77 vw bus won't shift into gear!
getmyvwontheroad!
getmyvwontheroad! is offline
PostPosted: Tue Dec 15, 2015 1:28 am    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
I've tried researching and reading manuals to try and understand, I'm just lost! I've visited the links that have been posted, but I'm still confused Shocked Mad
What does 28* BTDC mean? Sorry for the questions, I'm sure it's simple. This is my first time doing maintenance on it, other than changing the oil and spark plugs.
Setting up shop from a 77 VW Bus Smile
http://lifessweet.bigcartel.com/product/let-s-go-there-tee
Check out the page and give us a follow!
http://www.instagram.com/lifessweetclothing
Tom Powell
Tom Powell is offline
PostPosted: Tue Dec 15, 2015 1:43 am    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
getmyvwontheroad! wrote:
And I checked out the How to Keep your VW Alive from the library a few months ago, guess I'll go back and grab it again ! And thanks for the axle explanation, makes sense now
Check out the book from the library again and read up in it.
Better yet, buy a copy for yourself.
http://www.amazon.com/s/?ie=UTF8&keywords=how+...2n1h3_b_p2
A Bentley is the shop manual, but it doesn't have the explanations that the Muir book does.
http://www.amazon.com/Volkswagen-Station-Wagon-Ser...ley+manual
You'll find information about your CV joints in the Muir book.
BTDC is before top dead center
that is the ignition timing spec
Aloha
tp
Tcash
Tcash is offline
PostPosted: Tue Dec 15, 2015 9:53 am    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
The videos should help.
Timing -
28* BTDC at 3500rpm hoses off
Timing
Vintage VW Training Film - Ignition Timing Part 1
Vintage VW Training Film - Ignition Timing Part 2
Vintage VW Training Film - Ignition Timing II
Good luck
Tcash
getmyvwontheroad!
PostPosted: Tue Dec 15, 2015 5:08 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
So I think the problem may be bigger than the timing or it could be a result of bad timing. I fired up the bus today and it was idling really low at about 600 rpms and I was looking at the motor/exhaust and saw black or dark brownish bits spitting out the exhaust? It looked almost like oil and I was able to see it sitting inside the exhaust. It looked like a liquid ball before it would come out. Does anyone have any idea about this?
Wildthings
Wildthings is offline
PostPosted: Tue Dec 15, 2015 6:14 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Sounds like dirty condensate, if so it is perfectly normal to see such when a cold engine has first been fired up. So long as the exhaust pipes are below the dew point of the exhaust gases this will happen.
getmyvwontheroad!
PostPosted: Tue Dec 15, 2015 9:23 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Okay thanks for that, so as far as the timing, I watched the vids and it explained what goes on with the spark plugs/distributor and what not but I didn't catch how to set the actual timing.
Also I can't seem to find these "notches" on the pulley that I would line up? How am I supposed to know top dead center?
Tom Powell
PostPosted: Tue Dec 15, 2015 9:44 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
https://www.youtube.com/watch?v=ulQmKU2weyI
Aloha
tp
getmyvwontheroad!
PostPosted: Tue Dec 15, 2015 9:49 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Aloha
tp
Will this method work on my 77 fuel injected bus? I can't seem to find the valve cover on mine?
Tom Powell
PostPosted: Tue Dec 15, 2015 9:54 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
... I can't seem to find the valve cover on mine?
The valve covers are on top of the cylinder heads.
Aloha
tp
getmyvwontheroad!
PostPosted: Tue Dec 15, 2015 10:08 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Will oil come out when the valve cover is opened? I saw video and oil was dripped out Shocked
Tom Powell
PostPosted: Tue Dec 15, 2015 10:10 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Some, but not much.
Aloha
tp
Wildthings
PostPosted: Tue Dec 15, 2015 11:46 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
A Type 4 engine is going to have a timing scale as per below. The metal scales are white and the plastic ones are black, but either will do the job.
The pulley is going to have a tiny V notch on the forward rim for the TDC mark. If no one has painted the mark it can be hard to locate. You may need to run your fingernail or a knife blade along the forward rim of the pulley to locate the mark. The mark really needs to be painted, why people don't do this is beyond me. I have the V notch painted and then have a line filed in the outer rim which is also painted, makes life that much easier.
getmyvwontheroad!
PostPosted: Wed Dec 16, 2015 9:22 am    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Mine has the plastic timing scale on it, just no notches. I read you can find top dead center by listening for air out of the first spark plug? Or taking off the valve cover to see the valves? Is this accurate? And here's my engine
Wildthings
PostPosted: Wed Dec 16, 2015 9:35 am    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
You need the exact TDC not an approximation. Do as I suggested and run your fingernail along the forward rim of the pulley. You could also use a knife blade or anything else that will pick up the minor indentation of the V notch. There is an off chance you might have a pulley off of a Porsche/411/412 which used a timing mark in a different location, there are remedies for this, but first you need to be absolutely sure that you don't already have the proper bus style timing mark.
Tom Powell
PostPosted: Wed Dec 16, 2015 12:15 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
It looks like you have an MSD ignition system. Possibly with wire nut connections.
Aloha
tp
getmyvwontheroad!
PostPosted: Thu Dec 17, 2015 2:44 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Do you think that red mark could be from the previous owner? I turned the pulley until the distributor rotor was pointing at the first spark plug on the distributor. Could that be top dead center?
SGKent Premium Member
SGKent is offline
PostPosted: Thu Dec 17, 2015 3:09 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Bus Engine Cooling Issues? https://kentcomputer.com/77VW/BusEngineCooling.pdf
getmyvwontheroad!
PostPosted: Thu Dec 17, 2015 3:14 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
Alright so the notch is right behind the red mark, so it looks like it is. I just pointed it to top dead center, should it be moved to 7.5 btdc?
Wildthings
PostPosted: Thu Dec 17, 2015 6:10 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
TDC on a Type 4 engine is when the timing mark lines up with the zero on the timing scale and not with the parting line of the case.
getmyvwontheroad!
PostPosted: Thu Dec 17, 2015 6:14 pm    Post subject: Re: 77 vw bus won't shift into gear! Reply with quote
oh okayy thanks, so I would move it to the 0 on the scale or 7.5 on the scale to set the timing?
Page 3 of 4
