metropoj Samba Member
Posted: Tue Dec 01, 2015 11:01 am Post subject: Rear deck to floor Square Footage measurement? |
I was wondering if anyone could share the square footage or maybe measurements of the rear deck side to side and from the back hatch down to the floor under the rear seat ?
I need to purchase sound proofing materials to cover this whole area but I haven't the opportunity to rip out my Westy interior to measure it up beforehand ...
Thanks in advance if you can help .... _________________ John.
86 TiiCo powered Westy. |
rubbachicken Samba Member
Posted: Tue Dec 01, 2015 8:59 pm Post subject: Re: Rear deck to floor Square Footage measurement? |
gestimate and add 20%, i tried measuring for insulation on a split bus in england, i went through the motions and measured out how much i needed, when i went to do the job i came out short _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Wed Dec 02, 2015 5:18 am Post subject: Re: Rear deck to floor Square Footage measurement? |
In retrospect, is there ever such a thing as 'extra' sound deadening ??
I am sure I'll find piles of places to use it up ... _________________ John.
Merian Samba Member
Posted: Wed Dec 02, 2015 12:22 pm Post subject: Re: Rear deck to floor Square Footage measurement? |
the metal over the engine is quite stout (and corrugated) - rap it and you'll see that no deadener is really needed
OTOH, if you have some left over from other spot, cut it into strips and put it in the valleys (like I did)
put closed cell foam over that and then MLV - worst thing is you'll just be adding some cushy base to sleep on |
Posted: Thu Dec 03, 2015 5:28 am Post subject: Re: Rear deck to floor Square Footage measurement? |
Thanks for the tips. Any noise advantage of the metal engine hatch over the fiberglass hatch ? I have both, the metal is quite a bit heavier. I also removed all my factory sound deadener crap that was over top of the tranny.
I'm looking at products from second skin since I have a dealer within reasonable distance.
Many of their products are multi layered approaches where you can put down an MLV or other products and also coat with a product similar to the lizardskin that insyncro showed in use. I have to read and talk with them on what is right for my application. They have many different grades of products and for many different types of noise. I want to do this once and right the first time _________________ John.
Merian Samba Member
Posted: Thu Dec 03, 2015 10:33 am Post subject: Re: Rear deck to floor Square Footage measurement? |
I'd expect FG to be less noisy, but more likely to burn thru in an engine fire... |
