jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sun Dec 02, 2007 1:27 pm Post subject: |
I think they would be too short. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sun Dec 02, 2007 5:12 pm Post subject: |
They also come in longer lengths for the guys who run spacers. |
VolkDubz Samba Member
Posted: Tue Dec 11, 2007 11:21 pm Post subject: |
powellscooter Samba Member
Joined: March 17, 2007 Posts: 589 Location: LAKE POWELL,AZ
Posted: Wed Jan 16, 2008 10:57 am Post subject: |
OK once all this is done, how do you do the actual height adjustment? I am thinking.... raise bus with jack, loosen adjusters, lower bus with jack to desired ride height, tighten adjusters. |
sled Samba Member
Posted: Wed Jan 16, 2008 11:09 am Post subject: |
that doesnt work because then the springs will compress and youll be lower than desired height.
just need to account for the suspension compression. _________________ drive your split. |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Wed Jan 16, 2008 11:21 am Post subject: |
powellscooter wrote: |
If you have some car ramps, put the front tires on them, use the floor jack to support the weight of the bus, loosen the adjusters and lower the floor jack etc... _________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Wed Jan 16, 2008 11:47 am Post subject: |
I usually set the bus up on stands, loosen the adjusters and jack the wheels / tires up to set the height. |
Posted: Wed Jan 16, 2008 12:05 pm Post subject: |
mr. warehouse wrote: |
Thanks MR. I appreciate it |
flowman Samba Member
Posted: Thu Jan 24, 2008 6:41 am Post subject: |
LOOKS SO GOOD!!
thank you for your info! _________________ looking for a place under the sun... Click to view image |
33 Willys Samba Member
Joined: January 28, 2008 Posts: 344 Location: Alamogordo, NM
Posted: Sat Apr 19, 2008 7:36 pm Post subject: Avis adjusters |
Just got done putting Avis adjusters on the bus. After reading the threads I decided to do it a bit different. First thing I did was use a spot rivet drill to remove the dimples I could get to. No damage to the center spring retainer at all and was easy to move it out of the way with a few taps. Next I cut the slot just a little bigger than it needed to be. I was able to get a die grinder in and smooth out the rest of the dimple area as well as a LITTLE grinding on the rest of the area. Now the spring retainer moves easily by hand. After welding in the adjusters there is a little heat warpage but the adjusters still move easy. I will use black RTV to cover the holes so there will not be more heat distortion due to welding. I recommend a 1" square tube to beat the spring retainers out of the way because it has less chance of rounding off the edge of the spring holes. If you beat it too much the hole will get peened over and then you have a tuff time getting the springs back in. Drilling out the dimples solve this problem. |
Klemen Klemen Samba Member
Joined: March 09, 2005 Posts: 150 Location: Slovenia, Ljubljana
Posted: Wed May 28, 2008 1:42 am Post subject: |
Hey all!
Could someone tell me how to drill out this holes without damaging the inner part where the bolt is put in.
_________________ 1955 oct oval
1960 jan split bus
1974 topless |
volksfahrer.nl Samba Member
Joined: September 18, 2003 Posts: 2128 Location: Delft Holland
Posted: Wed May 28, 2008 2:05 am Post subject: |
Hey klemen!
after you've drilled out the diples in the beam that hold the centre-block in place you can slide the block a bit away from the center.
That way you have room to change the bolthole into a slot.
Be sure to slide the centre-block back in plave when welding up the dimples again.
Also rotate the block while you weld to prevent it from getting welded stuck! _________________ www.volksfahrer.nl
www.theundutchables.nl
66 panel |
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Wed May 28, 2008 9:11 am Post subject: |
I just installed adjusters on my bus while the beam was still bolted in. I used a 1-1/2" heavy wall pipe and 5lb sledge to smack the retainer off the dimples then I used a small cut off wheel to cut the slot and a die grinder with a burr bit to grind the dimples down from the inside. Smacked the retainer back to center from the other side, weld in the adjusters and it's done. I used the avis style adjusters but I disected them and rewelded and now they resemble the Bus Boys "Albatross" style. I will post some pictures as soon as I locate my camera, mia for 3-weeks now.
Shhhh...it was on my bay window bus but the concept is the same. Oh, and I was RAISING my bus not lowering. _________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
Posted: Wed May 28, 2008 12:42 pm Post subject: |
Are you talking about these things?
BTW, how hard it is to just smack the retainer off? _________________ 1955 oct oval
1960 jan split bus
1974 topless |
Posted: Wed May 28, 2008 3:38 pm Post subject: |
I create the slot with a cut off wheel. Yes those are the dimples _________________ Why buy what you can build.
rjonas Samba Member
Posted: Thu May 29, 2008 7:51 am Post subject: |
Klemen Klemen wrote: |
BTW, how hard it is to just smack the retainer off? |
Yep, those are the dimples, 3 per tube. 1-2 of them are hidden by the pivot bracket. You will need a 5lb sledge hammer as a claw or ball peen is not heavy enough and a 3-foot long x 1-1/2" pipe. I think it took 7-8 good solid smacks to get it off the dimples. I have narrowed several bug beams and installed adjusters but this was my first bus beam. Installed adjusters while beam was still in the bus, this was so much easier plus I only had to remove the shift rod. All the tie rods, brake lines, master cylinder/booster, clutch, e-brake and gas cables stayed there. Was almost too easy.
Although I like the bug style with adjuster bolt instead of avis/albatross style with the meshing teeth. Have not seen anyone use that style on a bus but making adjustments on the fly would be easier. _________________ 1979 Type-2 Westfalia “Sandy”
www.azbusclub.org |
Posted: Thu May 29, 2008 2:12 pm Post subject: |
Actually what I do now is cut the retainer out totally. I then hammer the dimples with a punch and then set the retainer back in and fill in the hole except for where the adjuster bolt will slide. _________________ Why buy what you can build.
rjonas Samba Member
Posted: Tue Jun 03, 2008 5:38 am Post subject: |
Pictures as promised.
Cut the slots
The Avis style before I cut it up
1-1/2" pipe with "C" channel for pounding
Grind the dimples from the inside with this
My creation: The "Avis-atross"
Set to raise 2" or drop 4" from stock height.
Ta-da
www.azbusclub.org |
tofftons Samba Member
Posted: Wed Sep 10, 2008 8:32 am Post subject: beam ??? |
my beam does not have dimpplies it has long crimps ...so now what |
Posted: Wed Sep 10, 2008 11:05 am Post subject: |
I have never seen one like that. Can you post a pic of it? _________________ Why buy what you can build.
