My 181 bundeswehr olf friend, time to do a body swap ...
Page: 1, 2, 3  Next
joghia
joghia is offline
PostPosted: Thu Nov 12, 2015 3:58 am    Post subject: My 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
saved her form the junkyard back then, we've had 5 wonderfull years of joy together !
did almost every aircooled car shows in belgium, holland ... the car is too far gone for a resto... so a good body swap and a new set of pans should keep the vin nr alive !
i traded a set of porsche cayenne wheels for a decent body ( 100 times better then my previous one) the new body requires the undersides of the left and right flanks, the nose was hard and straight, also rustfree!, the rear and espically the engine space is very bad, so here we go...
here is my car, the body in a sad state, floorpans welded to the body, several times, also the fenders welded to the body and a lot of bondo and misc. parst on there by the p.o , patched it up as good as we could, lasted for 5 years now (always outdoors in belgian climate)
the new donor body, first things first
some welding
other side
so far so good, no over to the rear, the sides of the engine in the engine bay are different from my old one ? my engine side is straight, this one is curved, so out with the sides
hopefully i can swap them and they will be not too bad from my old car...[/img]
citroen
citroen is offline
PostPosted: Thu Nov 12, 2015 2:59 pm    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Keep going we have build Things in worst shape check them out on our website http://kubeltreffen181.com
coopster
coopster is offline
PostPosted: Thu Nov 12, 2015 6:16 pm    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Nice , some good work going on there , what colour are you painting it?
joghia
joghia is offline
PostPosted: Fri Nov 13, 2015 3:57 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
thanks guys !
yes, this car was a write off about 12 years ago i think, so now getting it going for another 20 plus years .
i don't want to paint it army green again.... (because here in our small country there are dozens of it nowadays...
thinking about ral 7016 or ral 7021, panzergrau / stumpfmatt
that means i have to paint my seats and canvas top in a differtn color than original ...
planning on not running the front bars, and og mirrors, i have an old searchlight/mirror for my driverside...
if i cant find a cheap 3 spoke steering wheel i also want to put that in, first rescueing what can be rescued from my old body
coopster
coopster is offline
PostPosted: Fri Nov 13, 2015 4:59 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Army green is awesome Wink
joghia
joghia is offline
PostPosted: Mon Nov 16, 2015 7:26 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
my last piece of the rear is in !
my helpers came and tilted the body back on the floor with me, now it's sanding time ! they just smiled and left Smile
the only thing i need to weld to the body now is the one around the motor, that piece will hopefully be pulled of my old body, the sizes and shape was different ?
maybe the body was made for a fuel injected one ?
joghia
joghia is offline
PostPosted: Mon Nov 16, 2015 7:32 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
this is how i spend my weekend in grey belgium.
this week more sanding and putting filler on, ... i don't like filler but a little bit of filler is needed to get the most of the battlescars out of her !
still in search for left side fenders and doors..........
ernieballbass
ernieballbass is offline
PostPosted: Mon Nov 16, 2015 1:22 pm    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
that looks like how i spend my weekends here in Florida Cool
What I lack in brains, I make up for with good intentions.
joghia
joghia is offline
PostPosted: Tue Nov 17, 2015 2:41 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
at least you get a nice tan in the sun ! Very Happy
anayway, still sanding everything ! inside and out, i hope to spray the shell this weekend in its first cover of ' red menie' some european primer/ anti rust /...
so far no luck with the left side fender search...........
el_safari
el_safari is offline
PostPosted: Tue Nov 17, 2015 3:21 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Nice work joghia !
This Bundeswehr made in Germany 181 had some roll over .
I could save the back and some pieces .
Hard work to free the fenders ...
La terre n'est qu'un seul pays
joghia
joghia is offline
PostPosted: Tue Nov 17, 2015 8:22 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
i witnessed a roll over once, in the middle of the night at the campsite of le bug show in spa a few years ago......
wasn't pretty ....
that left front fender looks nice Very Happy
el_safari
PostPosted: Wed Nov 18, 2015 2:26 pm    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Hello joghia
The left front fender is for a friend ... Cool
joghia
joghia is offline
PostPosted: Fri Nov 20, 2015 2:47 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
so far nothing to report, sanding, and sanding, till my hands shake too much..
HIGHTOWER
HIGHTOWER is offline
PostPosted: Fri Nov 20, 2015 9:48 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Hi ,Yo
This is where i am at right now.
Time dor collor.
Quallity is never an accident!
el_safari
PostPosted: Fri Nov 20, 2015 10:48 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
HIGHTOWER wrote:
Hi ,Yo
Time dor collor.
Hi
What is this colour ?
I prefer something more "greenish" , I would like to try moss grey RAL 7003 https://www.ralcolorchart.com/ral-7003-moss-grey
on a door Cool
HIGHTOWER
PostPosted: Fri Nov 20, 2015 12:08 pm    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Hi,this is the primer after wettsanding Very Happy .
Next i think steppebeige with black bumpers.
[email protected]
waugamans@aol.com is offline
PostPosted: Fri Nov 20, 2015 6:19 pm    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
Barely resembles the original Thing, very nice work so far.
joghia
joghia is offline
PostPosted: Mon Nov 23, 2015 2:45 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
very nice koen ! straight as hell !
here some sanding pics
joghia
joghia is offline
PostPosted: Mon Nov 23, 2015 2:54 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
time for some redness !
joghia
joghia is offline
PostPosted: Mon Nov 23, 2015 2:55 am    Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... Reply with quote
still looking for left fenders and doors
mine are just too bad to put time in it and use..
Page: 1, 2, 3  Next
