i van Samba Member
Joined: August 23, 2004 Posts: 60 Location: south wales
Posted: Sat Sep 18, 2004 2:42 pm Post subject: |
jesus i would pay $24 for a complete kit!!!!
these kits are £120 here!!
british robbery i'm thinking!
so would i need the ball joint ones? even though my bus is king pin? |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Sat Sep 18, 2004 2:51 pm Post subject: |
It's the same kit except for the inside part, which you don't use on a bus beam, so either one. _________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
6D2 SBS Hit Squad
Joined: August 04, 2004 Posts: 1039 Location: Tampa, Floriduh
Posted: Mon Oct 25, 2004 6:10 pm Post subject: |
I need to order this setup for my bus... is it a weekend job for a novice? maybe I could hire a helper in the tampa area for the price of pizza and maybe beer for afterwards... _________________ Chris
The SBS #62
Red Hot Ad Specialties & Stuff...
Shirts and hoodies for shows or clubs.. we ship world wide...
www.pottymouthpromos.com |
dickcharlton Samba Member
Joined: February 09, 2004 Posts: 257 Location: Victoria, B.C., Cold Canada
Posted: Mon Dec 13, 2004 10:39 pm Post subject: |
So I'm hitting the centre piece with a pipe and a sledge and I get the piece to one side and i go to pull out the pipe and it won't come out. I guess I mushroomed the end of it. I think I have to make a cut for the adjustment and hopefully I can get in there with a grinder to grind off the mushroom so I can get my pipe out to do the bottom tube.
By the way. Those are awsome instructions.
Reminder:Use a a thick peice of pipe because you really gotta smash it. |
Posted: Tue Dec 14, 2004 10:23 pm Post subject: |
I got the pipe out and I've bashed the centre back and forth a few times but i can't seem to rotate the centre. Is there a trick to this besides drilling out the dimples? |
Posted: Tue Dec 14, 2004 10:37 pm Post subject: |
dickcharlton wrote: |
Now you need to make the groove, then put a lug nut in the center piece you broke, pound it up and down. Have adjusters? _________________ ---
Posted: Tue Dec 14, 2004 11:17 pm Post subject: |
I've got the groove and adjusters. Do i use a bus lugnut and just bash it back and forth until it slides real nice? |
Posted: Wed Dec 15, 2004 10:33 am Post subject: |
That is what I do. You can move the center up 3/8", then put your bar in and pound it side to side, that helps free the center up some more. _________________ ---
Rogerroger Samba Member
Posted: Thu Dec 16, 2004 1:24 pm Post subject: Wonderful tutorial |
jeremyrockjock,
I'm new to Beetle and have just discovered TheSamba. I was so very please with your tutorial on installing an Avis front beam adjuster.
Very wonderfully done.
Thanks,
Roger |
Posted: Thu Dec 16, 2004 2:03 pm Post subject: |
Long-roofs wrote: |
That is what I do. You can move the center up 3/8", then put your bar in and pound it side to side, that helps free the center up some more. |
Well I got bolts from Canadian tire threaded one inand hit it back and forth with a hammer until it slid good. So that's the bottom one done. Tommorrow I'l do the top. Thank you very much for your help. |
Posted: Fri Dec 31, 2004 5:29 pm Post subject: |
So I've got the front beam in the bus but the adjuster bolt on the top beam sticks out too far and gets in the way of the shift rod. The bolt is a 14mm X 1.75 inches long with a nut on it. I also tryed a 14mm X 1.5 inches long but with the nut on it it won't ground out against the leaves.
I thought about using a 14mm X 1 inch long bolt with no adjustment nut on it. Is this a bad idea?
I also thought about trying to find a headless 14mm X 35mm long allan bolt like the original bolt but with the thread of 14mm bolts I threaded in.
What did other people do?
Did anyone have this same problem of not having enough clearance for the shift rod? |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sat Jan 01, 2005 8:35 am Post subject: |
The shifter linkage is a issue depending on where you have the height set. One bus I actually modified the shift linkage to clear the adjuster. On my 58 I machined a nut to recess into the adjuster plate and used a 14mm to 1/2 wheel stud. You have to have a lathe to do that thou. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
earthmuffin Samba Worm Farmer
Joined: September 24, 2003 Posts: 1542 Location: In the shower..........peeing!
Posted: Sat Jan 01, 2005 2:57 pm Post subject: |
jeremyrockjock wrote: |
The shifter linkage is a issue depending on where you have the height set. One bus I actually modified the shift linkage to clear the adjuster. On my 58 I machined a nut to recess into the adjuster plate and used a 14mm to 1/2 wheel stud. You have to have a lathe to do that thou. |
Jeremy, Do you know if this is a problem on a baywindow also? I'm just assembling my beam after installing the adjusters and it is going back in my doublecab. Just wondering if I'm going to have shift linkage drama. _________________ This thread SUCKS!!! |
Posted: Sat Jan 01, 2005 4:00 pm Post subject: |
earthmuffin wrote: |
Jeremy, Do you know if this is a problem on a baywindow also? I'm just assembling my beam after installing the adjusters and it is going back in my doublecab. Just wondering if I'm going to have shift linkage drama. |
The one that I modified the shifter was a bay window bus. I used conduit. I created a peice with a deeper arch. I took the shifter rod and welded both ends to a fixture as to not loose the bolt locations because if you get them out of alignment it won't shift right. Then I cut the center out and welded in the new peice with the the lower bend. It worked good. _________________ Why buy what you can build.
Posted: Sat Jan 01, 2005 6:23 pm Post subject: |
Well I'll see what happens. Thanks for all the good information. _________________ This thread SUCKS!!! |
Posted: Sun Jan 02, 2005 9:57 pm Post subject: |
Anyone else got any good ideas or things they've done. |
h simpson Samba Member
Posted: Wed Jan 05, 2005 6:35 pm Post subject: |
I don't understand about the banging to loosen up the center piece.Do you put the rod down the axle tube or what? |
Posted: Thu Jan 06, 2005 8:39 am Post subject: |
yes. you smash it back and forth. |
Rocknrod Samba Member
Joined: November 02, 2004 Posts: 2157 Location: North Carolina
Posted: Thu Jan 06, 2005 9:30 pm Post subject: |
Nice model!
Could you do a primer on how you draw like that? |
Posted: Thu Jan 06, 2005 9:38 pm Post subject: |
h simpson wrote: |
I got a piece of 1 1/4 galvanized pipe with a cap on one end so I would have something to whack. Set the beam up on end and strap it to a work bench so it won't fall over and the get real intimate with a sledge, I would recommend at least 4 lbs. I beat it back and forth a few times, cut the slot, then turned the center retainer a few degrees and then beat it back and forth a few more times. Then once you get all worn out, you get to do it all over again on the other tube. _________________ This thread SUCKS!!! |
