SGKent Samba Member
Posted: Tue Nov 22, 2022 4:17 pm Post subject: Re: Solution!!! found 10mm swivel foot adjusters for type 4 rock |
Colin - I have a set you can have next time you are here as long as I haven't listed them for sale by then. I went back to polished normal screws which had better geometry on the valve tips. I also returned to spring spacers instead of the solid spacer because I am not running heavy duty valve springs. I happened to be watching a racing engine being built from the era and it was designed for very high RPM's. It had springs instead of spacers so I decided the idea VW used wasn't all that bad. My guess is when they went to hydraulic lifters, and they had to up the valve springs to control the lifters from pumping up, they had to replace the spacer springs with solid spacers to keep the rocker arm side loads under control.
Prior to the type 4 heads, other than my type 1 engine work on my 1971 bus, almost all the racing engines I built used lifter cups instead of rocker arms. I guessed that the swivel feet and solid spacers would be better, but there are geometry changes that are needed. Also all the new swivel feet I got had burrs and rough bottoms, so I had to polish them all to keep valve tip wear to a minimum, and get consistent valve clearance readings. In the end I just went back to the stock set up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Nov 22, 2022 6:27 pm Post subject: Re: Solution!!! found 10mm swivel foot adjusters for type 4 rock |
SGKent wrote: |
My guess is when they went to hydraulic lifters, and they had to up the valve springs to control the lifters from pumping up, they had to replace the spacer springs with solid spacers to keep the rocker arm side loads under control. |
With hydraulic lifters there is often a light compression on the valve train, this may cause the rocker to move sideways a little, this of course lessen the pressure on the drive train and the lifter may pump up a bit more creating a cycle where the rocker is pushed sideways a tiny bit more with every repetition until problems occur. Since solids don't pump up this does not occur in normal use, but can happen as valve train recession takes place. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Nov 23, 2022 5:11 pm Post subject: Re: Solution!!! found 10mm swivel foot adjusters for type 4 rock |
SGKent wrote: |
Colin - I have a set you can have next time you are here as long as I haven't listed them for sale by then. My guess is when they went to hydraulic lifters, and they had to up the valve springs to control the lifters from pumping up, they had to replace the spacer springs with solid spacers to keep the rocker arm side loads under control.
Thank-you, I will keep that in mind. Since next time is at least 4,000 miles away, I am considering 1700 rockers and 8mm genuine Porsche adjusters to keep my Hoffman heads as happy as possible out on the interstates.
I will be rebuilding NaranjaWesty's engine here as a preventative maintenance operation before clearances start to bang things out of shape.
Colin
_________________ www.itinerant-air-cooled.com |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Fri Dec 02, 2022 1:10 pm Post subject: Re: Solution!!! found 10mm swivel foot adjusters for type 4 rock |
I had two British specification, 1974~75 VW 1800 Type 2, VW 1800 Type 4 style, AP-Series air-cooled engines. One had M8 x 1•0 mm valve-rocker adjustment screws in common with a VW 412LE, VW 1700 Type 4 style, W-Series air-cooled engine I also had, whilst the other had M10 x 1•0 mm valve-rocker adjustment screws.
I used two of the worn & pitted M10 x 1•0 mm valve-rocker adjustment screws, with the ends cut off and through-drilled on a lathe, as the basis for the spacer-mast of my oil-pressure gauge-sender, installation adapter, as illustrated in my article (see picture at the bottom, left-hand side of the second page) that was published several years ago, in Volkswagen Camper & Commercial magazine.
Nigel A. Skeet, “How to: Fitting an Oil-Pressure Gauge-Sender, Installation Adapter, to the Type 4 Engine”, Volkswagen Camper & Commercial, Issue 17, Winter 2004, Pages 44~45.
_________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
SGKent Samba Member
Posted: Mon Jan 23, 2023 4:41 pm Post subject: Re: Solution!!! found 10mm swivel foot adjusters for type 4 rock |
I think I just figured out why I had trouble adjusting the swivel feet when I tried them on my 2L engine. The solid lifters webcam used (and may still do that) have a plunger cup in them. It you blow air into the top of the lifter after cleaning it, it sits lower. If you blow air into the side holes then the plunger cup moves out to the snap ring. Steve at Webcam told me they were made by Johnson Controls. Jake noted the snap rings and plunger action in them back in the early 2000's in a shop forum thread. Because the lifters have no valve in them like hydraulics, they are not going to pump up like hydraulics, however oil pressure is going to take up all the slack in the interior portion when the lifter is on the base circle. This small amount of oil in the lifter will cause the swivel feet to always ride collapsed and not allow oil into them. Further, the combination of a little oil inside the lifter body, combined with the swivel is going to make it harder to adjust them when the lifter is on the base circle. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
