crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Sat Jan 09, 2016 5:02 pm Post subject: Re: No Power when reaching operating temperature |
I thought that might be the case. That could be your problem right there.
Mark
Oettingerdiesel wrote: |
crazyvwvanman wrote: |
It looks like some of the wiring is a little hacked. What is the thin black wire that goes up to a screw on the firewall?
Mark |
I asked the PO , he mentioned he grounded that wire to firewall coming from the hall sensor plug into main harness. I dunno why that was ever opened up, but it always ran despite this...... |
Oettingerdiesel Samba Member
Joined: May 20, 2010 Posts: 95 Location: South Florida (not miami)
Posted: Sat Jan 09, 2016 6:18 pm Post subject: Re: No Power when reaching operating temperature |
Mark
Mark |
Yea but i checked the signal with the volt meter on the hall sensor and from the the computer harness as in the manual and it all came back within spec. _________________ Driver Found! |
Posted: Sat Jan 09, 2016 9:07 pm Post subject: Re: No Power when reaching operating temperature |
Until you unwrap it and look you don't really know what is up with that wire.
It may have nothing to do with the hall. Then the question is what does it have to do with.
Mark |
Posted: Sat Jan 09, 2016 10:47 pm Post subject: Re: No Power when reaching operating temperature |
Have you popped the cap of the distributor to see is you actually still have a Hall pickup in there and your PO didn't swap over to using points? |
Posted: Tue Feb 02, 2016 5:35 pm Post subject: Re: No Power when reaching operating temperature |
bad coil _________________ Driver Found! |
pushkick Samba Member
Posted: Sun Feb 07, 2016 8:24 am Post subject: Re: No Power when reaching operating temperature |
i recently was having a similar problem with the loss of power and eventually found a wiring problem that was causing the problem. a faulty wiper switch that was causing the horm circuit to ground. this was causing the engine to have a rough idle and lose power. when the voltage drops down it causes many issue with fi and spark. _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
