srfndoc Samba Member
Posted: Thu Nov 12, 2015 4:17 pm Post subject: Emergency Flasher Stopped Working |
67 Bus with stock setup. My emergency flasher stopped working recently and I'm trying to figure out the cause. Left and right flashers still work fine both front and back. I have power on the -S terminal of the emergency flasher switch and the K terminal is correctly hooked up to the blue wire going to the turn signal switch.
Initially I thought I had a bad switch but trying another switch did not fix it. On both switches, if I pull it out half way and wiggle it a bit I can hear a single click like its starting to flash but then stops. Could my 9 pin relay be bad even if the turn signals are still working correctly? I did clean the surface where the switch mounts to the dash to be sure there was a good ground.
Thanks for any help. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
OldVolks67 Samba Member
Joined: August 18, 2010 Posts: 159 Location: Boston Metro West
Posted: Thu Nov 12, 2015 5:47 pm Post subject: Re: Emergency Flasher Stopped Working |
When I replaced my wire harness in my bus i had an original 9 pin to use. I had the same problem so I too tried two different flasher switches,neither had worked.
I bought a new 9pin from WW and low and behold that was the culprit. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Nov 13, 2015 9:24 am Post subject: Re: Emergency Flasher Stopped Working |
srfndoc wrote: |
Could my 9 pin relay be bad even if the turn signals are still working correctly? |
You can Dremel the hollow rivet off and open the 9-pin. Once open you can clean the contacts and usually get it to give you a few more years of service. It will still screw back onto the mount after that. |
Posted: Fri Nov 13, 2015 9:46 am Post subject: Re: Emergency Flasher Stopped Working |
Unfortunately my bus was modified by the PO with this setup:
It looks like they used two of these instead of a 9 pin:
http://www.wehrle-electronics.com/en/trade/flasher...spx?LNG=en
Maybe these will work as a replacement:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111953227D
I'm guessing this was a solution somebody offered before WW had their 9 pin setup? Either that or they didn't want to pay $64 for the 9 pin replacment:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211953227BWW
So... I'm going to order one of the $10 relays and replace it to see if that resolves the issue. Is their any benefit to going to the 9 pin relay WW offers vs. my current setup (albeit not as clean looking)? Everything has always worked very well up to my emergency flashers that stopped working.
Thanks _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
turbo_g Father of Samba Cookie Lover
Joined: October 30, 2002 Posts: 717 Location: Laguna Hills, Ca
Posted: Fri Nov 13, 2015 5:02 pm Post subject: Re: Emergency Flasher Stopped Working |
Hey Todd, don't mean to hack into your thread and hijack it, so I'll give you my two cents worth before I hijack.
I like the idea of the 9-pin, clean, correct. I tried like the dickens to get the 9-pin i had on my 66 to work, but ended up having someone bread board me the equivalent (down in San Diego many many moons ago). If WW had one back then, I would have been in heaven. The breadboarded hack that I had looked much like what you have with the two relays, I guess I'm not the best electrical engineer, cause I never did get full understanding of how the two relays worked together.
On to the Hijack:
Has anyone tried to fit a 9-Pin into an earlier bus? Say a 63? Currently I have blinkers, and emergency flashers, but no dash lights that illuminate when blinking or flashing. I have tried every combination of relays and used the correct wiring to try and make them work, but again, must not be the best electrical engineer.
Would it be worth it to try? Anyone done it? Have the schematic? _________________ Turbo_g
66 TinTop Westy SO42
63 Sub-hatch Westy SO33
SV2s Member #425
"Three out of four voices in my head say 'Go for it'." |
Posted: Fri Nov 13, 2015 6:35 pm Post subject: Re: Emergency Flasher Stopped Working |
Damn you Greg!
No worries, I'm still trying to evaluate my options and figure out how the two relays work together as well. The fact that I still have turn signal flashers working correctly seems to prove the relay is working. It really looks like a grounding issue but I double checked the switch and cleaned up all connections but still have the issue.
Electrical is not my strong suit either so its a learning experience for me every time. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
olliehank47 Samba Member
Posted: Fri Nov 13, 2015 7:54 pm Post subject: Re: Emergency Flasher Stopped Working |
turbo_g wrote: |
On to the Hijack:
Would it be worth it to try? Anyone done it? Have the schematic? |
If I read your post correctly, you don't have the 9-pin but something like the OP. If that's the case, and you don't install a 9-pin, you can rig up a connection to make your dash light blink.
Look at the photo below and you will see the turn signal light at the bottom. The bulb gets power from the outside spade terminal via the black wire from the ignition switch. The bulb gets a ground, and lights up, when the flasher unit sends a flashing ground signal to the spade terminal in the center of the bulb holder.
It appears your makeshift set up does not have a relay that would have a blinking ground terminal when the flasher is working so nothing would be connected to the dash bulb. If a wire is connected, it is probably sending power to the bulb but nothing happens because the bulb has no ground--only two power connections.
Disconnect the daisy-chained wire from the ignition (the black one that connects all the dash bulbs together), from the outside terminal of the turn signal bulb. Be sure to tape off the end because it will be constantly hot. Now, run a wire from any terminal on the relays, that sends a flashing power signal when the flasher is on, to the disconnected terminal of the dash light (I don't have a schematic of your set up, but you must find a terminal that flashes under all conditions--left,right, or emergency. ) Run a simple ground wire from the center terminal to any permanent ground. Now, when the flasher is on, the bulb will blink in unison with the other bulbs be they the left or right turn lights or all four together. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Nov 16, 2015 10:01 am Post subject: Re: Emergency Flasher Stopped Working |
turbo_g wrote: |
Try the flasher unit from a 69-71 bay. I have one in my 59 and it works correctly. |
Posted: Sun Feb 07, 2016 12:36 pm Post subject: Re: Emergency Flasher Stopped Working |
Just to bring this full circle, replacing my custom relay setup with a WW 9 pin unit fixed all my issues and is working great:
