Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Wed Nov 11, 2015 12:32 pm Post subject: Ball joint adjustment - positive camber issue |
Building up my notch pan and have a ball joint/camber issue I can't figure out. I feel like iv'e built everything up correctly. I have german ball joints and Bert3 spindles. However, after adjusting the passenger side bj's to the fullest (upper & lower) I still have positive camber. I was able to get the drivers side pretty much straight, visually. Also I have the upper control arms bolted into the sway bar just enough to push on the seals, and the control arms slowly fall on their own when free.
Here's a pic, you can see the positive camber. I was able to adjust it in some more after this pic was taken, but still not enough.
Don't think this pic will help much.
Drivers side
_________________ Justin |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Wed Nov 11, 2015 1:00 pm Post subject: Re: Ball joint adjustment - positive camber issue |
Bent arm?
Are these like buses where you stack washers between the arms and the spindle to ensure front camber is correct? If so, you need Less on the top, more on the more on the bottom, or both _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Erik G Samba Member
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Nov 11, 2015 1:04 pm Post subject: Re: Ball joint adjustment - positive camber issue |
Now you know why VW made all those special tools for measuring front end hardware. Hitting curbs will bend some components. You may have a bent torsion arm. I have a similar problem... I can get one side in spec, but getting the other within 0.2(?) of the other like the book says is impossible. To complicate it, my ball joints lack the marks on the ends of the pins, so it took a while to figure out which way to adjust.
The effect is slight and unnoticeable around town. But out on the freeway, it pulls slightly to one side, and that gets fatiguing. My cheap solution until I fit another beam is to put 2 psi more in the dragging side, and presto, it tracks straight! |
Posted: Wed Nov 11, 2015 1:16 pm Post subject: Re: Ball joint adjustment - positive camber issue |
These are the same arms and beam that were in my fastback and were all true at that time. The difference now would be new BJs and Berts spindles. I also added the larger diameter sway bar. Hmmm... _________________ Justin |
Dlglobal1 Samba Member
Posted: Wed Nov 11, 2015 1:54 pm Post subject: Re: Ball joint adjustment - positive camber issue |
Where did you get those tie rods from? _________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Thu Nov 12, 2015 12:06 am Post subject: Re: Ball joint adjustment - positive camber issue |
If you read through Bert's drop spindle thread there are posts that say the style of ball joint you are using (Meyle) are not compatible. You need the style without the shoulder. _________________ 69 Fastback Build
Berg5 Build |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Nov 12, 2015 12:35 am Post subject: Re: Ball joint adjustment - positive camber issue |
I wouldn't even attempt to correct anything here until you have the suspension fully loaded with the body assembled and on and do a full front end alignment starting with centering the wheel and adjusting toe.
Every angle affects every other angle and if you get the suspension "looking" perfect when it's not loaded, it won't look perfect when you add all the weight.
That said, if the BerT3 spindles don't work with the Meyle ball joints- of course change them now while it's easy, but do not drive yourself bonkers with any alignment settings just yet. You're just chasing your tail. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Nov 12, 2015 8:00 am Post subject: Re: Ball joint adjustment - positive camber issue |
Brent wrote: |
If you read through Bert's drop spindle thread there are posts that say the style of ball joint you are using (Meyle) are not compatible. You need the style without the shoulder. |
OK.. so what style is needed?
These?
http://www.thesamba.com/vw/classifieds/detail.php?id=1749531 _________________ Justin
BerT3 Samba Member
Joined: August 18, 2002 Posts: 1569 Location: Antwerp
Posted: Thu Nov 12, 2015 8:13 am Post subject: Re: Ball joint adjustment - positive camber issue |
Indeed - those balljoints are no good - use the ones without a shoulder
BerT3 |
Posted: Thu Nov 12, 2015 8:38 am Post subject: Re: Ball joint adjustment - positive camber issue |
Copy that. I just ordered the NOS set that I linked above.
Can someone post pics showing the difference between ball joints with the "shoulder" and without? _________________ Justin |
Posted: Thu Nov 12, 2015 8:40 am Post subject: Re: Ball joint adjustment - positive camber issue |
Tram wrote: |
That said, if the BerT3 spindles don't work with the Meyle ball joints- of course change them now while it's easy, but do not drive yourself bonkers with any alignment settings just yet. You're just chasing your tail. |
Good point. Thanks Tram. _________________ Justin |
Brent Samba Member
Posted: Thu Nov 12, 2015 9:45 am Post subject: Re: Ball joint adjustment - positive camber issue |
I hope they send the Teen Love book with the ball joints. Because how far should making out really go? _________________ 69 Fastback Build
Berg5 Build |
Posted: Thu Nov 12, 2015 10:04 am Post subject: Re: Ball joint adjustment - positive camber issue |
Brent wrote: |
I hope they send the Teen Love book with the ball joints. Because how far should making out really go? |
Bonus! I'll make my 16yr old read it! _________________ Justin |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Thu Nov 12, 2015 10:29 am Post subject: Re: Ball joint adjustment - positive camber issue |
Critter1 wrote: |
Brent wrote: |
Bonus! I'll make my 16yr old read it! |
What rims are oon your car? They look like 912 or 256 rims. Thanks!
Ray |
Posted: Thu Nov 12, 2015 10:47 am Post subject: Re: Ball joint adjustment - positive camber issue |
Yes they are staggered 4.5/5.5 ... 911/912 steel rims.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Thu Nov 12, 2015 12:45 pm Post subject: Re: Ball joint adjustment - positive camber issue |
Tram wrote: |
That was my first thought too when I saw the pics. Until you get the body on it, and get some weight onto the pan, you'll be just chasing your tail trying to set it. It (weight) does make a difference, as right now there's really "no load" on the torsion bars. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Nov 16, 2015 7:05 am Post subject: Re: Ball joint adjustment - positive camber issue |
I got the correct ball joints installed. Thanks for the advise on this topic, much appreciated. Now, I wont stress over alignment until the full weight of the car is on the ground.
Here's the build thread if anyone here is interested:
http://www.kustomcoachwerks.com/forums/viewtopic.php?f=15&t=8366 _________________ Justin |
Posted: Mon Nov 16, 2015 7:31 am Post subject: Re: Ball joint adjustment - positive camber issue |
Critter1 wrote: |
Where did you get them might I ask? I know of one Porsche/speedster specific site that sells nice reproductions....but these may not be the same. I have been hoping to find some in four bolt.
Thank you! Ray |
