13deluxe Samba Member
Joined: April 03, 2005 Posts: 19 Location: Manhattan Beach
Posted: Tue Oct 04, 2005 9:19 pm Post subject: |
I just finished my 66 beam. I drilled the dimples that i could reach and rewelded the holes after. I also cut TWO 1/2 inch galvenized pipes so i didnt have to swap ends when I was bashing the the center back and forth. The only thing I have to add is about the hardware. I found 14mm 1.5 thread (Thats what the stock thread is) that was about 1 and 3 quarter inches long or longer would work. I grinded the end to a point like the original set screw where it goes into the leave spring. Make sure you put a nut on the threads before grinding so you clean off the threads with the nut after. After I tightend the bolt into the leaves and then tightend the nut down on the cap, I welded the bottom piece on and then cut the head off the bolt. Then i cut a slot for a big ass flat head screw driver into the end off the headless bolt. It works perfect and I didnt have to retap anything. It gives you lots of clearence on the top for the shift tube. Nice!!!! Thanks for all the info in this tutorial!! |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Wed Feb 01, 2006 3:55 pm Post subject: |
Here is how I overcome the 14mm set screw problem now.
Stock center torsion retainer thingy.
Avis style adjuster for an early beetle CIP1 for $19(it does make a difference because you need the pointed set screw)
Hole drilled and taped for 1/2-20 TPI 180 degrees from the 14mm hole.
_________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Bill E. Samba Member
Joined: February 28, 2004 Posts: 792 Location: Port Angeles, WA
Posted: Wed Feb 01, 2006 10:45 pm Post subject: |
WOW great thread and soo much info...
So, why is there a second drilled hole in the center grabber??
I think it has something to do with flippin the torsion bars and twistin them?? But why a small set screw with no lock nut??
I made the new 14mm 1.4 X 60mm long bolts for the same reason. The center grabber is 14mm and the one in the kit is 1/2 20 (smaller).
I hear you can find some with the set screw end by using wheel studs. _________________ cars come and go, VW's live and breathe! |
yaz731200 Samba Member
Posted: Wed Jun 07, 2006 4:47 pm Post subject: |
o my god that u al so much i was gona pay sum mechanic 150 quid to du fit a new beam on my car. although im stil puting a new one geting it narrowed i jsut had a thought in bed aboutt he leavs and this jsut answerd it all thank you so much the job is so much more simple now |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Jun 07, 2006 8:13 pm Post subject: |
Bill E. wrote: |
because the short setscrew holds leaves in position by going into center detent on the leaves on a BALL JOINT beetle beam. a king and link pin has only one hole because the screw goes into dent on k/l pin front beam leaves. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
mabalot5150 Samba Member
Joined: October 06, 2005 Posts: 248 Location: Stone Province ESSJ
Posted: Thu Jun 08, 2006 2:27 am Post subject: man!!! |
holy shit!!! i see in black and white, have and IQ of twelve and drink out of the toilet...and, i understood that...youre the man, man. cant wait till i slam the beast. _________________ RoachGhia: haha, they're nuts designed to connect two bolts, or studs.
(21:21:50) vwluver74: nothing wrong with being gay pedro, but it is disturbing when yoiu shove burritos in your ass, flex your kegels and blow it all over your desk
twinwindows: How is it you guys know spark plugs but yet drive turds?
mabalot5150: cause they drive Carlos
twinwindows: lol. fuck you. |
Posted: Fri Dec 15, 2006 4:29 pm Post subject: |
Bill E. wrote: |
So, why is there a second drilled hole in the center grabber?? |
Finding a suitable 14mmx 1.5 stud is very hard. Thats why I use the given 1/2-20 one and redrill the retainer to accomidate it. A 1/2-20 tap is easier to come by than a 14mm x 1.5 allen stud that is long enough.
Does anyone know what size the ones that come with the new puma adjusters are?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C18%2D6313
I found out this thread is linked from the Puma link on CIP1's webpage. _________________ Why buy what you can build.
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Fri Dec 15, 2006 4:46 pm Post subject: |
jeremyrockjock wrote: |
Bill E. wrote: |
I found out this thread is linked from the Puma link on CIP1's webpage. |
If the Puma adjusters CIP1 sell are the same as the new CB Performance beams...2 1/8" tip to tip. _________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Posted: Fri Dec 15, 2006 4:54 pm Post subject: |
Thank Eric but I meant the stud size. 14mm or 1/2" _________________ Why buy what you can build.
Posted: Fri Dec 15, 2006 4:58 pm Post subject: |
Thank Eric but I meant the stud size. 14mm or 1/2" |
Oh...14mm, like I say, I'm checking with the CB beam, not adjusters from CIP _________________ ---
harryset Samba Member
Joined: July 14, 2005 Posts: 690 Location: Bemidji, MN
Posted: Sun May 20, 2007 8:03 pm Post subject: |
Getting ready to try this on my 72 standard bug, thanks for the great tutorial.
Question about your diagram on parts you don't mention. You show what appears to be 5 sets of retainers on each beam tube, but, only talk about the center retainer. . . what are the other parts pictured? _________________ '72 Standard
Proud owner of a "Hoover Bit"
185 60's up front, Empi disc kit, 2 1/2" drop spindles, 185 65's in back, stock drums.
Sound Deadening by Secondskin |
a_67vdub Samba Member
Joined: April 06, 2003 Posts: 504 Location: Long Beach
Posted: Mon May 21, 2007 9:11 am Post subject: |
The outer ones are the bearings, not retainers. |
AJ Quick Samba Member
Joined: July 20, 2006 Posts: 539 Location: Minnetonka, MN
Posted: Mon Jul 09, 2007 8:52 pm Post subject: |
I got this done on my Beetle today with the help of this thread.
I am going to use the stock center retainer though. So I ordered some 14mm bolts and nuts to put on them.
For some reason McMaster doesn't sell 14mm set screws! They skip it... We'll see how my bolts idea work. I am probably going to have to taper the front of them on the lathe though. _________________ Read My Beetle Restoration Blog!
http://www.RideSpace.net/
http://www.AJQuick.com/ |
Memph Samba Member
Posted: Tue Aug 28, 2007 1:07 am Post subject: |
Great thread and very informative. I have a question tho.
On the CIP site there are 3 different adjusters
BEETLE/GHIA 46-65
BEETLE/GHIA 66-77
and the Bus ones. Which of the Beetle ones should I get? I know there are the bus specific adjusters but if the beetle adjusters can be made to fit without much trouble i would rather go with that as it is half the price. fyi it would be going on a 72 Bus. |
jmsmilin Samba's Most Posted
Joined: November 10, 2005 Posts: 3302 Location: Out on Pa-troll.
Posted: Sun Oct 14, 2007 6:11 pm Post subject: |
this thread really helps me understand beams better _________________ Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/ |
nalange Samba Member
Posted: Sun Dec 02, 2007 12:13 pm Post subject: puma adjusters or avis? |
yes, why are the puma adjusters more than twice the price of the avis adjusters? and are they any better or easier to install? are the larger bumps necessary? |
Posted: Sun Dec 02, 2007 12:26 pm Post subject: |
Because anything bus related can be overpriced due to the poplarity. I still use the beetle avis adjusters. They work just as well at half the price. _________________ Why buy what you can build.
Posted: Sun Dec 02, 2007 12:57 pm Post subject: |
Yes except I can't remember right off whether I use the link pin or ball joint. One of the has the longer pointed set screw which I use after retapping the retainer for 1/2-20. _________________ Why buy what you can build.
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sun Dec 02, 2007 1:12 pm Post subject: |
Just saw this post, and Jeremy's post about not finding a proper 14x1.5 stud
I have a bunch of 14x1.5 hex head studs around, probably an inch and half long - they are wheel studs I bought for some Porsche lugs.
If you tapered the end would that work?
