brokevwguy Samba Member
Joined: November 03, 2012 Posts: 269 Location: Upstate New York
Posted: Tue Oct 24, 2017 5:29 am Post subject: Re: 1965 westfalia so-35 flipseat |
Is the bottom of the wheel wells on a 61 flared or are they straight? I am debating on ordering the the section from the vents down or trying to repair it, if I ever get that far.
_________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Oct 24, 2017 7:14 am Post subject: Re: 1965 westfalia so-35 flipseat |
my 61 was straight. does not appear like you need the entire side. _________________ regards
Uli
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Tue Oct 24, 2017 3:15 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Thanks Everett. I thought I could just use a piece of straight sheet metal. Oakman what guage metal did you use for the wheel wells? I need to also figure out the guage metal for frame because I have to repair a section of that too. _________________ Be happy with what you have, you will save allot of money that way....
1961 Standard |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Wed Oct 25, 2017 6:57 am Post subject: Re: 1965 westfalia so-35 flipseat |
brokevwguy wrote: |
Thanks Everett. I thought I could just use a piece of straight sheet metal. Oakman what guage metal did you use for the wheel wells? I need to also figure out the guage metal for frame because I have to repair a section of that too. |
You should consider buying an inexpensive pair of vernier calipers, that way you can measure what you have and compare it to what you intend to buy. A set at harbor freight is probably $20. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Thu Oct 26, 2017 10:47 am Post subject: Re: 1965 westfalia so-35 flipseat |
While we're talking mango here's a few more pics of the new project:
Picked up a nice middle seat for it:
Someone sanded the drip rail and other various spots on the bus then brushed on some sort of a rust inhibitor. The pictures in the ad made it look like the entire roof gutter was rusted all around. The roof is solid, only surface rust. I'll try to make that look better with some blending I think.
I've been after a pressed bumper bus for a long time so I'm pretty stoked to have this Mango. _________________ Brandon |
srfndoc Samba Member
Posted: Thu Oct 26, 2017 12:23 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Sweet looking bus. Your never going to finish the Westy with all these distractions. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
AS350driver Samba Member
Posted: Thu Oct 26, 2017 1:23 pm Post subject: Re: 1965 westfalia so-35 flipseat |
oakman wrote: |
I've been after a pressed bumper bus for a long time so I'm pretty stoked to have this Mango. |
Project? That looks like a finished bus to me! |
oakman Samba Member
Posted: Thu Oct 26, 2017 1:39 pm Post subject: Re: 1965 westfalia so-35 flipseat |
srfndoc wrote: |
Sweet looking bus. Your never going to finish the Westy with all these distractions. |
Haha I know, I never really completely finish anything though. Distractions are good sometimes, i'm all about distractions.
AS350driver wrote: |
It needs all of the usual to get it roadworthy, it does run and stop though! _________________ Brandon |
oakman Samba Member
Posted: Tue Nov 21, 2017 8:30 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Trying to put more miles on the Westy before BBB in January. I've only driven it about 130 miles so far. Finally had it out of the neighborhood and onto the highway It cruises nicely at 60, and at idle it's so smooth you can hardly tell it's running.
Here's what's left of my local Route 66 diner that burned to the ground last year in the Blue Cut Fire. I miss this place, I would eat there at least a couple times a month. This is at the top of Cajon Pass on I-15.
Some dirt road driving:
Took the bus out tonight after work and caught the last bit of light:
All in all everything is working as it should. The one problem I've been having is the ignition switch for the steering lock. It seems to be weak, not making a strong connection inside. A few times I've had to wiggle the terminals slightly while turning the key to get it to start. The bus had a Ford starter relay hooked up when I got it, I think I need to re-install that or get a new one from WW to take the load off that circuit. _________________ Brandon |
OgCalLook Samba Member
oakman Samba Member
Posted: Tue Nov 21, 2017 10:07 pm Post subject: Re: 1965 westfalia so-35 flipseat |
OgCalLook wrote: |
BadAss Bro! BBB 2018!! |
Thanks Tom, it will be here before we know it! Can't wait!! _________________ Brandon |
oakman Samba Member
Posted: Mon Dec 11, 2017 9:55 pm Post subject: Re: 1965 westfalia so-35 flipseat |
I bought a Wolfsburg West hard start relay. Easy to install and instantly cured my starting issue. It starts like a 12v bus now.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111998611
Putting miles on the bus!
squareweave Samba Member
Joined: November 15, 2004 Posts: 448 Location: British Columbia
Posted: Tue Dec 12, 2017 11:20 am Post subject: Re: 1965 westfalia so-35 flipseat |
Killer bus!! Perfect in every way |
oakman Samba Member
Posted: Tue Dec 12, 2017 1:27 pm Post subject: Re: 1965 westfalia so-35 flipseat |
squareweave wrote: |
Thank you Rich, it's slowly getting there! _________________ Brandon |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
wcfvw69 Samba Purist
Posted: Tue Dec 12, 2017 7:25 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Love seeing you out enjoying that bus!
Nice! _________________ Contact me at [email protected]
The Samba member since 2004.
oakman Samba Member
Posted: Tue Dec 12, 2017 8:08 pm Post subject: Re: 1965 westfalia so-35 flipseat |
notchboy wrote: |
That sucker looks good with yellow curtains |
wcfvw69 wrote: |
Nice! |
Thank you guys, this bus makes me smile. How can it not with all those colors going on?!!
I promise I'll get the wheel wells, paint blending and bumpers done soon. _________________ Brandon |
Posted: Tue Dec 12, 2017 9:04 pm Post subject: Re: 1965 westfalia so-35 flipseat |
oakman wrote: |
notchboy wrote: |
wcfvw69 wrote: |
Nice! |
I promise I'll get the wheel wells, paint blending and bumpers done soon. |
i wish everybody could find a car that makes them smile, would cut down on the assholes riding around _________________ regards
Uli
