marcotheturbosteamengine Samba Member
Posted: Sun Nov 22, 2015 5:55 pm Post subject: 200hp-300hp Turbo Waterboxer is the US ready? |
Maybe some of you already know of me and some of you dont but Ive now settled in the US and was thinking of building waterboxers again, ive been building them for over 20 years, this wont be my full time job but maybe theres a market for the turbo waterboxer? there are already some great builders of N/A waterboxers in the US like Gowesty, Rocky Jennings, Vanistan just to name a few but no one turbocharges the waterboxer, N/A is fine if you want a max of 160hp reliably but above that the engines architecture and head constraints really warrant turbocharging. Stock to full race 800hp is possible.
Thanks
Marco Mansi |
insyncro Banned
Posted: Sun Nov 22, 2015 6:02 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
I'm ready.
Bring it.
Do you have some ideas to help the transmissions handle that amount of power and torque? |
Posted: Sun Nov 22, 2015 6:04 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Welcome to the US! Whereabouts did you settle?
I have followed your WBX doings for a long time now. You do some incredible work and obviously make some serious HP out of the WBX platform. I love the dyno video of the gray Beetle that needed slicks just to maintain traction. Awesome! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Sun Nov 22, 2015 7:53 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Complete with engine management system? _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Merian Samba Member
Posted: Sun Nov 22, 2015 8:05 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
interesting - I just finished reading about a 440 hp 4.0L flat six - air cooled & N/A |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Sun Nov 22, 2015 9:19 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Well, Marco, I hope you build that turbo WBX. I have a personal reason for hoping this. Among other problems I daydream about solving, the way to efficiently plumb the primary exhaust pipes to the turbo collector on a WBX has me stumped. All the configurations in my head require relocating the alternator and running without a distributor. The distributor drive shaft would simply drive a cam position sensor.
My idea of a turbo WBX is not intended to be a racing application or even a performance version, but just a better mousetrap for the Vanagon/Westfalia. The idea is a torquey engine that will climb hills at reasonable speeds (inspired by VAG engines like the 1.8T and Audi AAN). I also would want stock WBX reliability. I would be looking for about 170 to 180 ft/lb of torque from 2,000 rpm up to 4,500 rpm with digital boost control to make a flat torque curve and a J&S Safeguard knock control system. My thought is that this setup would benefit from a slight re-gearing by way of oversize tires.
The attractions of a turbo WBX include:
- no engine adaptor, no adaptor oil pan, no cooling system mods needed;
- minor harness mods instead of major;
- valve jobs cheaper than 1.8T (8 valves vs. 20)
- lots of cheap cores available.
Issues to Solve:
- ideal primary exhaust plumbing;
- piston oil squirter installation;
- better oil pump;
- forged piston crown design?;
- are Inconel exhaust valves needed?
- use stock intake system or modify for space considerations?
Overall, my goal would be to use every WBX part (instead of fabricating or "borrowing" from another vehicle) that can be used which will not impair the torque and reliability goals. By this, I mean, I would like to NOT use piston oil squirters if the design can do without them, NOT use a bespoke intake manifold if the design can do without, etc etc. The reason for this should be obvious - - to keep cost reasonable.
With enough Inconel, titanium, custom aluminum and bespoke billet parts, any technical problem can be overcome - - except cost. _________________ '86 Syncro Westy SVX |
gumbajv Samba Member
Posted: Mon Nov 23, 2015 7:44 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Living at 7,000 ft. elevation, I'm interested. 300 h.p. sounds about right. Would the manual or auto trans stand up to the power would be the next question. |
insyncro Banned
Posted: Mon Nov 23, 2015 8:30 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Hopefully we can have more information added to this post.
I am interested in the more modest 200HP version and have an excellent low mileage MV core from one of my Syncro Westys that I would have you build.
Of course, the details, pricing, time line and any sort of warranty information would need to be discussed, but I like the sounds of what you are doing and think that more would be built, once we see how it performs.
I have access to a chassis dyno and would be installing this engine, at my personal and now private shop.
Please let me know, here or pmail.
Thank you. |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Mon Nov 23, 2015 8:51 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Promising for sure but yes, the tranny would have to be addressed among a few other things.
I assessed a dubious 240 hp (and proper torque increments) would be ideal to power a fully loaded westy syncro to match modern levels of power to weight ratio so anywhere between 200-300 would be great. Doesn't the SVX get about 235 ? |
insyncro Banned
Posted: Mon Nov 23, 2015 9:36 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Yes, the EG33 is roughly 230HP, with more gained easily. |
Posted: Mon Nov 23, 2015 9:40 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
I'd think torque would be more important than h.p. I've run a few 911 motors in my '68 d/c. The 2.4 w/160 h.p. was fine, but not enough torque. The 3.2 had good torque. The '68 weighed around 2800 lbs with the 3.2. My '86 doka is at approximately 3600 lbs, stock. |
insyncro Banned
Posted: Mon Nov 23, 2015 10:14 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
I maintain a Porsche 3.2 powered Syncro.
It is awesome.
Not many here would care for the maintenance and preventative maintenance bills associated with that engine conversion.
Yes torque kills. |
Posted: Mon Nov 23, 2015 4:12 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Christopher Schimke wrote: |
I have followed your WBX doings for a long time now. You do some incredible work and obviously make some serious HP out of the WBX platform. I love the dyno video of the gray Beetle that needed slicks just to maintain traction. Awesome! |
Thanks for your kind words! Ive settle on the east coast, Baltimore. |
Posted: Mon Nov 23, 2015 4:17 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
240Gordy wrote: |
Complete with engine management system? |
Yes without a doubt, full control of fuel and spark with Knock control, a possibility of dash screen to monitor all engine parameters. |
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Mon Nov 23, 2015 4:19 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Cool.
What price point are you trying to hit?
Will this be a core exchange program type of thing or a kit?
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
Posted: Mon Nov 23, 2015 4:22 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Merian wrote: |
Interesting, who built it? I resonantly finished a 650rwhp 3.6L 👍🏼 |
Posted: Mon Nov 23, 2015 4:36 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Howesight wrote: |
Issues to Solve:
- better oil pump;
With enough Inconel, titanium, custom aluminum and bespoke billet parts, any technical problem can be overcome - - except cost. |
My 225hp 250ftlb 2.1L is exactly what your looking for , its temperament is the same as a stock 2.1mv, a stock type cam and lifters are used, just with added boost, the most important thing is to keep oil temps under control, engine and gearbox need additional coolers to sustain 80mph+ on the highway pushing 4000lb+ Vehicle with longer gearing. |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Mon Nov 23, 2015 4:39 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Hi, no transmission will easily handle more then 200 hp, who says so, the (RIP) guru Daryl from AA.
I have installed 2 Subi Turbo in my career and no transmission did hold, 1 auto and 1 4 speed.
I'm sorry I don't know you, can we see some of your work? That would be interesting and nice!!!
How about a mild one! Around 160 hp or so (even 140)? We all know that Turbo engine eat gas 3 time a day. Most owner have camper and some with kids and have no need for 300 hp.
How about a 120hp without Turbo?
and what about the cost of a 200 hp turbo engine? What part would you use?
Cheers, Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Mon Nov 23, 2015 4:48 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
gumbajv wrote: |
A real 300hp 300ftlb motor in a vanagon is rapid , both the manual and auto trans can be made to withstand the hp, axels are next on the list to brake if abused. |
