ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Mon Nov 23, 2015 9:45 am Post subject: For the mechanic Guru (Subi problem) |
Hey guys.... I have posted this one of some Subi forum and on the Yahoo list but why not try here....
I'm stump. For my 96 conversion I did an older one, 2002, car from an old lady with no miles.
Did the usual HG and seal replacement and bla bla bla..
Problem: #1 is not firing properly at idle, look fine at 2000rpm. Of course it's not running smooth, not to bad but not perfect at all.
Ok, of course I did everything and replace everything, I can name it if you want but...
So unplugging the #1 injector at idle does nothing. Spark is good and coil, wire and plug where swap and all new anyway. Replaced/swap the injector same problem. Compression test is fine but the leak down test shows me a small leak on the intake side. Checked all valves adjustment and all is fine.
Pulled the injectors a bit out to see them spaying and they both spray at idle on this side, check every single wire from ECU to injector plug.
I read somewhere that a bad idle control valve could create a similar issue. both OS are unplug for testing and anyway it changes nothing if hooked. Ground is fine.
All other cylinder are acting normally if unplug, engine goes way to low. Strangely idle is at 700rpm or so.
No i didn't drive the van yet and yes I should.... but this engine as been working in the shop for more then 2 hours now.
Any suggestions?
Thanks, Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
insyncro Banned
Posted: Mon Nov 23, 2015 10:33 am Post subject: Re: For the mechanic Guru (Subi problem) |
I had a low idle and stumbling issue with an early one...it was building crankcase pressure and was not able to relieve it.
I would describe it as a mild choking.
Not saying this is your issue, just sharing.
Hope it helps. |
Honuak Samba Member
Posted: Mon Nov 23, 2015 11:13 am Post subject: Re: For the mechanic Guru (Subi problem) |
If have not done so already get a code reader (you can get one for less than $15.00) and check for trouble codes. A code will put your subaru motor in to limp mode, misfire. Many subi conversions (mine included) did not address things such as VSS, grounding, OX sensor etc correctly, Auto vs Manual confusion can be an issue as well.
With the code reader you can see what the problem is and then reset the ECU.
Usually you can drive the van normally for awhile before it goes back into limp mode but eventually the issue should be addressed. Once I fixed mine (grounding, VSS etc) I gained about 2 mpg and so far no more limp mode (fingers crossed) |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
insyncro Banned
Posted: Mon Nov 23, 2015 11:52 am Post subject: Re: For the mechanic Guru (Subi problem) |
Stumper
You will find out why Ben, I know you will.
Looking forward to hearing what it is and learning more from you.
Go gett'em Tiger. |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Mon Nov 23, 2015 12:09 pm Post subject: Re: For the mechanic Guru (Subi problem) |
Bad knock sensor ?
Made my subie do funny things once. |
insyncro Banned
Posted: Mon Nov 23, 2015 1:44 pm Post subject: Re: For the mechanic Guru (Subi problem) |
WestyBob wrote: |
Bad knock sensor ?
Ah yes, good point and maybe not the issue here, but they need to be properly clocked in my experiences. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Mon Nov 23, 2015 6:00 pm Post subject: Re: For the mechanic Guru (Subi problem) |
Nice job. Old lady with clean low mileage car usually means it hasn't been driven very hard and will get issues like that. Italian tuneup is needed on most cars! Unless you have seen the VW commercial of the old lady selling the Mk3 golf _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
pedrokrusher Samba Member
Joined: July 11, 2011 Posts: 654 Location: Montreal, Quebec, Canada
insyncro Banned
Posted: Tue Nov 24, 2015 5:07 pm Post subject: Re: For the mechanic Guru (Subi problem) |
ftp2leta wrote: |
pedrokrusher wrote: |
ftp2leta wrote: |
Problem fixed... a hard ride at 90mph and idle was back to normal. Compression also. |
Dang!!!
I wish I could fix all my problems like that!
Well try it, oupps one problem, you may not reach this speed
Ben |
I am sure that you mean 90km per hour...hint, hint.
Be safe out there.
"Professional driver, on closed course" |
boroko Samba Member
Joined: September 11, 2012 Posts: 326 Location: S.W. Michigan
Posted: Tue Nov 24, 2015 11:43 pm Post subject: Re: For the mechanic Guru (Subi problem) |
can't get 90mph? BS!
This is a cruise back from Florida to Michigan in a Westy Syncro with a stock 2.1. When the picture was taken, I'd been doing that for hours. And yes, the odometer is in miles, not km. Only major repair was a head reseal around 100k.
It'd go about 95mph before i wasn't comfortable with the handling, so I backed down a bit, but the motor didn't complain.
Just saying... that was before I learned they weren't suppose to do that.
Bo _________________ '87 SyncroWesty: Smokey the Turtle, '85 SubiWesty: Chappie, '84 GTI, '86 GTI in full Rally trim,
previous: 2 Syncro tin tops, 2 Vanagons, 3 busses, 3 Ghias, 2 Jettas, a 411, a gas and a diesel Bunny and about 25 Beetles, one that only drove left. |
boroko Samba Member
Posted: Wed Nov 25, 2015 12:44 am Post subject: Re: For the mechanic Guru (Subi problem) |
I know the issue has already been solved, and thankfully in a sweet way, but here is another tidbit that I learned from a trusted mechanic that I was working with lately.
He was having a problem with a mid 2000's subi that was going into retard from the knock sensor. A new sensor and proper torque did not help. He had found from one of his industry contacts that there were some of them (somewhere around 2002-2006) that had input protection circuitry on the ECU that failed and allowed too much of the knock signal through tripping a knock detect. The fix was to hook up high value resistor (around 560K ohm) from the signal line to ground to pull down some of the signal noise. The actual value was determined with a decade box or a variable resistor and watching the knock response. In the end, we got the right value and soldered it in. It allowed the knock function to still work and it solved the problem. All this is to say that there is a weakness is some of the ECU's and it will drive you nuts if you don't know about it. If anyone is having an difficult unresolved problem, I can get the exact years and procedure. Kind of an advanced procedure, but I have seen it answer a quirky problem that I had never seen.
I'm hoping to have my conversion done by spring for Busses by the Beach in May here in Michigan.
