Joined: January 01, 2007 Posts: 16803 Location: sticksville, ct.
Posted: Tue Nov 10, 2015 8:36 pm Post subject: steering shaft rubbing inside tube |
how I get involved with this crap is beyond me....
66 bug, adjustable beam installed elsewhere. the steering shaft is bottomed in the tube and for obvious reasons rubs.
I pulled the U clamp off the box, checked it both ways and one way wasn't going to fly at all.
I am out of ideas. last ditch effort would be weld up the notches on the U clamp and re grind notches in it. I need to get the steering box up like 3-5mm to prevent rubbing in the tube. even at that, it wouldn't be centered.
I have no idea who made the beam. like I said, I'm out of ideas any help before I go and re-index the notches on the U clamp?
thanks in advance _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
grandpa pete Samba Member
Thomas Lindemann Samba Member
Joined: May 07, 2013 Posts: 111 Location: Gloucester, VA
Posted: Wed Nov 11, 2015 2:49 am Post subject: Re: steering shaft rubbing inside tube |
honestly you don't need the notch on the beam itself, grind it off and just center the steering shaft in the tube and off you go |
Posted: Wed Nov 11, 2015 7:11 am Post subject: Re: steering shaft rubbing inside tube |
Thomas Lindemann wrote: |
I think I would much rather re-notch the U bracket than clean off the nubs on the beam. I would hate to see the steering box dance around on the beam _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Nov 11, 2015 8:25 am Post subject: Re: steering shaft rubbing inside tube |
a lot of the nicer after market beams don't even come with that notch. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Thu Nov 12, 2015 7:42 pm Post subject: Re: steering shaft rubbing inside tube |
The notches are on the clamp. The clamp pointing one way for a bug and another for a ghia. You're right some don't put the 'nubs' on a tube of the beam. Just another sign of the lowering of standards for replacement parts. Check out those home made from OG sheetmetal bolt 'keepers'
