Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Apr 30, 2018 7:10 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
marcotheturbosteamengine wrote: |
Pbk wrote: |
Marco
please add me to the list for efi kit p.kirst@sbcglobal. Net
82X96 10/1 comp
Thank you
Phil |
Added thanks
Thats a nice combo, just the programable FI kit will transform the engine, with 10/1 compression you will be limited to 6psi of boost adding 40hp max on 93, if you used sunoco GT(100)you could run 12psi and get 80hp over your base line tune. |
What would you figure the numbers for 9.3:1 80x96 2316cc ported heads would be (boost and HP gained) on 91 octane Chevron fuel. |
Pbk Samba Member
Joined: April 23, 2018 Posts: 5 Location: Los Angeles
Posted: Thu May 03, 2018 6:47 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Marco
Stock rods ok to the 6psi of boost with ARP bolts
Thanks
Phil |
marcotheturbosteamengine Samba Member
Posted: Sat May 05, 2018 6:03 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Pbk wrote: |
Marco
Thanks
Phil |
Ive had the Stock rods with ARP bolts to 320hp in a Doka |
gumbajv Samba Member
Posted: Sun May 06, 2018 6:50 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
300 h.p. in a doka would be fun! |
Posted: Thu May 10, 2018 10:46 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Any updates? We want updates! |
CabbageVendor Samba Member
Joined: October 31, 2009 Posts: 8 Location: Northeast PA
Posted: Fri May 18, 2018 4:56 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Pbk wrote: |
Marco
Thanks
Phil |
I'm intrigued. Please add me to your list. cabbagevendor at gmail dot com |
noelleon Samba Member
Posted: Sat May 19, 2018 6:22 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Please add [email protected] to your list! _________________ '90 Westfalia w/ NAHT |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 806 Location: Seattle
Posted: Sun Jun 10, 2018 10:21 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
One of my favorite threads. Bumping this up and begging for an update. |
Posted: Tue Jun 12, 2018 4:20 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
CabbageVendor wrote: |
Pbk wrote: |
Marco
Thanks
Phil |
Added thanks |
Added thanks |
Posted: Tue Jun 12, 2018 4:48 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Just alittle update, I am working on the Efi and Turbo kit parts and will post progress here when it happens,
Just to keep the intrest going
This is a 1.9DG
Stock heads
Stock valves
Stock pistons
Stock crank
Stock head studs
Stock intake
Stock size throttle body
93 gas
25psi of boost
Made 350+hp!!!
https://www.facebook.com/ManchesterAircooled/videos/2005992626109528/ |
Posted: Mon Jul 09, 2018 10:44 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Hoping for some updates.
Is your kit going to utilize the stock exhaust header pipes or come with custom parts? _________________ Steve
Steve's 87 Syncro project |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Mon Jul 09, 2018 10:52 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Nice to hear a stock 1.9 + the efi/turbo CAN do 350+ on a dyno... I actually only WANT about 140 to 160 HP on my stock 2.1. I am not going to do much to my 93.5 tintop for the near future. Just try to put it in stasis. (drop gas, coolant, oil, put note on steering wheel says DONT TRY TO START!) And do some basic 'rust sleeps for now' attempts...
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
1fin Samba Member
Posted: Wed Jul 11, 2018 12:39 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Marco, please add me to your wait list [email protected]
I'm interested in the FI and Turbo kits.
Thanks
Peter |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17116 Location: Retired South Florida
Posted: Wed Jul 11, 2018 12:46 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Impressive numbers. Is the cooling system being updated to handle the additional BTU's being generated? That's a pretty big jump in power over stock. _________________ ☮️ |
Posted: Wed Jul 11, 2018 1:44 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
MarkWard wrote: |
Impressive numbers. Is the cooling system being updated to handle the additional BTU's being generated? That's a pretty big jump in power over stock. |
Marco stated his kit will include a real oil cooler. It will eliminate the factory oil cooler. Should work great. He is also water cooling the turbo using the plumbing that previously hooked to the liquid to liquid factory oil cooler.
I'm still curious about the exhaust configuration. Do we need the stock primary and secondary exhaust pipes or does the kit include a complete exhaust system? _________________ Steve
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Wed Jul 11, 2018 7:41 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Steve Arndt wrote: |
MarkWard wrote: |
I'm still curious about the exhaust configuration. Do we need the stock primary and secondary exhaust pipes or does the kit include a complete exhaust system? |
Good point. Ive been holding off on buying a new exhaust for this reason |
SubArcticHank Samba Member
Joined: May 02, 2016 Posts: 5 Location: Fairbanks, Alaska
Posted: Sun Jul 29, 2018 10:50 am Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Hey Marco I'd like to be added to the list: <[email protected]> Have a stock 1.9 and a GW 2.2 waiting. Hope things calm down a bit for you! |
Inlet Samba Member
Joined: April 12, 2010 Posts: 287 Location: SF Bay Area
Posted: Sun Jul 29, 2018 2:08 pm Post subject: Re: 200hp-300hp Turbo Waterboxer is the US ready? |
Too bad we won't be able to use it in California. |
