geodude Samba Member
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6348 Location: Honolulu,Hawaii and France
insyncro Banned
Posted: Tue Nov 10, 2015 10:04 am Post subject: |
I have a set here...beefy.
The fins are a new look for sure.
I am still going to have them trued as I do with all new brake parts.
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Tue Nov 10, 2015 10:41 am Post subject: |
insyncro wrote: |
I am still going to have them tried as I do with all new brake parts. |
I assume you meant "trued". I have seen this several times. Wouldn't it make sense to heat cycle them a few times (i.e.use them) before doing that? I'm not saying it is not important, as my drums currently need it. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
insyncro Banned
Posted: Tue Nov 10, 2015 10:45 am Post subject: |
If you wish to heat cycle go for it. |
Posted: Tue Nov 10, 2015 12:29 pm Post subject: |
Sounds like you haven't fitted them up yet. Curious about the fit and finish. _________________ 1988 GL Camper
1991 Multivan — the basket case |
insyncro Banned
Posted: Tue Nov 10, 2015 12:40 pm Post subject: |
geodude wrote: |
Sounds like you haven't fitted them up yet. Curious about the fit and finish. |
Everything except the backing plates will be new.
They fit fine.
I personally don't like the look of them, but they aren't seen behind rims with small openings.
They are heavy, and that is good for heat displacement.
SA drums are NLA, so these are your next best thing. |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Tue Nov 10, 2015 12:48 pm Post subject: |
Wow thats a lot of unsprung weight! What does a wheel and tire weigh? What does that do to your carefully selected shock valving? _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
insyncro Banned
Posted: Tue Nov 10, 2015 1:21 pm Post subject: |
240Gordy wrote: |
Wow thats a lot of unsprung weight! What does a wheel and tire weigh? What does that do to your carefully selected shock valving? |
Any van that I am worried about with reference to your question would have custom adjustable suspension and rear disc.
These drums are for stock vans and are designed not to warp, same as the SA versions that have dried up. |
danfromsyr Samba Member
Posted: Tue Nov 10, 2015 2:33 pm Post subject: |
for someone with larger diam off road tires, concern of unsprung weight is already thrown away.. but greater heat dissipation from the greater rotational mass just in the tire alone would be helpful. _________________
Abscate wrote: |
insyncro Banned
Posted: Tue Nov 10, 2015 2:38 pm Post subject: |
danfromsyr wrote: |
for someone with larger diam off road tires, concern of unsprung weight is already thrown away.. but greater heat dissipation from the greater rotational mass just in the tire alone would be helpful. |
Plus, while camping you can jack the rear up and use the fins to make salsa on one side and mash tatoes on the other.
Watch your knuckles |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Tue Nov 10, 2015 7:25 pm Post subject: Re: Gowesty Finned Brake Drums |
I have a set on my Syncro Multivan. There are heavy and super sharp, I like the look of them as well. My stock drums were toast so at almost the same price as Chinese made Ate's I'm happy with them. I haven't had a chance to flog em but they've got to be better than my stock warpy drums they replaced.
I did end up replacing the studs, I run Rheins and I had about 4-5 turns of an alloy lug nut. With stock steel wheels should not be an issue, anhy thing other than that I'd replace the studs.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 806 Location: Seattle
Posted: Sun Nov 19, 2017 12:48 pm Post subject: Re: Gowesty Finned Brake Drums |
Got the GW finned drums last year. Now going back to stock when I get the chance. I've been getting a horrible pulsating when braking. The shop pulled the drums and turned them. They said one was slightly out of whack while the other was way out of whack. After turning them and remounting, there was no change. weird. Maybe something else is off that's causing the drum to be off. The shop didn't charge me for the fruitless two hour detour. Taking it back in two weeks for a swap back to stock. We'll see then if anything changed.
16CVs Samba Member
Posted: Sun Nov 19, 2017 2:27 pm Post subject: Re: Gowesty Finned Brake Drums |
I had that issue and GW just sent me another set and said chuck the old ones. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Posted: Sun Nov 19, 2017 4:18 pm Post subject: Re: Gowesty Finned Brake Drums |
RainierSyncro wrote: |
I have this issue and it ended up with one of the hubs being out of kilter. Installing a different hub fixed the problem. This could be a factor in your pulsing brakes. |
Posted: Sun Nov 19, 2017 11:15 pm Post subject: Re: Gowesty Finned Brake Drums |
The shop did mentioned a possible hub problem. Will have them look into it while swapping the drums to avoid another visit. I had to panic stop on the freeway and the whole van shuddered. The pedal was bouncing so hard that my foot almost slipped off. Beyond irritating. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Mon Nov 20, 2017 8:04 am Post subject: Re: Gowesty Finned Brake Drums |
In my experience, while it is a pain to do, you get a better drum machining job if you use the stock hub with the drum bolted to the hub with the lug nuts vs a plain drum. This replicates best how it sits on the stub axle spindle. The drum centers just don't hold it square enough to the drum lathe with the lathe adapters. I am not saying it can't be done without the hub though. _________________ ☮️ |
Posted: Mon Nov 20, 2017 8:09 am Post subject: Re: Gowesty Finned Brake Drums |
on my new to me van the rear brakes pounded and at times (randomly) would drag and be close to smoking hot..
issue was in the aftermarket rims twerking the drum when torqued. _________________
Abscate wrote: |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Mon Nov 20, 2017 8:48 am Post subject: Re: Gowesty Finned Brake Drums |
I had a pair the original GW heavy duty drums and could not, after multiple attempts to eliminate the pulsing caused by them, went back to stock drums and all is well. Contemplating Burley Discs in the rear now. _________________ '90 Syncro Westy w/GW2.5L |
Posted: Thu Dec 21, 2017 4:59 pm Post subject: Re: Gowesty Finned Brake Drums |
Update - replaced the GW finned drums with stock replacements and the pulsating stopped just like that. Must have gotten a bad pair. |
