Dan Pedro Samba Member
Posted: Thu Nov 12, 2015 9:46 am Post subject: 356 A or B ? |
In need of some help identifying a 356 I purchased about a year ago...the problem is that it doesn't have the original vin (has a state issued vin number) and has probably been clipped at some point...it is titled as a 59, but looks exactly like a 60 B model so I just figured it was a B car built in 59...thats until I pulled the gauges and they are dated mid-1958...the engine is no help either because its a 912!! Are there any differences in the tub itself between an A and a B car? I'm starting to think that someone hung a B nose and doors on an A tub... |
James Davies Samba Member
Joined: September 24, 2013 Posts: 141 Location: Baltimore, USA
Posted: Thu Nov 12, 2015 10:02 am Post subject: Re: 356 A or B ? |
The original chassis number can be found in 3 places:
1) stamped into the chassis beneath the rubber mat behind the spare tire
2) on the Porsche chassis/model ID tag between the fender and gas tank on passenger side
3) stamped on an aluminum tag on the door hinge cover plate, driver's side
You can then look up this chassis ID here
http://356a.com/
And find out what year it is.
It is likely it is a 356A that was hit, and had 356B parts grafted on for repairs. |
dg58innm Samba Member
Posted: Mon Dec 07, 2015 6:08 pm Post subject: Re: 356 A or B ? |
The rear frame members are different. Rear seat pans are different. The rear tunnel/floor/bulkhead intersection is diffferent. The tunnel itself is different. Top of door hinge pillars are different. The battery boxes are different. Plenty of other little details in the tub metal to differentiate between A and B. Post a few picures and it should be obvious.
DG |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Mon Dec 07, 2015 9:01 pm Post subject: Re: 356 A or B ? |
dg58innm wrote: |
DG |
The whole car is different from the outside. Front fender lines, bumper/overrider locations, front air intakes, hood handle, the list goes on. No need to look at pans, etc. With a simple comparison of pictures it will be very obvious which is which. As noted, if you can post a picture it will be easy to tell. |
Posted: Wed Sep 14, 2016 12:15 pm Post subject: Re: 356 A or B ? |
Porsche has confirmed that the car started life as a '59 A but received a B replacement body from the factory at some point in its life...ugh. I am considering back dating the nose to an A...any thoughts for or against this "mod"? |
Posted: Wed Sep 14, 2016 6:54 pm Post subject: Re: 356 A or B ? |
If you're going to switch back (good luck) I don't see where having an "A" nose and a "B" everything else would make sense. To me it's all or nothing and at this point if the car is straight I would lean toward nothing and leave it be. Just my $0.02. Best of luck either way you go. |
tom coughlin Samba Member
Joined: February 16, 2008 Posts: 67 Location: near Boston
Posted: Thu Sep 15, 2016 5:29 am Post subject: 356 B back to an A |
If you prefer the A look go for it. If you go to show the car and somebody makes an issue, you can argue that you've just made it original. That's something that any old B that's been changed to an A look without the history of your car would be unable to argue. |
dsrtfox Samba Member
Posted: Thu Sep 15, 2016 10:55 am Post subject: Re: 356 A or B ? |
If the factory rebodied it and you have written proof I wouldn't touch it but it's your car... |
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Sat Sep 17, 2016 4:42 pm Post subject: Re: 356 A or B ? |
I second the position of "if you have documents from Porsche that show it was rebodied I would leave it".
That being said it's your car do as you wish. _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Sat Sep 17, 2016 4:52 pm Post subject: Re: 356 A or B ? |
What does the shifter/heater control look like? _________________ Jack Staggs
Actual name |
saddlesore1 Samba Member
Posted: Wed Sep 21, 2016 9:23 am Post subject: Re: 356 A or B ? |
what is your serial number and does the number on the nose under the mat match the number on vin plate or doors.
I have a very early 1960 which has many anomalies when compared to a "True" B. |
JulesD Samba Member
Joined: September 27, 2007 Posts: 36 Location: Phoenix, AZ
Posted: Wed Sep 28, 2016 9:33 pm Post subject: Re: 356 A or B ? |
How can porsche verify if you have a state issued vin? What number did you give them to run? They go by old records so a state issued vin would not come up. I dont get it |
Posted: Mon Nov 21, 2016 10:59 am Post subject: Re: 356 A or B ? |
Porsche kept record of vin when selling a replacement body. I supplied the replacement body number and they supplied me the correct vin. during a resto vins are removed but because this car was newish when this was done the original vin could not be transferred. |
ensys Samba Member
Joined: March 11, 2009 Posts: 322 Location: America's Automobile Heartland
Posted: Fri Nov 25, 2016 11:44 pm Post subject: Re: 356 A or B ? |
Just another opinion (w/the usual disclaimer about "your car"), but the Factory documented replacement body makes your car "original" as it stands, just like an authorized replacement engine would then be correct for a car.
Buggering around with the body to suit one's tastes is the owner's privilege of course, but be aware that it will cost you somewhat dearly in ultimate value.
If you can't stand Bs, sell it to someone who will respect it for what it is and buy yourself an A.
PS: Given the situation, I should think most states would, after inspection, re-register with the now-correct body no.
As a parallel situation, Calif. used to register by engine no., but with a little persistent effort, I had mine changed to the body no. _________________ Keep 'em flying...
S.J.Szabo |
