion. _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9614 Location: Western WA
Posted: Sun Jul 25, 2021 9:16 am Post subject: Re: Rear outer wheel bearing depth? |
===== PSA clarifying an old thread that has a good searchable title. =====
Thought I'd add this pic showing that taking the Bentley literally is "wrong".
Bentley writes: "press bearing in until seated."
but there is no seat.
I think they meant to write: "press bearing in until 'VW472' is seated."
Not knowing what the VW472 tool looks like, I went thru the measurements with a caliper and confirmed that the outer race should be positioned just about "flush" in its bearing bore.
Looking at thedesign of the bearing it's clear that there is a couple mm tolerance either way in the final position, but if you press it down until it stops (as if against a non-existant seat, the bearing may be destroyed.
The 'stop' is the rollers jammed against the spacer.
When you drive, the rollers will be rubbing on the spacer.
Here are two simple ways to set the outer wheel bearing depth.
And note that there is up to 2mm tolerance either way so if you end up satisfying either of the condition on the pic, it's good.
Also note that on the OTHER side, the housing seal is pressed down against the circlip, about 5mm deep into the bore. _________________
....KTMs, GasGas, SPOT mtb |
