busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Nov 19, 2015 5:26 pm Post subject: Amazing new "razor blade" belt drive system, WTF?? |
Not a joke, that's what it's called in the ad: http://www.thesamba.com/vw/classifieds/detail.php?id=1862736
I'm having a really hard time getting my head around this, first of all why?, and secondly how?. It looks like there's a bit of rubber every few inches for traction, is there cogs on the pulleys as well? (can't quite see), how long can a strip of metal flex until it lets go in the middle of nowhere?, does it stretch?, is it noisy?, how is it better aside from the steampunkish look? (that tensioner looks really special)
I also wonder about the ratios, looks like the fan would be turning fairly slow from the size of that top pulley (1:1?). Thier website is hokey so that's not much help
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Thu Nov 19, 2015 10:08 pm Post subject: Re: Amazing new "razor blade" belt drive system, W |
With many new products and innovations, I like to imagine what problem or question the inventor was addressing when they settled on the solution.
The only question I could come up with is, "Why didn't I cut my fingers clean off when I accidentally touched that rubber fan belt?"
I think this is a pretty damn good solution to that problem. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
modok Samba Member
Posted: Thu Nov 19, 2015 11:04 pm Post subject: Re: Amazing new "razor blade" belt drive system, W |
Very interesting!
I am sure it will be the perfect solution for......an application we haven't thought of yet. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Nov 20, 2015 12:33 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
I'm out, as I don't have an iPhone to run the tensioning app. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Fri Nov 20, 2015 1:26 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Looks like some industrial belt system applied to a T1 engine. It will have smaller losses for sure than a v-belt. And cut stuff more efficiently as noted before.
Maybe a good product for mileage fanatics? _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Nov 20, 2015 4:51 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
wonder if it 'whistles'
I hate any king of 'idlers' they don't last on our american junk _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri Nov 20, 2015 5:16 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
runs so tru that you don't even need an alternator/generator nut anymore
Saves weight thereby increasing gas milage |
risk Samba Member
Joined: June 24, 2004 Posts: 711 Location: Stumpbroke, Arkansas
Posted: Fri Nov 20, 2015 7:19 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
It slices, it dices, it makes julienne fries!! |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Fri Nov 20, 2015 7:33 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Why go out and buy an expensive counter top slicer when you can make ham sandwiches for your entire family from the comfort of your own garage.
"You set the timing"
"I'm not setting the timing"
"Let's get Mikey, He'll set anything"! _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
jeff68 Samba Member
Joined: November 02, 2007 Posts: 298 Location: Sarasota, Florida
Posted: Fri Nov 20, 2015 8:11 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Vw designed the factory Belt and pulley system so that the belt could slip at higher rates of engine acceleration and rpm. I think most of the serpentine belt systems are trying to eliminate belt slippage. So, in my opinion the serpentine systems are trying to eliminate what the serpentine system designer / manufacturer sees as a problem (belt slippage maybe?). I think this system isn't needed. I don't see any advantage to using a serpentine system for my car anyway. I can't understand spending money fixing something that if set up properly with stock parts isn't broken or a problem to begin with.
I think that alot of vw owners have belt / pulley problems caused by improper installation / adjustment, bent / worn pulleys, improperly made poor quality replacement crank and alternator pulleys, mis-aligned crank and alternator (or generator) pulleys, wrong belt for their application etc. The factory system is so simple and it works really well but all the correct components for the application have to be in good shape and they have to be installed and maintained properly. Things go wrong when one or more of the above are not right. By the way, the latest Hot VW's has a page or two on alternator pulley / belt problems by Steve Phillips and is really good to read.
My $0.02 |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6033 Location: CONGERS, N.Y.
Posted: Fri Nov 20, 2015 8:46 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Being in the Elevator Industry for 50 years as electro-mechanical design engineer, I could come up with a list as to why the belt system should be banned. But I will give you #1 on my list –It is so Freaking Dangerous!!!!!!!!! I had to incorporate my business to sell my Cali Deco Floating Pen. My lawyer said as simple as it looks what if someone uses it as a weapon, you could lose your house and life saving. The metal belt systems if it breaks not only can is whip around and slice and dice all your fuel lines and all your ignition wires and cable, but seeing it is metal it can short out and burn out your electrical systems like Electronic ignitions and regulators etc. Oh this should have been number #1-- think about what it can do to you, if it catches your shirt or a tool. Or if it breaks and whips around at 1000 rpms ( idle speed ). Slice your wrists or worse.
There are reasons some belts are made to slip like a fan belts to prevent a total lock up of the system.
Other belts are for timing that have teeth like a Timing belts.
Both are rubber or similar material, non conductive and safe. This has been the industry standard for years and for good reasons.
Anyone selling that had better have good insurance. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Fri Nov 20, 2015 9:14 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Seems the steel belt technology has certain niches, such as the food and medical industry. I agree it seems out of place as an automotive drive belt. _________________ 1958 Karmann Ghia owner |
jason Samba Member
Posted: Fri Nov 20, 2015 9:17 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Just a question, why do you think that VW designed the belt to slip? Is it written somewhere? Probably not designed to slip but the more powerful motors of today make them. My 36er wont slip a belt unless its ready to fall off. |
LivinInnaVWBus Samba Member
Dale M. Samba Member
Posted: Fri Nov 20, 2015 9:25 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Looks like just another attempt to get into the serpentine belt craze.... On than I will pass...
And the spinning metal belt reminds reminds me of a "bandsaw" blade made to to cut wood or metal.... Flesh????
mark tucker Samba Member
Posted: Fri Nov 20, 2015 10:11 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
has any body seen my fingers I do like the nylon crank pully they make,I bet it will reveloutionize the vw industry by damping the crank harmoncs and oh so light too.and you can spit off a belt in less than 3 seconds for a quicker 1/4 time. the pushrod tubes look quite small and might be good for stock stuff, but they might not work so good with a high loft cam. |
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Fri Nov 20, 2015 10:29 am Post subject: Re: Amazing new "razor blade" belt drive system, W |
Best response would be the little "X" in the top left corner,
And type selma hayek hot in the search and forget all.
Fabricator john |
